Page 6 of 6 FirstFirst 123456
Results 126 to 134 of 134
Thread: Need BF.C's collective help on my rattle issue
  1. #126
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Quote Originally Posted by jakermac View Post
    I don't mean to demean anything being said here, just relate my own experience. My cam to cam chain was a brand new Iwis chain when I built the engine. The noise was present from the 1st start-up.
    Yup. I replaced all that stuff in my old engine. Didn't fix it...
  2. #127
    Aug 2008
    Calgary, Ab
    E30
    Quote Originally Posted by NOTORIOUS VR View Post
    Well this is encouraging!
    Can I ask which chain you're speaking of? I'm assuming just the chain between the cams and not the one from the crank since that would require removal of the head to get the front cover off.
    I might just bite the bullet and order up these parts as well.
    Yes just the cam to cam chain. I installed a new main timing chain and guides when I built the motor.
  3. #128
    Toronto, Canada
    E36 Turbo
    ah alright, I did all the chains and lower guides when I built my motor as well.
    I'm happy that you were able to solve the issue. Were you able to see any order of abnormal wear on the parts you changed out that might have caused the noise?
  4. #129
    Sep 2002
    USA
    BMWs
    FWIW I did all IWIS master-less chains w/ new guides/tensioners/etc. on my engine when I built it. I think the only thing I didn't replace was the sprockets. I did put on a new crank sprocket, though.
  5. #130
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by 5mall5nail5 View Post
    When you got the new crank sprocket, did it reference (front/rear)?
    I found out the hard way on front and rear of that sprocket. Very tough to tell, only small recess. Get it wrong, chain won't fit.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  6. #131
    Aug 2008
    Calgary, Ab
    E30
    Nothing I could see just by looking at them or putting them together to compare. Teeth were not pointy, sharp or worn badly. There was some wear on the thrust washers from the spring plate but that's normal from what I've seen. Nothing really stood out that would make me say it was the cause of the problem. I was surprised when I fired it up and the noise was gone, I honestly figured I spent a bunch of money for nothing.
  7. #132
    Sep 2002
    USA
    BMWs
    I don't remember off hand but it fit fine and the chain lines up fine. Just a rattle, only when the car is warmed up, at light throttle around 3000 RPM. Going more than 5% throttle or 0% throttle makes it go away. I'll tear the engine down some day to check it out.
  8. #133
    Nov 2011
    Gaithersburg, MD
    86 528e B35/5spd Swap
    Bringing this thread up.
    Did anyone successfully diagnosed this 3k low load rpm falling rattle noise?
  9. #134
    Toronto, Canada
    E36 Turbo
    Quote Originally Posted by smhheidari View Post
    Nope... still there... still annoying and shitty sounding
  1. Need help on my H&R coilover!
    By DINAN COSMOS in forum 1992 - 1999 M3 (E36)
    Last Post: 08-17-2010, 10:50 PM
  2. Replies: 1
    Last Post: 08-29-2005, 06:52 AM
  3. Need help on my dream coupe
    By yofreeze in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-15-2005, 10:58 PM
  4. need help on my car!
    By mastermind in forum 1991 - 1999 (E36)
    Last Post: 03-24-2005, 12:30 AM
  5. Need help on my 1995 740i
    By BMW740i in forum 1995 - 2001 (E38)
    Last Post: 01-28-2004, 09:24 AM
