Results 1 to 25 of 25
Thread: Rear brake upgrade using e34 vented rotors?
    Jan 2015
    Somewhere,USA
    1985 BMW 735i
    I searched and I find posts where others have used the e32/e34 vented rear rotors with upgrading the rear trailing arms, but is it possible to use the vented rear brakes with the stock trailing arms?
    thanks,
    Cfisher
    Jun 2010
    TX
    1983/84/85 745i
    Yes, works with stock trailing arms.
    I make E23 parts.
    10/1984 745i
    11/1984 745i
    11/1984 735i (10:1-265/6)
    Jan 2015
    Somewhere,USA
    1985 BMW 735i
    Thanks very much!
    Mar 2006
    Sacramento, CA
    87 535i/84 €735i/8
    I think I'm the only one to have done trailing arms so far.
    --Jay3->Sic gorgiamus allos subjectatos nunc
    84 €735i manual, 88 528e/i
    Motronic 1 and 1.3 wiring
    Transmission & Diff gearing sheet
    Quadratechtown, PA
    5, 7, 4x4
    Which rotors are used when going big brakes on the rear? With the 540/740 rear calipers the e28 needs the 540 rear rotors. Does the E23 care?
    SoCal
    83 320is, 07 RS4
    Quote Originally Posted by 8991XJ View Post
    You need to make sure you are getting the rotors from the E34 540 and not the E32 740,750. The calipers and carriers however are identical on both.
    Here is a great reference page that shows all the available options-
    http://www.m535i.org/officers/ra/articles.html#brakes
    Bimmerod
    Quadratechtown, PA
    5, 7, 4x4
    Is this true for the E23? I know about the need to use the 5-series rotors on the 5-series cars. I guess I could try it, I have a set of the brakes available and if the E34 rear rotors are the correct part they will fit. If not, they will go on my 5 and I'll look for a set of rears for the e23.
    Mar 2006
    Sacramento, CA
    87 535i/84 €735i/8
    That is not necessarily correct.
    I used the 740/750 E32 rear rotors, with the 740 trailing arms (which are the same part numbers, difference is the bearing vs a bushing)
    Jun 2010
    TX
    1983/84/85 745i
    Thumbs up
    Quote Originally Posted by Jay535is View Post
    Tut tut, I have the E23 V8/12 arms on my 10/84 car! But stock rear brakes.
    I make E23 parts.
    10/1984 745i
    11/1984 745i
    Quadratechtown, PA
    5, 7, 4x4
    Quote Originally Posted by Hit Man X View Post
    Spell check on model number.
    Jun 2010
    TX
    1983/84/85 745i
    Thumbs up
    Keith is correct, I mean the E32 V8/12 trailing arms.
    I have E23 on the brain.
    I make E23 parts.
    10/1984 745i
    11/1984 745i
    Quadratechtown, PA
    5, 7, 4x4
    We can help.
    Mar 2006
    Sacramento, CA
    87 535i/84 €735i/8
    Theres an app for that.
    Jan 2015
    Somewhere,USA
    1985 BMW 735i
    Hate to resurrect a year old thread, but wanted to keep all the information in one thread if possible.
    Could anyone verify that they used the e32 740i /750i rotors on the stock e23 trailing arms when doing this upgrade?
    I ordered a set of the e34 540i BMW rotors and they DO NOT work with the trailing arms on my e23. They go on the hub just fine, but the brake carrier will not fit over the rotor. The section of the rotor where the parking brakes are needs to be "deeper".
    I'd appreciate it if someone could check their records and post what they installed.
    Thanks!
    Mar 2006
    Sacramento, CA
    87 535i/84 €735i/8
    The hat offset for the 540 vs. 740/750 rear rotors is different, I'm willing to bet you need the E32 rotors.
    To be clear, I used the 740/750 rotors/calipers on 740/750 trailing arms-essentially the entire assembly, except the flange for the axle was changed to the E23 part.
    The trailing arm part number is the same for E23/24/28/32/34, the differences are in the flanges & bearings.
    Jan 2015
    Somewhere,USA
    1985 BMW 735i
    I bet you are right Jay. Thanks for your input. I'll order a pair of 740i rear rotors and give it a try and report back.
    Jan 2015
    Somewhere,USA
    1985 BMW 735i
    I just wanted to report back and let everyone know that the 740i rear rotors fit the rear hubs of my e23 and the 540i/740i rear calipers and carriers went on without any issue. So I would say for an e23 the 740i rotors are needed (part #34 21 1 162 967) and as stated earlier for the e24/e28, the 540i rotors are needed.
    Jul 2010
    Leland, NC
    85 €735i 08 550i/6
    How much of a difference does this mod make? How much larger are the rotors? Just curious.
    Sent from my LGLS755 using Tapatalk
    Mar 2006
    Sacramento, CA
    87 535i/84 €735i/8
    I found it to be a very nice upgrade, the larger rear rotors and pistons in the calipers significantly reduce nose dive on hard braking.
    Quadratechtown, PA
    5, 7, 4x4
    Quote Originally Posted by motohunter4 View Post
    Realoem> the e23 brakes, rear brakes, rotor size listed 282x12
    Realoem> the e32 brakes, rear brakes, rotor size listed 300x20
    Mar 2006
    Sacramento, CA
    87 535i/84 €735i/8
    Rotor size is only part of the story.
    The pistons on the E32 calipers are also bigger.
    Jul 2010
    Leland, NC
    85 €735i 08 550i/6
    Scouted the pick and pull and bought some calipers and brackets of a '93 740il for future upgrade. Thanks for the insight guys.
    Jun 2010
    TX
    1983/84/85 745i
    Thumbs up
    Makes a nice difference, rode in a car with this mod and did a big time brake pull down from around 140mph. Far more even braking as stated.
    I make E23 parts.
    10/1984 745i
    11/1984 745i
    Dec 2005
    Omaha NE
    84' 533i Turbo
    I may be familiar with said car.
    Mar 2006
    Sacramento, CA
    87 535i/84 €735i/8
    Showoffs...
    :-p
  1. 330i Rear Brake upgrade DONE!!!!!!! It is AMAZING
    By Hollywood Hamilton in forum 1991 - 1999 (E36)
    Last Post: 03-11-2006, 11:09 PM
  2. Rear brakes upgrade
    By Hugo in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 05-27-2005, 08:15 PM
  3. Replies: 19
    Last Post: 05-02-2005, 09:21 PM
  4. 540i Brake Upgrade for E34 E28 E24 Cars
    By Euro_M5 in forum BMW Parts For Sale
    Last Post: 03-19-2004, 12:53 PM
  5. 540i Brake upgrade for E34 E24 E28 Cars
    Last Post: 02-17-2004, 12:29 PM
