Results 1 to 23 of 23
Thread: 1991 850i No Start/Won't Stay Running
    Apr 2016
    St. Louis, MO
    1991 BMW 850i
    I'm starting a new thread to just focus on the one issue with this 850. It won't stay running. I got this car for free and I really want to get it running and am thinking about restoring it in some shape or form.
    After replacing various parts, it will run but only for a second before stalling. Video of what its doing here (sorry its sideways): https://www.youtube.com/watch?v=HmBXXo4xWKA
    What I Know:
    -It has spark
    -It has plenty of fuel flow (have not been able to test pressure)
    -All Fuses are good
    -Seems to be no codes
    What I have replaced:
    -Both bad fuel pumps
    -Fuel hose that was leaking in sending unit and after fuel filters
    -All Plugs
    -Plug wires/ID sensors
    -Both crank sensors (one for sure was bad)
    -Known Good used FPRs
    -GM Capacitors (not related to starting)
    I need any advice now on where to go next. Hopefully the video will help you understand whats happening. Help me save her!
    Feb 2013
    Sarasota, Fl
    95 840CI 91 850I
    If it were me I would get the number off the EML and buy a known good one with the same number. Should not be much and if it fixes it great if not you have a spare.
    I had a car with a bad EML and it did crazy stuff once the good one was plugged in everything got better. It did not show EML light.
    IF you have Compression, Fuel and spark it should start. If not then it has to be something that is not telling the fuel injectors to fire off after the initial start. If timing was screwed up and you keep cranking there would be misfires.
    BMW CCA #500359 E31 Chapter.
    Jun 2008
    TT Cayenne / SC 850
    I was actually over another owners house on Tuesday diagnosing a very similar issue.
    He had replaced both fuel pumps but the car would not start, we had spark and no codes.
    It turned out to be a blockage in the fuel filters and lines, the fuel filters were never replaced. Also he had leaks in the fuel pump assembly lines.
    There was some fuel flow coming out but pressure was not adequate.
    Replacing both fuel filters and running the fuel pumps manually after fixing pressure leaks in the assembly solved the problem.
    It now runs on all 12!
    Apr 2016
    St. Louis, MO
    1991 BMW 850i
    EML = Engine Management Light?
    Do you mean DME? This is an 850 so I would need two DME's.
    I will add that unplugging one DME it acts similarly. Starts up on 6 cylinders then turns right back off.
    Quote Originally Posted by dragon850 View Post
    I need to just check the pressure. My gauge is really wanting to leak which is causing problems. I'll get the pressure checked at the filters. Maybe my problem is just fuel pressure... I definitely have plenty of flow. Once I fixed some fuel hoses that were busted, the car would actually start and not just chug and try to start. So its definitely better.
    Jun 2008
    TT Cayenne / SC 850
    Quote Originally Posted by breeves002 View Post
    BMW 850 had 2 DMEs and 1 EML module.
    So have you replaced fuel filters?? That might be your problem.
    Feb 2013
    Sarasota, Fl
    95 840CI 91 850I
    You have one EML and Two DME. Take the EML out record number and go hunting. It is located in the same box as the DME's.
    I thought you checked the fuel pressure at the regulator rail and it was good. Fuel pressure guage and T with shrader valve not very expensive and not too difficult to do.
    Del Mar, CA
    91 850i, 01 740i, 06 760
    You should measure the fuel pressure at the fuel rails. Harbor Freight has an inexpensive meter that will do the job. If that is good i would connect an oscope to the injectors to determine if they are being shut off.
    Apr 2016
    St. Louis, MO
    1991 BMW 850i
    Will report back tomorrow with findings if its not raining tonight.
    EML is the third computer in there, got it.
    Apr 2016
    St. Louis, MO
    1991 BMW 850i
    Update:
    3 videos for your viewing pleasure.
    *seems* that fuel pressure is OK on both banks. Its oddly wild to me. I feel like it shouldn't be so uneven?
    Looks like injector pulses are being stopped by the DME for whatever reason and that is why the car stalls. I didn't feel like pulling the o scope outside since it looked like it was going to rain so I just used the test light. Works just as well for this although not nearly as much resolution.
    Something started squeaking today that hasn't done it before after the engine starts.
    Is EML a valid possibility? I really don't want to just throw parts at it.
    FP Bank 1: https://www.youtube.com/watch?v=-GjHM8zNEng
    FP Bank 2: https://www.youtube.com/watch?v=wbTU4Bqq59g
    Injector Pulses: https://www.youtube.com/watch?v=FkUANJjBJnw
    Jul 2014
    Westfield, IN
    '91 e31 M70 |'01 e38 M73
    I would say next step is EML as mentioned above.
    Sent from my iPad using Tapatalk
    MY SPEEDO ON THE 'BAHN!!! - @155!
    '07 e65|N62 - Alpina B7 - Black Sapphire|Black|Loaded
    '02 e46|M54 - Orient Blue|Beige|'Vert
    '00 e39|M52 - Anthrazit Metallic|Grey (Daughter's)
    '01 e38|M73 - Anthrazit Metallic|Schwarz|Shadow-Line
    '91 e31|M70 - Schwarz|Schwarz|M70
    '13 328i Auto - Black Sapphire|Coral Red|Sport Line|GONE
    '05 545i SMG - Jet Black|Black|Bamboo Anthracite|GONE
    '07 335i Auto - Montego Blue|Grey|GONE
    '05 545i SMG - (Euro Delivery 7/22/05)|Black Sapphire|Auburn|GONE
    '97 528i Auto - GONE
    Jun 2008
    TT Cayenne / SC 850
    Couple things, you did not say if fuel filters have been changed?
    You still might have a blockage judging from fuel pressure being uneven, also the fuel pressure droops off too fast IMO, you might have a leak at the lines in the fuel pump assembly.
    We still don't know what the codes actually are, INPA never was connected?
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    That looks like you are getting no signals from the Cylinder Identification Sensors (the devices on plug wires 6 and 12). If the DME's don't get a signal after a second or two they turn the injectors off to stop wash-down of the cylinders. By the way, the fuel pressure should stay at 2.5 Bar or so at the fuel rail when the engine is not running for weeks - the pressure should be maintained between the fuel pump (by a built-in one-way valve) and the FPR's.
    P.P.S. Just seen that Dragon has already said that.....
    Apr 2016
    St. Louis, MO
    1991 BMW 850i
    Happy memorial day! Was at the lake all weekend. Going to the Carlisle Ford Nationals in PA this week...
    Anyways, I'll have to check for the pressure bleeding off so fast. Its not the FPRs so it must be at the pump housing. The fuel filters I have not personally replaced. They have been replaced before.
    The ID sensors are brand new. Doesn't mean they aren't bad, but they came on a new set of plug wires. I'll get my scope out and see what output I'm getting from those. Anyone know what to look for?
    I don't believe there are any codes. I haven't had the chance to try to get that all working again. I've been very busy.
    Does anyone else think the EML should be replaced or should I wait to do that?
    Apr 2016
    St. Louis, MO
    1991 BMW 850i
    I'm back! I've been traveling to DC for work a few times the past few weeks and just been busy overall.
    I finally pulled the EML tonight and ordered an exact replacement. $45 on eBay, not bad. Will replace and cross fingers it changes something. If it doesn't.... I may have to sell it. I can't sit on this thing much longer. That would be really sad. I'm so close it feels!!! I honestly don't think this is the problem.
    I'm going to check the ID sensors with a scope this week. They're brand new but new things can be bad.
    Just a recap: the engine will fire up but the injectors stop firing a few seconds after startup and it turns right back off. If anyone has any more suggestions please feel free to tell me.
    I have air, spark, and fuel pressure is ~50 PSI although very jumpy.
    I've replaced:
    - Both fuel pumps
    - Pieces of fuel pump hose
    - Both crank sensors
    - Plugs and wires/ID sensors
    - FPRs
    Something really weird. When I first got it and had just replaced the fuel pumps, I got it to run on 1 bank for about 10 seconds before it died. Now it won't run for more then 3... Just odd...
    Jun 2008
    TT Cayenne / SC 850
    So how about fuel pump relays??
    Woodland Hills, CA
    Disco II 850i MERs 750il
    One problem I had was shorting of the fuel pump relays to the fuel pump relay fuses wiring that goes along the firewall. The insulation had crumbled and the bare wires shorted.
    Apr 2016
    St. Louis, MO
    1991 BMW 850i
    I have fuel pressure and the fuel pumps run, so how would the relays be a problem? Its the injectors that turn off - the pressure is solid.
    I'm being told that if you unplug the coolant temp sensor the DME's think the car is super cold and will fire the injectors in batch firing mode instead of sequential. He also said it should run for a little while with the ID sensors unplugged.
    Can someone just try unplugging their ID sensors and seeing if the car runs more then 3 seconds?
    Sunny Cali,
    6.5 second 69 Camaro
    Turn the ignition on without cranking the car over, Under the hood, Do you get a Buzzing sound from your Throttle bodies/DK's?
    Apr 2016
    St. Louis, MO
    1991 BMW 850i
    Yes buzzing is there. The throttles operate with the car in the on position. They both open if I push the gas pedal.
    Sunny Cali,
    That means your hidden fuse is not the issue, Strike one! If you don't wanna throw parts at it, Get or borrow a diagnostic tool, What type of plugs did you install and check the condition of the caps and rotors.
    Apr 2016
    St. Louis, MO
    1991 BMW 850i
    Spark is fine. Like I have said previously, the problem is the injectors are turned off. I used not the OEM ones that are impossible to find but the newer Bosch ones. I didn't look at the caps and rotors - I should, but that won't make it die right away. The issue is the car starts, then turns off due to the computer cutting fuel... 3 seconds later.
    Nov 2011
    VA
    Want 850
    I'm dealing with this as well, however only one bank is doing this. Did you fix yours?
    Feb 2014
    Louisville, KY
    BMW 730i
    Did anyone get this solved?
    Quote Originally Posted by Cup1d View Post
    How about some follow-up on this problem?
  1. '99 M3 won't stay running after start up
    By the Scholar in forum 1992 - 1999 M3 (E36)
    Last Post: 06-27-2013, 12:18 PM
  2. Cause of Starts, Won't Stay Running?
    By Dr320i in forum 1975 - 1983 (E21)
    Last Post: 07-09-2010, 04:34 PM
  3. E38 starts but won't stay running (jinxed myself)
    By sdmike1 in forum 1995 - 2001 (E38)
    Last Post: 01-29-2010, 11:19 AM
  4. 89 535i starts, but won't stay running.
    By Ramm328 in forum 1988 - 1996 (E34)
    Last Post: 03-20-2008, 02:52 AM
  5. 1997 M3 won't stay running (no idle)
    By HomerJaySimpson in forum 1992 - 1999 M3 (E36)
    Last Post: 05-19-2007, 05:38 PM
