Page 1 of 4 1234 LastLast
Results 1 to 25 of 98
Thread: E39 Touring 6speed Build
    Jul 2006
    burnaby b.c
    1998 328is 1999 540iT
    Well i don't really post here that often, so i decided to make a build thread on the touring i just picked up.
    This is my second 540it, the first one i bought last year for a great price but was rusty but made a decent daily. Couple months ago timing guides went, planned on fixing the guides and doing a 6speed swap in the process. Until i found my new touring sitting in a garage for the past 7 years. it has a blown transmission and needed a wash bad, so decided to sell the red touring and put the 6speed swap in the new touring.
    my first E39 few months later: Dsp delete, M5 bumper, HR Front race springs, E38 Mpars, M5 2001+ headlights , Pioneer Double Din Navi,3k HID fogs, Facelifted Black grills , X5 Roof rack bars
    The 6Speed Donor car: 1997 540i - blown Guides
    And now the New Touring: 2001 540iT Aspen Silver on black , single owner, Dealer serviced, no reverse, gloss Shadow Trim, Style 32's, sport suspension
    After 3 washes , and a complete interior Clean
    Things i've already ordered:
    UUC Selector rod
    E60 short shifter
    Maintaince parts
    M5 bumper
    Hartage Replica Lip
    manual Pedal set
    throw out bearing
    Gaskets and seals for the Transmission
    This will be my first Auto - Manual Swap as all my cars have all been manual but this isn't my first project.
    95 318is - m52 powered, 97 328is - M-package, ​01 540iT/6speed
    Oct 2012
    Atlanta, GA
    2000 528iT 5MT
    Whoa. Love the build.
    I just picked up a manual E39 touring in Aspen Silver after owning an automatic 2.8 touring for a couple years. Beggers can't be choosers for a manual wagon, so I'm not sure if it would have been my first color choice, but it's grown on me now I love it. The color is all over the place depending on the light: silver, purple, grey, beige, brown. Definitely a 90's color, but it's a 90's wagon, and I like the 90's.
    Want to get Style 32's as well. Fit the color perfectly I think. My suspension will be done within the year and within a couple years want to supercharge.
    Mar 2014
    San Diego, CA
    09 Rx8 R3
    Looks great! Aspen Silver is one of my favorite colors on these cars. Huge fan of the style 32 wheels too. They are a close second to the style 65's.. and mulled over which to get for a long long time.
    Jul 2006
    burnaby b.c
    Quote Originally Posted by Shiftless View Post
    Thanks! yeah when i got the phone call he said purple.... so i was scared to take a look until i showed up. Its like my Red wagon i didnt like the color for awhile now im going to miss it lol
    Quote Originally Posted by speed7 View Post
    Each day i look at it i like the color more and more, the 32's are just a classic 90s wheel and one of my favorites.
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Nice! Slip a bunch of stuff from your red car over too I assume is the plan (respray bumper, springs, wheels, etc.?)
    You've read my coding wiring conversion checklist write-up yes?
    You can re-use some of the pedal parts from the pre-face donor but not all. You have to decide which style of pedal switches to go with as well. The donor will have big old fashion physical switches but the facelift would normally have the hall-sensor style that clips to the clutch master.
    At this point all the info is public w/ plenty of success stories so should be smooth sailing and you've got plenty of help around here between me and blackknight and redshift etc if you run into questions or issues just post it up...
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Jul 2006
    burnaby b.c
    Thanks! im actually not pulling anything from the red car, i ordered a M bumper and for suspension i was thinking something with more adjustability.
    I've read it atleast 10 times now hahah , im using the original pedal bracket off the new car as the 99 still have the revision for the old DBW gas pedal.
    Left is the new set-up, removed the Auto-brake lever installed the new face-lift Brake lever then swapped all clutch pedal assembly from the donor car. Now im just waiting on the new Clutch master and a new Return spring.
    im just waiting on a few more items to arrive then i can slowly start swapping the transmission. if i have any issues i will post them
    Jul 2006
    burnaby b.c
    no updates, just cleaned the transmission. put new bushings not he shifter Arm
    But now i have a question I've been trying to search for the awnser but i can't find anything. i have a Post style pedal and clutch, now my parts car was a Pre is there a way i can use the Pre clutch sensor for the cruise control? as i will be not be using the starter lock option. Or will i need to buy the Post sensor and wiring just the one for the cruise control?
    Nov 2010
    Charlotte, NC
    03 M5/05 RR/06 Cayman S
    The later switch does both start interlock and cruise cutout. It's super easy to wire in the start interlock since you just take the wire from the clutch switch module and go to pin 8 on the EWS. That's it and they're right next to each other. The cruise cutout and reverse switch wiring to the cluster are the only "new" wires that need to be run in the cabin. I repurpose the two steptronic shifter wires that went to the now gone EGS so I don't have to run new wires through the firewall. I then extend them from the shifter area to the cluster and pedal as required. I use the new style clutch master cylinder with the new type switch and get the adapter wire harness and modify it to work for me.
    -Paul
    2003 "M5" - Full M5 conversion, AMG C63S 6 piston front calipers, Porsche Panamera 4 piston rear calipers, GC Coilovers,
    Eibach ARBs, UUC Evo3/DSSR, Borla Exhaust w/Muffler Delete, BMW NBT with Carplay/Android Auto, Bi-Xenons, e38 Style 37 M-Pars, e60 Hubs 530i 6-speed swap build thread
    2005 Range Rover 4.6is (M62TU Powered) - 4.6is Engine Swap from X5, BMW NBT with Carplay/Android Auto
    Jul 2006
    burnaby b.c
    Quote Originally Posted by blackknight530i View Post
    Thats what i was thinking of getting the newer sensor. but i was thinking of cutting some cost on the build anywhere i can. as i have the older style and the bracket but not sure if the way the ECU reads is different per sensor.
    cause i don't need the start interlock, i never liked the option.
    Nov 2010
    Charlotte, NC
    The way the DME reads the signals is identical between old and new. The new switch is a replacement for the old one.
    Sent from my SM-N910V using Tapatalk
    -Paul
    Jul 2006
    burnaby b.c
    alright thats perfect. I will use the old style clutch switch. Thanks!!
    Mar 2010
    Quote Originally Posted by karies View Post
    thats a USA-are-too-stupid feature anyway. Rest of World didnt get it because they were trusted not to start the car in gear like idiots.
    2003 M3CicM6 TiAg
    Former:
    Nov 2010
    Charlotte, NC
    While that may be true, it's easy to hook up if you use the new switch module and it doesn't hurt to have it. The only thing I would miss by having it hooked up is that I typically leave the car out of gear with the parking brake engaged in my garage and occasionally, I like to be able to start the car from outside the car while diagnosing something. Other than that, I'm pretty much always pushing the clutch in to start the car out of habit, so I don't really see it being an issue. I've actually wired it up on my cars, but I've left the coding set to disable the start-interlock because I'm lazy .
    -Paul
    Jul 2006
    burnaby b.c
    thats one thing i didn't like when working on the car, having to hop in and out to start the car. lol plus non of my cars ever had the clutch start option.
    mounted the Mpars, now time to wait for the dealer order and ECS order. a lot of the stuff are coming from Germany.
    i was missing a lot of the clutch pedal hardware since nothing really was transferable from the Pre pedal.
    Jul 2006
    burnaby b.c
    So decided i wanted a different look for this Touring found these wheels this morning. was nearly free
    Jul 2006
    burnaby b.c
    sorry for the lack of progress been busy with work and school, but today finally got the chance to do the 6speed conversion on my wagon. Total time in and out was roughly 8 hours.
    no coding but i was able to bypass the wiring on the transmission harness, i don't get any transmission fail errors and also used a PAsoft to change the cluster to manual.
    all thats left is wiring in the clutch pedal sensor, reverse lights and also proper coding. but in the mean time the car drives great.
    Mar 2010
    another conversion to add to the roll call list..! I think I'm missing more and more cars on that list now...
    nice. if you haven't reflashed the DME there's no doubt it's not running optimally, and must be throwing a bunch of codes behind the scenes for not seeing the tranny computer - a few guys have hacked around coding on these conversions but if you prod and ask the right questions, their cars are never 'right' - but there's something to be said for at least being able to move it around and drive it.
    2003 M3CicM6 TiAg
    Former:
    Jul 2006
    burnaby b.c
    I'll be doing a reflash and tune at the same time, the cars been sitting for over 5 years so it's still on old gas , plugs , filter . it needs a good tune up. I'm just glad I was able to start it right up after a few jumper pins.
    but yah the car feels nice with the 6speed. the weight loss is noticeable.
    Oct 2012
    Atlanta, GA
    2000 528iT 5MT
    Dude! So rare for someone to say they're going to do this swap and it's not just talk.
    You made it seems so easy...
    Jul 2006
    burnaby b.c
    Lol, Thanks man. The conversion is actually pretty easy.
    well picked up some staggered 32's that need refinishing and ended selling me the spare aswell, so now i have 10 style32's Lol
    Mar 2010
    Tell me about it. You wouldn't believe how many guys PM or email me about these swaps and then fizzle out.
    2003 M3CicM6 TiAg
    Former:
    Nov 2010
    Charlotte, NC
    For sure, same here.
    -Paul
    Jul 2006
    burnaby b.c
    Oh man, im sure alot of people probably opened my thread and was like Right..... another one lol
    only issue i had was finding the time to do the swap. ill keep updating the thread.
    up next is sound system, suspension, waiting for my M5 bumper.
    Mar 2010
    Oh man, im sure alot of people probably opened my thread and was like Right..... another one lol .
    Ha ha indeed but well done and welcome to the club of finishers!
    Can I suggest a blower next? I promise you'll like it.
    2003 M3CicM6 TiAg
    Former:
    Jan 2015
    Tempe, AZ
    1995 525i/5
    Haha you can add me to the list of people that have thought about it and not done it. Though in my defense, the reason I didn't do a touring 6-speed swap is because I managed to find a real M5 for less than most facelift 540i wagons haha
    1995 525i 5-speed - Thread
  1. lq9 in e39 touring build
    By hkssupra in forum Engine Conversions
    Last Post: 11-30-2020, 11:02 AM
  2. Replies: 49
    Last Post: 02-28-2014, 06:08 PM
  3. E39 e39 Touring Celis Tails OE
    By Mad Dog 20/20 in forum Exterior Lighting & Body Parts
    Last Post: 05-18-2008, 08:49 PM
  4. WTB: e39 Touring 6speed
    By AlpineOverNappa in forum 5 series & 6 series
    Last Post: 01-10-2008, 08:21 PM
  5. E39 Euro Tails for e39 Touring
    Last Post: 12-14-2007, 02:47 PM
