Page 7 of 10 FirstFirst 12345678910 LastLast
Results 151 to 175 of 228
Thread: E90 Can bus project (E60, E65, E87....)
  1. #151
    Apr 2013
    Ireland
    2001 E39 , 1996 E36
    Would anyone know the message used to control the reversing lights in an E65? Thanks.
  2. #152
    Mar 2019
    Lithuania
    E92
    Hi, I am trying to understand CAN BUS message from 0x1D0 id, to see interesting information with Arduino. Maybe anyone know what are the meaning of these:
    So far I know the meaning and formula of these:
    Code:
    TEMP_EOI        Coolant temperature. (Byte[0] - 45 = temp in C)
    TEMP_ENG        Oil temperature. (Byte[1] - 45 = temp in C)
    ST_SW_WAUP      ???
    ST_RBMCYC       ???
    ST_END_RUN      ???
    RPM_IDLG_TAR    ???
    RDUC_DOCTR_RPM  ???
    OPMO_FU         ???
    IJV_FU          Amount of fuel injected (Byte[5] * 256 + Byte[4] = in microliter) ???
    CTR_SLCK        ???
    ALIV_COU_DME    ???
    AIP_ENG         Air intake pressure (790 + Byte[3] = in hPa) ???
  3. #153
    Jul 2016
    Westland, Mi
    E82 135i 2011
    ST_SW_WAUP - Software wake up.
    RPM_IDLG_TAR - Engine idle speed target.
    ALIV_COU_DME - Alive counter.
    Where did you get those labels from? Do you have more? DBC?
  4. #154
    Mar 2019
    Lithuania
    E92
    No I don't have more, found them in another forum, but no one has more there too, I would be interested to get more also. If anyone has more decoded KCAN messages please share. Would be nice to know how to get Air fuel ratio, oil level, coolant level, washer fluid level and other parameters on KCAN.
  5. #155
    May 2020
    NL,ECE
    E21,E30,E46,E60
    TerraPhantm,
    How did you get that table from Tool32? Which file did you use?
    Quote Originally Posted by TerraPhantm View Post
    Thaniel, I was digging through tool32 and found this table that seems to define what many of the various CAN IDs are for, and where they originate. Might be helpful
    Code:
    CAN_ID_DEZ    CAN_ID_HEX    CAN_ID_NAME    DIAG_ID_DEZ    DIAG_ID_HEX    SG_NAME
    0    0x00    unbekannt    0    0x00    Sender unbekannt
    949    0x3B5    Status Wasserventil [6]    120    0x78    IHKA
    957    0x3BD    Status Verbraucherabschaltung [2]    114    0x72    KBM
    250    0xFA    Steuerung Fensterheber FAT [10]    0    0x0    KGM
  6. #156
    Sep 2012
    Toledo, OR
    1993 S13 1jz coupe
    I have an e82 135i I swapped with a 2jz and kept everything as factory as possible. I have a Link Fury ECU with the CAN Bus capability. Right now we streamed the can data for the bmw throttle pedal ( the data matched the E46 ) and now we are full e throttle with no cable and works amazing with the 2jz throttle body. Since we used the factory transmission so speed works fine on the cluster. So far we need to get proper data for AC RPM and Fuel. Right now fuel is full power on a switch wired from the Bus controller.
  7. #157
    Sep 2012
    Toledo, OR
    1993 S13 1jz coupe
  8. #158
    Mar 2016
    Australia
    e30 318i, 135i
    i'd like to find more info on which address the AFR is broadcast if anyone knows?
  9. #159
    Mar 2019
    Lithuania
    E92
    Does any one know what does K-CAN BUS message ID 0x332 (DME1/DDE1 - Fahreranzeige Drehzahlbereich = Driver display speed range) means?
    It seems that byte 0 value 0x79-0x83 moves M cluster dynamic red line:
    But what does it value mean?
  10. #160
    Mar 2019
    Lithuania
    E92
    Does any one know how to decode 0x1A6 message?
    It suppose to be "distance", but I am not sure what kind of units are used here and it seems to be strange value.
  11. #161
    Aug 2018
    Ga, USA
    2002 BMW 530i
    Quote Originally Posted by hotter View Post
    Does this help? http://www.loopybunny.co.uk/CarPC/can/1A6.html
  12. #162
    Mar 2019
    Lithuania
    E92
    Has anyone decoded DME messages? for example id 0x1B6 (Heat flow engine)
    Code:
    438     0x1B6   Wärmestrom Motor [11]   18      0x12    DME1/DDE1
    I suspect there could be air and exhaust temperatures?
  13. #163
    Mar 2019
    Lithuania
    E92
    Is there CAN message for BC button? Or its only passed directly to KOMBI not through CAN BUS?
  14. #164
    Aug 2020
    Italy
    2019 X1 18d
    No it is connected direct with pin 16 on the cluster connector: pin16 with 1K resistor to ground = BC button, pin 16 with 2K resistor to ground = UP, with 3K = DWN
    I have bought an E90 cluster too, and controlled with an Arduino Mega,I have switched off all alarm lights including electric steering that was enabled on my cluster;
    i'm able to control speed and rpm needle, fuel needle too but I'm searching for a CAN ID that control the MPG needle... Someone have found this ID?
    thanks in advance
  15. #165
    Mar 2019
    Lithuania
    E92
    How did you switched off all alarm lights?
    Its easy to control fuel needle, you need to sent message with id 0x349 every 200ms
  16. #166
    Aug 2020
    Italy
    2019 X1 18d
    I switched off airbag, abs, TCS and finally active steering light...there are no indication about it, I finally found the CAN ID 0x1FB looking in a E90 log on the web.
    I have controlled the fuel needle, but I want also to move the consumption needle on the right, I have seen in the BC that consumption remain all the time at 0.0Km/l
  17. #167
    Jul 2016
    Westland, Mi
    E82 135i 2011
    Before I start reverse engineer,.. do you guys have an idea if traction control state can be changed via CAN (same as pressing DTC button)?
    I know JB4 piggyback was able to do it, but I am not sure how it did it.
    It seems like it is n K-CAN, but also probably mirrored to PT-CAN. I am not sure at which ECU is the state of the button held though.
  18. #168
    Oct 2020
    cranston, RI
    2009 BMW 128i
    can we have some more info in the coolant temp tap. been looking for a way to monitor coolant temp in my e82.
  19. #169
    Jun 2003
    San Jose, CA
    '02 M Coupe, '12 C4 GTS
    I'm trying to do things the other way around; swapping an E90 powertrain into another vehicle. So far I have the JBE awake & the DDE powered up, and I'm seeing 0x130,c5,42,ff,ff,ff on the D-CAN at the OBD connector.
    When Protools tries to talk to the DDE (sends 0x6f1,...) there's no response. I'm wondering if my Terminal control message is wrong? I've been using Thaniel's 45,42,69,8F,E2 sequence, which has worked to keep JBE alive, and I'm seeing plenty of traffic on PT-CAN from the DDE, but obviously something is missing.
    I get the same result (i.e. no response from the DDE) if I leave the JBE out of the equation and just connect directly to the PT-CAN.
    '02 M Coupe
  20. #170
    Mar 2019
    Lithuania
    E92
    Quote Originally Posted by dzid26 View Post
    Its interesting that on this drawing its on K-CAN. I have also been looking into this feature, but it seems that its connected to JBBE directly and then goes to P-CAN. Not sure if its possible to trigger it from K-CAN. Maybe other know more?
    It might allow sending same message from K-CAN to F-CAN.
  21. #171
    Jun 2003
    San Jose, CA
    FWIW, I don't think the JBE is actually on F-CAN, it just passes it through between two connectors. I'm fairly sure I've identified all of the CAN transceivers on the board, and they're all spoken for (PT, D and K).
    '02 M Coupe
  22. #172
    Jun 2003
    San Jose, CA
    Still no luck getting the DDE to respond to 0x6f1, but I did find a trace with some real 0x130 messages in it. The last byte is not constant, it's actually two separate counters. The low nibble just counts 0...E, changing every message, and then rolls over. The high nibble is more complex; it also counts, but skips a different value based on the message. It's also offset differently based on the message, in a fashion that seems to be derived from the other bytes in the message (though I haven't worked out the derivation yet). The high nibble also changes every message, so for a given 0x130 message there are 15 possible values for the last byte.
    Based on the trace I analysed:
    // 41 42 21 0F off (steady state)
    // checksum base 2,0 high skip E
    // sequence 20 31 42 53 64 75 86 97 A8 B9 CA DB FC 0D 1E
    // 41 42 61 0F clutch depressed before starting
    // 41 42 61 1F starting (2x)
    // 55 42 69 2F starting (1x)
    // 55 42 69 6F starting (8x)
    // checksum base 9,E high skip A
    // 55 42 61 9F starting (2x)
    // 45 42 61 9F early running, clutch depressed (26x)
    // checksum base 4,0 high skip B
    // 45 42 61 8F running, clutch depressed
    // checksum base 3,0 high skip A
    // 45 42 21 8F running, clutch released
    // checksum base F,0 high skip 6
    // sequence F0 01 12 23 34 45 56 77 88 99 AA BB CC DD EE
    // 45 42 21 4F turning off (1x)
    // 45 42 29 6F turning off (3x)
    // 41 41 29 6F turning off (1x)
    // 41 42 21 5F turning off (2x)
    // 41 42 21 1F turning off (24x)
    // checksum base 3,0 high skip 1, F, double 3
    // 1 skip may be timer artifact, not enough samples?
    In the second last message (41 42 21 1F) the trace suggests that both 1 and F are skipped, and 3 shows up twice. There's only one record that looks like this, so I'm not sure what to make of it, but it's not a simple bitflip:
    130 4142211FEB
    130 4142211F0C
    130 4142211F2D
    130 4142211F3E
    130 4142211F30
    130 4142211F41
    '02 M Coupe
  23. #173
    Nov 2005
    Kilmarnock, VA
    E53, E90, Triumph GT6
    Quote Originally Posted by DrZiplok View Post
    Getting the DDE happy via CAN is difficult. If it were not then anyone could tap the CAN bus and simply drive the car away. There are a bunch of CRC's and Security information and the CAN message stream has to be perfect with all CRC's correct passed for the DME/DDE to be fully operational (the KOMBI doesn't care that much as turning it on is a low security issue). Best bet for an engine swap is doing some reprogramming/Tuning/immo delete of the DME/DDE.
    I've worked on some projects where people did modify the DME to get it to work in another car. But I only was involved in the data transmission of the CAN bus to make the gages and similar work so can't advise how it was done. More information likely can be found on BMW tuning forums.
    Thaniel
  24. #174
    Jun 2003
    San Jose, CA
    Quote Originally Posted by Thaniel View Post
    In this particular case, the DDE in question has had EWS disabled, so it will start as soon as the engine turns over (and the START wire is pulled high). I'm not trying to build a standalone EWS bypass device, that's more headache than I care for. 8)
    I reached out to the Bimmergeeks folks since it was their tool that was sending 0x6f1, and they cleared up my misconception - that ID is actually a query to the CAS, as they want to read the VIN and VO in order to identify the vehicle. I pulled the CAS & key reader from my donor vehicle and added it to the stack, removed my 0x130 generator, and whilst INPA is not entirely happy I can now scan the DDE and (so far as I can tell) talk to things "normally". I'm sidetracked reversing the flash protocol for another CAN device right now, but I will start documenting what I can see now that I have the CAS in the picture shortly, since ideally I'd like to be able to talk to the DDE without the CAS or JBE present.
    '02 M Coupe
  25. #175
    Jun 2003
    San Jose, CA
    So back at my "emulate the CAS enough to be able to diagnose / maintain the DDE standalone" project. I think I have a handle on most of what's going on as ProTool is scanning the car, and faking it should be pretty straightforward.
    While digging through this, I noticed that the VO returned by C_FA_LESEN is encoded in some fashion. I see mention of a FA_STREAM2STRUCT job that is supposed to do the decoding here, but searching turns up almost nothing. I don't actually need to know the VO, since I just need to cough it up when asked, but I assume *someone* must know how the encoding works...
    Since I managed not to find a description of how the tools talk to individual ECUs anywhere (and the loopybunny site's page on the subject isn't linked), here's what I've been able to work out so far.
    BMW assign specific CAN message IDs to ECUs for the purpose of addressing specific devices. There's a partial list on the loopybunny page, but I'll reproduce it here for the sake of searchability (and adjust it a bit)
    0x00 JBBF, Junction Box Module
    0x01 MRS, Airbag
    0x40 CAS. CAS ELV. car access sytem
    0x41 DWA, AntiTheft Alarm System.
    0x50 SINE, Siren And Tilt Sensor.
    0x56 FZD, functional roof sensor
    0x60 KOMBI, Intrument Cluster,
    0x64 PDC, Rear Parking Sensors
    0x72 FRM, Footwell module
    0x78 KLIMA, Climate control.
    0xef broadcast / all-call
    0xf1 D-CAN adapter
    Whenever a module is talking as part of one of these conversations, it uses the CAN ID that is 0x600 + the module ID. Conversations always start with a message from the D-CAN adapter (the test system), of the form:
    0x6f1: XX YY Z1 Z2 Z3 Z4 Z5 Z6
    XX = ID of the module being addressed
    YY = length in bytes of the command
    Z1-6 = command bytes
    These command bytes line up with the KWP2000 commands / subcommands listed in Tool32 jobs, which is awfully convenient.
    The response from the addressed module looks like:
    0x6XX: 0xf1 0x10 LL DD DD DD DD DD
    XX = ID of the module responding
    LL = total length of the response in bytes
    DD = first 5 bytes of the response, where the first YY bytes are the same as the command, except that the first byte has bit 0x40 set. Padded with 0xff if there are less than 5 bytes in the reply.
    If the response is 5 bytes or less, this is the end of the exchange. However if it's longer, the D-CAN probe will respond with:
    0x6f1: XX 0x30 0x00 0x01 0x00 0x00 0x00 0x00
    XX = ID of the module being asked to complete its response
    The addressed module will then deliver the remainder of its response, with a sequence of messages of the form:
    0x6XX: 0xf1 SS DD DD DD DD DD DD
    SS = sequence number, starts with 0x21 and counts up.
    DD = data bytes, padded with 0xff
    As an example, here is the probe reading the VIN from CAS:
    41 0:02.489.646 6f1 8 40 03 22 10 10 00 00 00 VIN read
    42 0:02.513.397 640 8 F1 10 14 62 10 10 57 42 “WB”
    43 0:02.514.073 6f1 8 40 30 00 01 00 00 00 00
    44 0:02.514.345 640 8 F1 21 41 50 4E 37 33 35 “APN735”
    45 0:02.516.107 640 8 F1 22 58 39 41 32 36 36 “X9A266”
    46 0:02.518.709 640 8 F1 23 33 38 36 FF FF FF “386”
    '02 M Coupe
  1. E46 Can bus project.
    By Thaniel in forum Engine Conversions
    Last Post: 02-26-2024, 09:42 AM
  2. BMW Dual 3" Tip Peformance Muffler Exhuast E39 E46 E38 E90 E92 E36 E30 E60 E65 E66
    By BimmerKing12 in forum Engines, Performance Parts & Software
    Last Post: 11-28-2013, 06:45 AM
  3. BMW Dual 3" Tip Peformance Muffler Exhuast E39 E46 E38 E90 E92 E36 E30 E60 E64 E65
    By BMW112 in forum Engines, Performance Parts & Software
    Last Post: 08-20-2013, 05:44 PM
  4. FS: Brand new DIAGNOSTIC SCANNER E60 E63 E65 E87 E90
    By bumer325 in forum Engines, Performance Parts & Software
    Last Post: 07-07-2012, 05:03 PM
  5. CAN Bus IDs - Working for PC integration on E65!
    By xolmatic in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 02-14-2008, 08:06 PM
