Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 98
Thread: E39 Touring 6speed Build
  1. #51
    Jul 2006
    burnaby b.c
    1998 328is 1999 540iT
    Think you have some incorrect understandings about how some things cause other things, and how yet other things work.
    Yeah wearing the tires out has zero.zero to do with the SLS.
    And bags don't change spring rate from 'wearing out' like a spring does, they just start to crack and leak overnight.
    Danny is 100% right about what causes the rear tires to wear pre-match.
    But just go throw parts and bling at it. That's more fun anyway.
    Also, get off of my lawn, you can't have your ball back.
    i understand, maybe I should’ve made it a bit more clear on what’s going on... lol
    reason for the SLS delete is cause I have swifts springs in a box waiting for install, and cause I’m currently rubbing. My wheel fitment and tire size is a bit to aggressive to keep the SLS as the ride is 100x softer than the front. I’m currently running 18x10.5+15 with 275s all around. The only way I was able to make these wheels work was -3.7* of Camber and the shop barely got it the toe to zero. The tears are pulled and I already flattened then lip. So With a stiffer spring rate (21k) I will be able to elimanate the rubbing as it only rubs on hard dips which is from a softer spring rate, it’ll be a lot cheaper then buying new bags as my springs came with my coilovers.
    I do know the balljoints and bushing wear down the tires and will ultimately effect my alignment. And it is part of my plan to refresh the rear end as the mileage is getting up there and it sitting in a garage for 9year with the bags completely out of air probably didn’t help also.
    I wish i had had the money to bling out lol.
    95 318is - m52 powered, 97 328is - M-package, ​01 540iT/6speed
  2. #52
    ca
    e39
    Just a heads up, on many if not all driver side headlights the factory mounting points are crooked and the replacement projectors sit a little clockwise. Not sure if your setup shows this but I was running Evo2s with CBIs and custom 43w Hella ballast for a bit, hated them and now have replaced them with some modded RX330s. Some people don't notice or don't care but for optimal results the projector should be clocked properly this will give you better visibility and also keep blinding oncoming traffic to a minimum.
    Here is what the crooked output looks like...
  3. #53
    Nov 2010
    Charlotte, NC
    03 M5/05 RR/06 Cayman S
    Quote Originally Posted by ucsbwsr View Post
    I use the Hella G4 Bi-Xenon reps in mine and they are level and the bolt holes line up well.
    -Paul
    2003 "M5" - Full M5 conversion, AMG C63S 6 piston front calipers, Porsche Panamera 4 piston rear calipers, GC Coilovers,
    Eibach ARBs, UUC Evo3/DSSR, Borla Exhaust w/Muffler Delete, BMW NBT with Carplay/Android Auto, Bi-Xenons, e38 Style 37 M-Pars, e60 Hubs 530i 6-speed swap build thread
    2005 Range Rover 4.6is (M62TU Powered) - 4.6is Engine Swap from X5, BMW NBT with Carplay/Android Auto
  4. #54
    Jan 2015
    Tempe, AZ
    1995 525i/5
    I definitely need to adjust my headlights. The pair I have came from different cars so they're all over the place. Is there a guide on how to adjust them properly?
    1995 525i 5-speed - Thread
  5. #55
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    Hey Paul, on those BiXenon reps, you know how they stick in about 3/8 of an inch., what do you think about swapping out the metal bracket that holds the lens to move the lens closer to where its supposed to be, like the stock lens is. The result should just widen out the beam a little bit, right?
    Good idea? Bad idea?
  6. #56
    Nov 2010
    Charlotte, NC
    Quote Originally Posted by BimmrMeUpSnotty View Post
    The problem is the studs. They don't have threads deep enough on them. I don't even see it as a problem. They work perfect for me and I bet only people that have installed them would notice.
    -Paul
  7. #57
    ca
    e39
    Quote Originally Posted by dannyzabolotny View Post
    You bet, here is a guide I created for the Tesla Model S but it can be used for the the E39 as well since they have projectors which reside at similar heights.
    https://www.facebook.com/VisionAutoL...58985871053127
  8. #58
    Jul 2006
    burnaby b.c
    Quote Originally Posted by blackknight530i View Post
    I Ended up selling the set to a buddy, wasnt that a big a deal when they got installed.
  9. #59
    Jul 2006
    burnaby b.c
    Was able to put some time in today,
    Installed Airpump
    Installed new front liners
    Installed new Driver Strut
    Mounted the 18s back on
    Installed new Metal M-sport Brake Ducts
    Polished/buffed my new M5 aluminum Trim
  10. #60
    Jul 2006
    burnaby b.c
    raise the car up a bit to save these new fender liners, deleted SLS and got a Alignment
  11. #61
    ca
    e39
    We are going to need more photos. Please.
  12. #62
    Jul 2006
    burnaby b.c
    slight update.
    took the Wagon to a AutoX event last month.. and it was a blast till my drive home.
    Fuel pump failed, then after it was fixed the following day my power steering pump mount ears broke!
    so in the last week or so i've done the following: New OEM PS pump, new resv, expansion tank, new rad hose, coolant flush, spark plugs, got some Front Diff mounting bolts with the revision for the bolt so i can finally install my M5 Chassis reinforcements
  13. #63
    Jul 2006
    burnaby b.c
    From the other day at Cars and Coffee.
  14. #64
    Feb 2014
    Alexandria, VA
    Only one car showed up?
  15. #65
    Jul 2006
    burnaby b.c
    Hahaha naw, showed up 30min early they didn’t let anyone in the parking lot.
  16. #66
    Jul 2006
    burnaby b.c
    huge update since i last posted here, figured id update what I've been up to with the wagon.
    -Mtech bumpers
    -E38 Sport seats
    -Black Headliner
    -4.8is Cluster converted to M5 black face from FIXELS
    -powerdyne Supercharger off a E34 M60( I modified the original metal bracket)
    -Euro Tail lights
    -M5 rep mirrors
    -front control/trust arms
    Things im waiting to install this coming week:
    N62 TB
    Ecumaster DET3
    and bigger injectors
    hoping to have the wagon at the dyno in a few weeks.
  17. #67
    ca
    e39
    More pics! K, thanks.
  18. #68
    Jul 2006
    burnaby b.c
    Finished a few more things before i drove it to the shop to get the wiring all done for DET3 and dyno tuning.
    but first stop MCD for some coffee and a shot of my E53 4.8is cluster that Fixels coded and installed black M5 faces ( Need new DSC/ABS module )
    while wire was getting done i mounted some new winter tires on my summer rims.
  19. #69
    Nov 2010
    Charlotte, NC
    Quote Originally Posted by karies View Post
    Love it. Thanks for the Fixels shout out
    Sent from my SM-G988U using Tapatalk
    -Paul
  20. #70
    Jul 2006
    burnaby b.c
    of course!! Honestly without your help I’d still be rocking broken boring stock 540i cluster lol
  21. #71
    West Coast
    two 3's one 5 three 7's
    Cars lookin mighty fine and has quite the mod list - very nice!
    I’m not familiar with your aftermarket ECU setup, so bare with my questions if you please - is there a reason why you didn’t dyno tune the factory ME7.2 DME?
    More boost related tuning options by going aftermarket?
    Will you still have 100% factory functionality to read codes, communicate with all of the other modules of the car, etc...?
  22. #72
    Jul 2006
    burnaby b.c
    Quote Originally Posted by whiteghost1 View Post
    glad to awnser, the unit I’m adding is a piggyback system that taps into the factory 7.2me and lets me control afr and timing in the fly also it has a built in 4bar map if I decide to remove the factory maf and run alpha N style. I still keep all factory functionalities as all I tap into is the maf/crank sensor and iat. I was thinking of doing flash tunes but with my turbo’d E36 i had a flash and it was just a pain waiting for reflashes and if it’s not right again you wait again. So this way I rent the dyno one time and have my local tuner take care of it.
    I’m currently using their standalone in my e36 and have seen a few m62tu sc in Europe running the det3 with good results.
    I have contacted dudmd he flashed some items for me so I won’t have cel in the future as I got him to delete Sap/rear o2s/limiter increase/speed limiter and idle bump.
  23. #73
    Jul 2006
    burnaby b.c
    Just a little teaser..
    Got the det3 working with the stock dme and swapped 34lbs injectors and hoping to do some tuning tomorrow night.
  24. #74
    IL
    2000 740i sport
    Subscribed
  25. #75
    Jul 2006
    burnaby b.c
    Well bit of an update..
    Car made 300whp and 300lbs torq @ 5psi was on the dyno for about 4 hours. (Mustang dyno)
    Drove it around after car was quick, on my drive home it started to miss fire... I got home and I scanned the car and I Got the code p0011 means chain guides. Car ran great and still runs and drives but not going to take the chance on hurting the motor since it’s not making any noise at the moment.
    Sooo I was already prepared for this!! I have a spare motor I pulled out of my Msport parts car roughly same KM’s but with brand new guides and chain.
    I will be re sealing the motor as it looks like the guy used silicone to seal it up.
    Power washer the motor.
    And since the motor is out I will decatting the headers or will be installing M60 non cat headers.
  1. lq9 in e39 touring build
    By hkssupra in forum Engine Conversions
    Last Post: 11-30-2020, 11:02 AM
  2. Replies: 49
    Last Post: 02-28-2014, 06:08 PM
  3. E39 e39 Touring Celis Tails OE
    By Mad Dog 20/20 in forum Exterior Lighting & Body Parts
    Last Post: 05-18-2008, 08:49 PM
  4. WTB: e39 Touring 6speed
    By AlpineOverNappa in forum 5 series & 6 series
    Last Post: 01-10-2008, 08:21 PM
  5. E39 Euro Tails for e39 Touring
    Last Post: 12-14-2007, 02:47 PM
