I have a gravely noise but only at idle. Pretty sure the sound is coming from the VANOS area, but it goes away when I bring up the rpms. My VANOS is rebuilt with the BEISAN but has no Belleville spring washer, so I figured it is probably related to that. The main chain tensioner is the later M3 unit.
1989 E30 - M50B28 Turbo - ZF 8 Speed
So mine still does it. Chikinhed's weld up of my timing cover certainly fixed that for me, and I had to replace the right side chain guide which had been smashed into little bits and was in the oil pan along with the upper guide pin which had obviously vibrated loose at some point and also dropped into the pan. But replacing all those parts and restoring the timing chain environment did not correct my "death rattle". I have had that noise for about 17,000 miles now (a little over 2 years) on my built NA motor that sees 7,800 in the lower gears from time to time.
I replaced all the Vanos bits (new intake chain sprocket, new camshaft gear, rebuilt a different Vanos unit with anti rattle spring and new bearing sanded to size) and none of this resolved it. When I put a stethoscope to the motor, the noise is loudest right on the Vanos solenoid and the valve cover nuts closest to the Vanos intake area. As soon as I move away from that area, the noise more or less vanishes (with the stethoscope). I have welded/reground cams from Web and then thought that might be doing it. I also had "wonky" cam timing so thought that might be the case. I have since reset the cam timing to something more reasonable, noise still there.
However, I DO have Supertech springs, 1mm over valves and retainers. I do not know what weight springs they are as I bought the head used with the parts already installed. I wonder if that is the "key"? Springs too stiff?
I'd say it's probably the stiffer springs resonant frequency at that rpm range and the backlash of the three Vanos gears.
I noticed an increase in noise after installing the 85 lb Supertechs in my engine. I too swapped in new gears, Vanos and tensioners with only a minor change to the rattle. Jaker's rattle is much louder than mine, maybe the aluminum block amplifies it?
Sent from my GTX3582R
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Any chance the wrong primary tensioner is being used? There are a few variations and I think the M3 version has a different PN.
There is also a specific torque spec for the shim plate stack. Not sure everyone is using a 1/4 drive torque wrench to get an accurate result there. Those stud nuts get blue loctite.
In all fairness, that 3rd video was taken while the right side timing chain guide sat in the oil pan in a hundred pieces so that was quite a bit louder than the actual original problem that surfaced in 1st start up after the engine build. And as Chikinhed mentioned, my block is aluminum so the sounds/resonances are probably different/louder.
I know. I was responding to some people who think it is.
The some people that think it might be, have been around the block for some time.
Supertech springs are way tighter than stock. When those valves are closing, they are slamming shut when that cam lobe allows them too.
Although I haven't heard his noise, mine has surely gotten louder after the head was built.
1996 332IS
Built 3.2
1996 332IS
Built 3.2
I'm starting to think it's more and more likely that the force on the closing ramp of the cams is causing a torsional resonance in the cam and the sound is coming from the lash between the vanos splines.
Do you feel anything when you put your hand on the front of the valve cover? That engine almost sounds like a damn M20! Also, I know we are diving into valve springs and what not, but I would also make sure that everything is bolted down around that general area....any bolts missing? Fuel rail bolted down? Spark plugs torque'd?
1997 Arctic Silver/Black M3
1999 Techno Violet/Dove M3
Yes you can feel and hear the rattle/noise on the front of the VC.
I know it's hard to understand someone explaining these types of noises over the internet... But the noise is constrained to the front of the intake cam/vanos area as best I can tell. Something there is rattling... chain, VANOS shims/spring, VANOS, mesh gear, tensioner... something...
And the more and more I realize that the way my car runs changes with the noise and temps, etc... verifies it's something with the cam(s).
Unfortunately all the VANOS parts are quite expensive and I hate just "throwing darts" and parts at something I don't understand. I'm just not sure what else there is to do about it.
I'm still seriously considering to cut open a spare VC so I can watch what's going on in there while it's running.
^^Thatd be super cool
Can you record a video of the sound your car is making Notorious? I'm curious if it's similar to my noise. I'd post one of mine but I'm currently not running.
I have this as well, idle-2.5k rattles when warm and it's annoying as heck, especially on a 12k mile rebuilt engine!! Rebuild my vanos twice and have another low mileage vanos unit + newer style gear plate/shim waiting to go on.
Maybe I missed it but are your timing/vanos chains new? I'm thinking in my case the 220k mile (overall) chains may have stretched and I should probably get new ones.
1995 325i | OBD1 S52 | S50 cams | AA Turbo TD06 20g / 42lb / Porsche maf | .140 MLS | F1 s3 clutch | Ultimate SSK | AKG 75D subframe/diff bushings | 3.23 LSD | Powerflex LCAB/RTAB | e46 fca | Raceland coils | BMP rear arms | DEPO HID | AEM Failsafe | Aeromotive FPR | Walbo 255 | 3" Magnaflow muffler/cat/res | 17x8.5/9.5" 225/45 & 255/40
