Hello All
hoping some one can provide some insight.
Currently my e30 sits on ground control coil overs.
The rear springs are 0500.225.600 (5" length , 2.25 diameter , 600lbs)
my car experiences excessive wheel hop - dampers on softest setting
am wondering if I went with a taller spring and a softer rate if that would help reduce wheel hop or is a progressive spring the way to go?
I dont drag often but figured you guys would know spring specs a little better.
What tires are u running ?
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
size 195 60 14 Summotos or something like that.
but no matter what type of tires or size it hops bad.
in comparison my brothers e30 with progressive lowering springs gets little to no hop.
the rear subframe and trailing arm bushings where changed prior to my ownership. They are green so poly maybe.
