Page 6 of 10 FirstFirst 12345678910 LastLast
Results 126 to 150 of 228
Thread: E90 Can bus project (E60, E65, E87....)
  1. #126
    Nov 2005
    Kilmarnock, VA
    E53, E90, Triumph GT6
    Quote Originally Posted by MrBlah View Post
    Anyone have a list of the PT-can channel / ID / Format? Looking to add pedal position, wheel speed & individual brake pressure so I can monitor what the ECU/DSC is doing on the track
    I have the following mapped already, RPM, TPS, Steering, Engine temp, Oiltemp Brake, fuel level
    RPM ID 170 offset 4 length 2 signed little endian conversion raw x .25 / 1
    TPS ID 170 offset 2 length 2 unsigned little endian conversion raw x .00154 / 1
    Steering ID 196 offset 0 length 2 signed little endian conversion raw x -.04395 / 1
    brake pedal pressure id 414 offset 6 length 1 unsigned little endian no conversion needed
    oil temp ID 464 offset 1 length 1 unsigned little endian conversion raw + -48
    These should be available but I do not know the ID offset length and value
    wheel_spd_fr_lf
    wheel_spd_fr_rh
    wheel_spd_rr_lf
    wheel_spd_rr_rh
    clutch_switch
    brake_pr_fr_lf
    brake_pr_fr_rh
    brake_pr_rr_lf
    brake_pr_rr_rh
    temp_outside
    map
    gear
    Have you checked here:
    http://www.loopybunny.co.uk/CarPC/k_can.html
    Outside temp is 2CA
    I'd expect transmission gear to be on one of these
    0B5
    0BA
    1A2
    1D2
    304
    3B1
    Wheels speeds is 1A6. Think there is info in this thread on it.
  2. #127
    Mar 2019
    Lithuania
    E92
    Hi, I am thinking about e92 test rig also. I would like to try to flash firmware to modules with WinKFP at home. Would that be possible? Is firmware written through K-CAN bus?
    If I would buy FRM module attach K+DCAN cable, and connect other module to FRM updating firmware would work?
  3. #128
    Mar 2019
    Lithuania
    E92
    So I am joining the party. This is my test rig:
    Also I have STM32F091RC Nucleo microcontroller and MCP2551 transreceiver (for PT-CAN).
    As for K-CAN I read that it is low-speed and need TJA1054T transreceiver, I was wondering where I could get one, and found it in BMW professional radio:
    So I am planning to use it and solder wire on RX and TX pins. It should work?
    But for now I cant make CAN BUS work on PT-CAN with STM32F091RC and MCP2551, I bet my configuration of STM32 code could be bad:
    hcan.Instance = CAN;
    hcan.Init.Prescaler = 16;
    hcan.Init.Mode = CAN_MODE_NORMAL;
    hcan.Init.SyncJumpWidth = CAN_SJW_1TQ;
    hcan.Init.TimeSeg1 = CAN_BS1_4TQ;
    hcan.Init.TimeSeg2 = CAN_BS2_2TQ;
    hcan.Init.TimeTriggeredMode = DISABLE;
    hcan.Init.AutoBusOff = DISABLE;
    hcan.Init.AutoWakeUp = DISABLE;
    hcan.Init.AutoRetransmission = DISABLE;
    hcan.Init.ReceiveFifoLocked = DISABLE;
    hcan.Init.TransmitFifoPriority = DISABLE;
    Any one have any experience with STM32?
    I am getting zeroes when listening to PT-CAN/K-CAN:
    Any help would be appreciated.
  4. #129
    Mar 2019
    Lithuania
    E92
    So I was able to light KOMBI. But I did it through K-CAN with MCP2551 chip. I get many warnings and cant keep cluster on for long. Do I need to keep sending same command to keep KOMBI on?
    Also PT-CAN seems to be not responding, no messages nothing on it.
    I have connect MCP2551 to JBE pin 1 and 2:
    Do I need to shorten 6-43 and 42-5? Or there must be another module on PT-CAN that it would work?
  5. #130
    Aug 2018
    Ga, USA
    2002 BMW 530i
    Bought a cluster and got RPM and speed working. I have Brake, ABS lights but I'm assuming those need to be coded out since sending codes has no effect.
    I tried the values from the loopbunny website but I can't for the life of me, figure out how to get the needle to move.
    So far I have
    fuelLevelMsg.id = 0x349; //From ECU
    fuelLevelMsg.len =5;
    fuelLevelMsg.buf[0]= 0x76;
    fuelLevelMsg.buf[1]= 0x0F;
    fuelLevelMsg.buf[2]= 0xBE;
    fuelLevelMsg.buf[3]= 0x1A;
    fuelLevelMsg.buf[4]= 0;
    Can1.write(fuelLevelMsg);
    Am I missing something? Do I have to turn the Gas light off (using a resistor) before the value will change?
    UPDATE : Found a resistor and it did move and removed the Fuel light.
  6. #131
    Nov 2005
    Kilmarnock, VA
    Quote Originally Posted by Hakeem530i View Post
    So far I have
    Getting a cluster happy on the bench is like 10x times harder then trying to fake the car that there is a DME there when there isn't. There is a whole lot of messages that are coming from other modules that it is expecting. Simulating all those other modules is much harder than 1 DME. Just to put things in perspective for those looking just to do engine swaps in E9x cars.
    I'd suggest getting INPA connected and look at what errors the KOMBI is reporting and go from there. With the Red car on the lift the KOMBI is verry unhappy.
    Thaniel
    Quote Originally Posted by hotter View Post
    Looks like that may be for jumping terminating resistors. Does your PT-CAN bus resistance measure approximately 60 ohms (the physical layer standard for high speed CAN bus)?
  7. #132
    Aug 2018
    Ga, USA
    2002 BMW 530i
    Quote Originally Posted by Thaniel View Post
    Thaniel
    That makes sense. Need to take a look at a couple wiring diagrams and reread this thread. How do I go about getting INPA connected to the cluster? Is a DME needed to connect to INPA? Might just take that route and pick up a climate control unit as well.
    Edit : Found the wiring diagram https://www.newtis.info/tisv2/a/en/e60-530i-lim/YsZSur5. I'm using an e60 so I think it may be different. I'll look into it more when I get home
  8. #133
    Mar 2019
    Lithuania
    E92
    If I measure it it shows 2.4k ohms, which is way too much? I have connected only to pin 1 and 2:
    Also do you know how to get rid of those annoying errors on startup? I tried sending those errors as "OFF" (byte 3 as 0x30) flooding them but it does not seem to work it just keeps appearing.
    As for needles, I was able to move speed, RPM and gas needles. Any one knows how to move oil one? and cruise control?
  9. #134
    Aug 2018
    Ga, USA
    2002 BMW 530i
    I still have the errors. I assume we'll have to connect to the DME or figure out what's causing it. I don't think we can code off those messages if they're activated on their own. How did you get the fuel needle to move? I put in a resistor but it seems to be stuck on full.
  10. #135
    Nov 2005
    Kilmarnock, VA
    2.4K ohms is TOTALLY wrong for can bus terminating resistors
    Read this: https://embedclogic.com/can-protocol...hysical-layer/ And other articles like it. If the bus isn't happy you are in for never ending problems.
  11. #136
    Nov 2005
    Kilmarnock, VA
    You will need to connect a code reader (INPA for example) and get the codes before you can begin to discuss how to turn them off (feels like I said this before).
    Part of turning them off will be simulating more modules by sending more CAN messages or coding out some of the KOMBI options using something like NCS expert (I think that's what it was). Or a little of both. I'm not an NCS expert so cannot provide the details for how to code the KOMBI. But there are some people other places on the forum that are very good with coding modules.
  12. #137
    Mar 2019
    Lithuania
    E92
    Is it possible to move oil temperature needle? What message do I need to send?
  13. #138
    Nov 2005
    Kilmarnock, VA
    Don't know that needle isn't on my cluster. But try 0x1D0 the byte right after coolant temperature.
  14. #139
    Mar 2019
    Lithuania
    E92
    Indeed:
    TxMsg.Header.IDE = CAN_ID_STD;
    TxMsg.Header.RTR = CAN_RTR_DATA;
    TxMsg.Header.StdId = 0x1D0;
    TxMsg.Header.DLC = 8;
    TxMsg.Data[0] = 0x85;
    TxMsg.Data[1] = temp; //<-- oil temp
    TxMsg.Data[2] = 0x46;
    TxMsg.Data[3] = 0xC0;
    TxMsg.Data[4] = 0x4F;
    TxMsg.Data[5] = 0xC4;
    TxMsg.Data[6] = 0x0D;
    TxMsg.Data[7] = 0x90;
    It moved the needle but after like 2seconds of mooving it resets to default position and stops responding to 1D0 message. Is it because of cluster warnings I have or do I need to send it in specific interval? I am sending it every 100ms like terminal30 signal.
    Also maybe you know how to send washer fluid and coolant fluid levels?
  15. #140
    Feb 2020
    Los Angeles
    1988 BMW M3
    Just got a e90 335i cluster and I'm having trouble turning it on, T15 doesn't do anything. Verified with scope and logic analyzer / can sniffer that I'm sending valid data. Using STM32.
    Sending:
    DLC:5
    0x45 0x42 0x69 0x8F 0xE2
    10Hz
    Is the last byte counting or can it be constant?
    Message is not being ack'd by the KOMBI
  16. #141
    Mar 2019
    Lithuania
    E92
    Are you using full setup with JBBE? I noticed that KOMBI turns on when I plug OBD cable (I guess it wakes it up), otherwise it does not respond to T15. Maybe its because CAS module is not present in my setup.
  17. #142
    Feb 2020
    Los Angeles
    1988 BMW M3
    Got it turning on, but can’t seem to get rpm or oil temp to move. Anyone successful with that on a late 335i cluster?
    EDIT:
    got light, turnsignals, rpm, fuel, oil temp working, but RPM won't move and my error codes (brake, abs, traction control, airbag and seatbelt) come back a second after clearing them with a 0x592.
  18. #143
    Aug 2018
    Ga, USA
    2002 BMW 530i
    Quote Originally Posted by James134 View Post
    EDIT:
    How'd you get the oil temp and fuel? Think those were the only things I've had trouble with. What code are you using for RPM?
    Also, The error codes won't disappear unless they're coded out like Thaniel said above. Those codes can't be cleared via Canbus.
  19. #144
    Feb 2020
    Los Angeles
    1988 BMW M3
    oiltemp is [1] of 0x1D0, same formula as coolant temp.
    fuel according to loopbunny site.
    I was able to get rid of error messages, but only until I power cycled the cluster, they came back after. Can't seem to reproduce.
    Tried sending message according to loopbunny/thaniel's example in this thread, at 100Hz, but no success. RPM needle won't move.
    EDIT: Just saw in Thaniel's can sniff that C0 never reaches FF on Byte[0] it counts from F0 to FE. Ill try this and report back.
  20. #145
    Mar 2019
    Lithuania
    E92
    As for 0x130 terminal message it seems it is send on PT-CAN not on K-CAN. is it possible to send wake signal in K-CAN to wake cluster up?
  21. #146
    Aug 2018
    Ga, USA
    2002 BMW 530i
    I've been waking up the cluster using K-CAN with no issues. Think it's just a matter of changing the baudrate.
  22. #147
    Aug 2018
    Ga, USA
    2002 BMW 530i
    Try sending at 10ms. I remember having issues and didnt get it to work until I changed it to 10ms or something.
    Here's my code, I'm using a Teensy so yours might be different:
    static uint32_t s = millis();
    if(millis() - s > 10){
    rpmMsg.id = 0x0AA; //From ECU rpmMsg.len =8;
    rpmMsg.buf[0]= 0x6C;//0x5F;
    rpmMsg.buf[1]= 0x06;//0x59;
    rpmMsg.buf[2]= 0x28; //Throttle
    rpmMsg.buf[3]= 0xFE; //Throttle u
    rpmMsg.buf[4]= 0xD0; //RPM
    rpmMsg.buf[5]= 0X6B; //RPM
    rpmMsg.buf[6]= 0x94;
    rpmMsg.buf[7]= 0x00;
    Can2.write(rpmMsg)
  23. #148
    Feb 2020
    Los Angeles
    1988 BMW M3
    Thanks, I was sending at 100Hz (= 10ms). tried your message, no luck either, RPM needle is not moving.
    Still can't get rid of the ABS errors.
    Not sending 0x0C0 get's me a BRAKE, ABS, traction, and car on the lift error while the rest of the gauges are OK.
    When sending 0x0C0, I get the same errors as without but after like a second or two the Check engine light comes on additionally, and my oil temp gauge goes to minimum and stops responding.
    Sending 0x0C0 at 5Hz (200ms).
    I have a regular OBD usb cable for INPA etc., can this be connected directly to the cluster to clear/read faults?
    edit: attached 2 can sniffs (with and without 0x0c0) about 500msec each.
    Attached Files Attached Files
  24. #149
    Mar 2020
    Poland
    E70 2010
    Hi!
    I have front seats from E70 (I don't have this car) and I'm trying to run them without a car. The module have TJA1055. I'm sending a frame to him (0x130, 45 40 21 8F FE) via CAN but buttons on seat not working. VCC pin have 5V, EN and STB have high state, WAKE have +11V and ERROR pin have low state. Does anyone know what I'm doing wrong?
  25. #150
    Feb 2020
    Los Angeles
    1988 BMW M3
    Anyone got any leads on this? I just purchased a jbbfeII and cas but couldn’t get inpa to connect for some reason.
  1. E46 Can bus project.
    By Thaniel in forum Engine Conversions
    Last Post: 02-26-2024, 09:42 AM
  2. BMW Dual 3" Tip Peformance Muffler Exhuast E39 E46 E38 E90 E92 E36 E30 E60 E65 E66
    By BimmerKing12 in forum Engines, Performance Parts & Software
    Last Post: 11-28-2013, 06:45 AM
  3. BMW Dual 3" Tip Peformance Muffler Exhuast E39 E46 E38 E90 E92 E36 E30 E60 E64 E65
    By BMW112 in forum Engines, Performance Parts & Software
    Last Post: 08-20-2013, 05:44 PM
  4. FS: Brand new DIAGNOSTIC SCANNER E60 E63 E65 E87 E90
    By bumer325 in forum Engines, Performance Parts & Software
    Last Post: 07-07-2012, 05:03 PM
  5. CAN Bus IDs - Working for PC integration on E65!
    By xolmatic in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 02-14-2008, 08:06 PM
