1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
I'd change out the intake helical gear as well, it contributes to the backlash.
Sent from my GTX3582R
Well crap. If it atleast quiets the noise down I'll be happy.
You guys all running vanos cyl heads?
Update:
Slow day in the shop so I was able to wrench on the e30. Installed new cam sprockets, chain, chain guide, splined shaft, spring plate and all thrust washers.
Noise is gone!!!
Only thing I noticed when reinstalling was the new chain is a lot tighter then the old one, other than that I couldn't see anything major wrong with the old parts that would cause the noise.
Possibly the old chain was over stretched and the upper tensioner couldn't keep it tight enough??
Anyways I'm happy I didn't spend a bunch of money for nothing.
Well this is encouraging!
Can I ask which chain you're speaking of? I'm assuming just the chain between the cams and not the one from the crank since that would require removal of the head to get the front cover off.
I might just bite the bullet and order up these parts as well.
