Originally Posted by
DennisCooper
Hi,
You can't just put on a taller profile tyre as it'll mess up the rolling radius and the car will perhaps go into limp mode. You need to keep within 3% of the OEM rolling radius. If you wish to reduce wheel arch gap to the top of the tyre the only option is to lower the car, which you say you don't want to do. If you *absolutely* won't lower, then there's nothing you can do to reduce that gap.
If you are out of work and broke currently, live with the car as it is and once you are working again, then perhaps look to purchasing high quality springs which will give a very compliant ride and lower the car perhaps 20-30mm, brands like H&R, Eibach and others do products which are excellent. Avoid the budget choices as the risk of a less compliant ride is higher as there's not nearly as much R&D that goes into those.
Cheers, Dennis!
