Page 2 of 6 FirstFirst 123456 LastLast
Results 26 to 50 of 134
Thread: Need BF.C's collective help on my rattle issue
  1. #26
    Jan 2014
    Tacoma, WA
    Estoril Mcoupe
    Quote Originally Posted by NOTORIOUS VR View Post
    6 cyl problems... Am I right?
    Interesting point of view... although I have to wonder why it just decided not to mesh one day but was fine for thousands of KM before?
    Could be new parts seating into the old parts and just not meshing. Could be a miscalculated shim. Might need reshimming.
  2. #27
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    Shimming what?
  3. #28
    Manchester, N.H.
    96 332IS 6466 turbo
    Maybe the noise the the valves slamming shut with those super duper heavy springs.
    Just maybe.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  4. #29
    milKt's Avatar
    Just maybe.
    only at the front?
  5. #30
    Toronto, Canada
    E36 Turbo
    Quote Originally Posted by milKt View Post
    Shimming what?
    Nothing is shimmed so not sure what he means by it either.
    Just maybe.
    Maybe I should do the valve spring delete mod?
  6. #31
    Apr 2006
    Minnesota eh?
    86 325es
    The valves will still be riding the closing ramp of the cam but that is an interesting thought. If you ever turn a cam by hand in the motor with no chain installed the cam will force itself to turn every 60 degrees as one pair of springs pushes on the cam lobes. I wonder if at certain rpm's the cam is accelerating slightly and putting slack in the vanos gears and then taking it up again. Kind of like trans gear rattle with a lightweight flywheel. This seams astronomically unlikely to me. But if I read the OP correctly it was the only thing changed when the noise started.
  7. #32
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    I helped a friend with an s50 cam swap, engine was quiet before and after had the same exact noise you are describing, you could out your hand on the front of the valve cover where the chains are and you would've thought the chains were touching the valve cover, after many "vanos rebuilds" he brings it to a local guy who is pretty well versed in bmw's, told him he needed the anti rattle shim for the intake cam, and the 3 or 4 wearable parts ofof the vanos system, engine quiet now.
  8. #33
    Sep 2002
    USA
    BMWs
    Have a rattle in my engine too - not cold, only warm, and usually around 2.5k rpm - 4k rpm (higher I can't hear anything due to exhaust) and part throttle. Like, if I am slightly accelerating or decelerating, nothing. But if I am in that kind of latent area of part throttle cruisingish... I don't even have VANOS lol. Just been leaving with it but I want to figure it out eventually.
  9. #34
    Manchester, N.H.
    96 332IS 6466 turbo
    Its the heavy spring rattle.
    1996 332IS
    Built 3.2
  10. #35
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    With the update, you also need longer studs since the stack height increases.
  11. #36
    Dec 2007
    Gatineau,Quebec,Canada
    1990 329tis e30
    Do you have an M50 intake manifold swap?,if you have its more likely coming from the manifold,after I did my m50 intake on my m52 I got the same noise that is right around 2500-3000 rpm,its a resonating noise ,at least in my case.
  12. #37
    Sep 2002
    USA
    BMWs
    Quote Originally Posted by George318 View Post
    I have an M50NV that had an OBD1 intake and it did it, and then I switched to a DI intake and it still did it. It sounds like valvetrainish noise, but, eh. I might break it down some day. Just a minor thing - most people don't notice it.
  13. #38
    Apr 2012
    Tampa, FL
    E36,E38, and E46
    It seems like there was an iphone application that would pinpoint vibrations with the accelerometer and/or mic. Its been years though.
  14. #39
    Toronto, Canada
    E36 Turbo
    I do have an M50 manifold but it has been on my motor since I even turbo'd my stock M52, and since I put my built motor in... So highly unlikely that all of a sudden I would develop a resonance in the intake manifold out of the blue that was never there before.
    Also the noise is VERY pronounced in the front valvecover/vanos area... you can hear and feel it there directly. Sounds do travel in an engine so it wouldn't surprise me if it happened to be somewhere else.
    That said, I'm going to call my BMW dealer today to get a quote on a new set of discs, spring and bolts for the intake cam. If I'm pulling everything apart again, they're going to get changed lol
  15. #40
    Dec 2007
    1990 329tis e30
    On my e36 after I swapped the intake mani it started to make a noise very close to that engine noise that you linked it here,and I have the same noise in my e30 m50 nv turbo,I hoped for you was the same and an easy fix as ignore it like I do?
  16. #41
    Toronto, Canada
    E36 Turbo
    I will certainly look into it and appreciate the feed back!
  17. #42
    Aug 2008
    Calgary, Ab
    E30
    I've got the same thing going on as well with my s50. Had a cracked head so I swapped in a m50nv head modded to fit vanos and since then I have a rattle in the valve train area similar to vanos rattle. So I Rebuilt vanos with besian anti rattle kit, noise still present. Bought a dr.vanos in hopes to resolve it, well it wasn't, so that was a waste of money. Still have the noise, I have around 20k on my built motor with the rattle going on and no issues. I'd definatly like to resolve the noise though as the sound drives me nuts, so hopfully you figure it out.
  18. #43
    Toronto, Canada
    E36 Turbo
    Quote Originally Posted by Boosted E30 View Post
    Well as odd as this may seem, the increasing amount of people that I'm finding who also have this issue is oddly comforting lol
    Still yes, I need to get to the bottom of it all since it just sounds ugly.
  19. #44
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    So apparently its more common then we thought.
    Thats the good news, along with the fact that no one has ever had any failures as a result of it.
    Bad news is that nobody has fixed it... Except for me when I swapped engines hahaha :P
  20. #45
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by rajicase View Post
    Thats the ticket. If the motor rattles just get a new one. Spread the word, problem solved.
  21. #46
    Feb 2012
    1995 BMW M3
    Thats car repair 101. Duh.
  22. #47
    Ship, Pa
    Red Sled, RC51
    I'd just replace the whole car. Easier than the engine.
    "Believe nothing you hear, half of what you read"
  23. #48
    Feb 2012
    1995 BMW M3
    Quote Originally Posted by Fender13Bender View Post
    +1 Totally agree.
  24. #49
    Toronto, Canada
    E36 Turbo
    The M50 guys fixed their issues by putting the late style VANOS plates and spring...
    EVeryone else just seems to live with the noise or goes to a mechanic and they say it's normal.
    I can't see how this noise is normal, it just sounds plain ugly.
    Also I'm not convinced that it doesn't actually do anything performance wise... Maybe not at WOT, but at PT in certain areas of the map I can feel and see the car hesitate/jerk around and my MAP sensor confirms it. I believe it has to do with the state of the engagement of the VANOS... if it's just starting to engage, etc.
  25. #50
    Sep 2002
    USA
    BMWs
    Just want to reiterate, I too have a rattley noise part throttle, say < 5% at mid RPM, oil warm, etc. No jerking/etc., but it's there... and without VANOS.
  1. Need help on my H&R coilover!
    By DINAN COSMOS in forum 1992 - 1999 M3 (E36)
    Last Post: 08-17-2010, 10:50 PM
  2. Replies: 1
    Last Post: 08-29-2005, 06:52 AM
  3. Need help on my dream coupe
    By yofreeze in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-15-2005, 10:58 PM
  4. need help on my car!
    By mastermind in forum 1991 - 1999 (E36)
    Last Post: 03-24-2005, 12:30 AM
  5. Need help on my 1995 740i
    By BMW740i in forum 1995 - 2001 (E38)
    Last Post: 01-28-2004, 09:24 AM
