Results 1 to 16 of 16
Thread: Spal Electric Fan Conversion DIY
    Victoria, Canada
    1991 850i
    I thought I would make a DIY here for people looking to make this conversion. I participated in an earlier thread on the subject, where MWrench did this mod I believe. There was some information about it, but not enough for me. I ended up getting a more concise set of instruction through several E36 and E39 threads, and thought I'd make an area on here.
    The Reason: I had read a few threads about fans blowing up and destroying the rad, denting the hood, etc... I already had a nick out of each fan blade due to some contact earlier in it's life, and figured that it could be beneficial for the belt drive and water pump pulley in some small way to boot. Whether or not it frees up some small amount of HP seems to be a matter of debate.
    The Parts: After much reading I ended up going with a Spal puller fan, and I chose the 16" high performance version with the curved blades. THIS IS A SINGLE STAGE FAN! You can click the following link to read up on the fan stats:
    https://webstore.spalusa.com/en-us/p...-16-c-12v.aspx
    I bought it off Ebay for about $135 + shipping.
    I went to Summit racing and bought the following accessories:
    - A 195 degree Spal wiring harness kit
    http://www.summitracing.com/int/parts/spu-ix-195fh
    - A mounting bracket kit. Super important because the fan doesn't come with any mounting material and it is too heavy in my opinion to simply attach it through the radiator
    http://www.summitracing.com/int/parts/spu-ix-30130011
    - A rubber fan shroud. Attaches around the fan housing and acts as a shroud/protection layer between the hard plastic fan housing and the radiator fins.
    http://www.summitracing.com/int/parts/spu-ix-30130074
    They also have a wiring kit to a couple of rocker switches if you wanted to be able to switch the fan on and off manually.
    The Job: After a couple of weeks wait everything arrives at home and sits waiting to be installed. The harness package comes with a temperature sending unit, so that you can add a housing to a coolant line (the bottom hose from what I read) and install the included sensor. I ended up opting to connect the harness to the existing coolant temp sensor used for the AUX fan, so the sensor, and temp specs for the kit didn't really apply since it would be coming on and off based on the stock sensor. I didn't take any pictures during the job as I wasn't thinking about doing a DIY until after, so my apologies.
    Step 1: Remove the skit plate under the rad, just the one piece with the rubber trimmed edge, And jacked the car up on all four corners (was doing shocks at the same time), to get under engine clearance.
    Step 2: I removed the clutch fan using clutch fan tools (a thin 32mm wrench and an equally thin locking bar with several holes for fan pulley bolts), super easy! I dropped the fan out of the bottom of the car.
    Step 3: disconnect the fan shroud push pins and screw clips (10mm bolt on each side) so that the shroud can move around a bit.
    Step 4: I disconnect all of the top little coolant hoses (3 clamped). You will need to seal off the small hose outlet at the top of the water pump, and the small hose outlet at the top of the radiator to prevent spillage (I just used some bits of rag). The return line to the reservoir is fine unsealed.
    Step 5: I wedged the electric fan into the opening of the stock fan shroud and placed it where I wanted it. The top of the fan should line up with the top edge of the radiator with the top fan edge matching the top layer of radiator fins. This will allow perfect fitting top to bottom in the fan shroud opening while ensuring that all fan surface is on radiator fins. For right to left you look into the opening and slide the fan back and forth until you have it centered in the fan shroud opening. Once done I used a marker and marked a line on the radiator lip to correspond with one of the fan cover bars that would be running top to bottom to ensure proper side to side placement; easy!
    Step 6: I removed the fan and then removed the fan shroud making sure to leave the reservoir in place. It's a wiggle job, and you need to go slow to make sure that you don't damage anything, but it will come up and out.
    Step 7: I lined up a top to bottom fan housing bar with the marker line I had drawn fro proper centering left to right on the rad, and I place the top edge of the fan housing to the top edge of the radiator fins and voila, the fan is in proper position!
    Step 8: The fan mounting brackets come in a package of four and click securely onto the fan. My radiator already had several mounting holes and so I manoeuvred each mounting bracket so that it would reach out from the fan housing and match up with a hole. You want to have the brackets stretch as straight away as possible from the fan to ensure a tight fit with no movement. I ended up enlarging the holes I chose with a drill to fit the bolt nut combinations I was using to bolt it on. NEITHER THE FAN, NOR THE BRACKETS, COME WITH HARDWARE!
    Step 9: I bolted on the top two brackets, and then used a dremel with cut off wheel to trim off excess bracket material as I wanted the fan shroud to fit snug along the top as before. For the bottom brackets I used two existing holes but this time used some larger thread screws since I would be able to get a nut on the back side. I measure the distance from fan housing and radiator mounting holes and dremel cut the two bottom brackets accordingly. The fan was now snugly mounted to the radiator.
    Step 10: Before putting the fan shroud back on I plugged the wire harness to the fan pig tail, and sorted out where I wanted to run the various wires. Spal instructs you to give the fan a dedicated power supply, because then fan draw is large I believe, so I would be using a post from the positive power terminal where the jumper nut is, and the alternator power cable goes (see picture, notice the new alternator cable I created that runs down the side of the wheel arch instead of in a metal tube along the engine. It's marine grade and sealed cable and a larger gauge than stock, the ground cable is larger and also of the same type of wire).
    The black ground wire from the pigtail is run to a 10mm bolt near the fan on the headlight pod bracket, and the red wire from the pigtail runs into the fan relay. I chose the location for the relay because there were already two holes from a previous owner's aftermarket alarm set up that I removed.
    From the relay I ran the yellow 12 v power wire to the terminal as described above, the red power wire runs back to the fan pigtail, and the little orange wire is looking for an ignition sourced power wire. You can run the fan off a constant 12v power source if you want the fan to run when the car is powered off. Since it is governed by the coolant temperature sensor it will run when the car is off until the sensor drops into the shut off range. The main issue here is that the fan has a rather large draw, so running it off the battery may run it down past acceptable levels. For my part I wired it to an ignition powered 12v source.
    Thanks to the help of a member on here I was able to source a ignition powered 12v source right where the relay was. The little black fuse box in the picture has four fuse slots when you open it. From the front of the car, the first slot is a permanent 12 v source (should you want that option) and the second slot is an ignition powered 12v source. Since there was no fuse there at all I simply pulled the connector out from the bottom of the box and attached the orange wire from the relay directly to it; done!
    The final wire is the grey wire. This one is to be attached to the temperature sender. For my install (after reading through the e36 and e38 threads) I decided to splice it into the existing temperature sensor. The sensor is on the opposite side of the engine bay from the rest of the fan wiring, but luckily the harness kit comes with more than enough wire length for each wire to do the job. I ran the grey wire along the top of the radiator and down the other side to the temperature sensor.
    There are three wires going into the sensor. The black is the ground wire, the green and black is the low speed wire, and the grey and black is the high speed wire. This sensor runs the auxiliary fan which is a TWO STAGE FAN, while the Spal is a SINGLE STAGE FAN. You have a choice here: ONE: you can wire the grey wire into the green and black wire which will activate the Spal fan when the coolant temperature hits the low temp threshold. At this temperature the auxiliary fan turns on to low speed as well. This wire is also responsible for turning the aux fan on to low speed when the A/C is turned on. The problem here from what I have reads is that if the Spal comes on as well it keeps the engine below the low temp which prevents the engine from running at apparently more optimal/efficient higher temps. Also, the fan is on far more often, and ostensibly not when actually needed.
    I attached the grey Spal fan wire to the grey and black wire which controls the high temperature setting and turns the aux fan on high speed. This means that the Spal fan will only com on when the coolant temp sensor hits the high threshold. This was the consensus choice from the E36 and E39 threads, but someone more knowledgeable can certainly chime in on the merits of letting the engine operate at a higher temperature before cooling.
    Step 11: I replaced the fan shroud by working the bottom edge over the fan and back into place behind the reservoir and in its retaining clips. This took some wiggling and flexing of the plastic, but it got back into it's home eventually. I then replaced the three coolant hoses and clamped them tight. Now time for the push rivets and brackets on each side. I topped up the coolant from the bit I had lost, and I was done.
    An observation I have made so far is that I have never seen or heard the fan come on! Ever! The car always warms up and the needle moves from blue to TDC and never wavers, but the fan also never seems to come on. The guys from the other forums warned that the fan is powerful and when it comes on it's generally fro no more than 30 seconds to bring the engine temp down a few degrees and then shits off again. Here in the spring, in the pacific northwest, it seems as though it's not hot enough yet.
    Still, I though it would be interesting to note that this set up moves from a fan running constantly, and the engine temp gauge sitting at TDC, to a fan that never seems to need to run, and the gauge is STILL at TDC. I have gone for reasonable drives around town with lots of stop light idling, and gotten out and not only is the Spal not running, but neither is the aux fan. This leads me to believe that the coolant temp is not even hitting the low temp threshold that would activate that fan, let alone the high temp threshold needed for the Spal. Pretty neat. I suppose it could be argued that the sensor is faulty, but with no code, no warning message, and no fluctuations in gauge temperature, I'm inclined to think that the system is doing it's job just fine, and that at least in this climate, the clutch fan is entirely unnecessary, at least in fall/winter/spring.
    Thoughts?
    Live, Love, Life, Amazing...
    Feb 2013
    Sarasota, Fl
    95 840CI 91 850I
    Nice write up, will this also work in front of the condenser? Mine on the 840CI is about to go.
    And another thought if that fan is excellent and our cars run cool if all the cooling components are doing the job what about using that fan (the one in place of the engine driven fan) to run at say 1/2 speed tripped by the low temp switch and full speed when tripped by the high temp switch and eliminate the front electric fan.
    Seems that maybe he fan manufacturers may have improved their efficiency over the past 30 years. Thereby allowing one fan to do the job of two. Course you lose some redundancy.
    BMW CCA #500359 E31 Chapter.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    The high-speed operation of the auxiliary fan is for a situation where the viscous-coupled fan has failed to lower the coolant temperature effectively - OR - when the refrigerant pressure is too high. This is an emergency situation only, so probably the wrong place to wire the new fan. The fan would only run when the temperature gauge reached the 3/4 mark.
    The low-speed operation of the auxiliary fan is normally used by the A/C system to get additional air through the condenser. As your auxiliary fan doesn't run I guess that your A/C refrigerant pressure is too low and doesn't operate?
    Possibly a better way would be to add a temperature sensor to the lower hose on the radiator set to 70C - 80C and leave the rest of the system as it is. Even if wired to the low-speed contacts the fan would run at the wrong temperature levels.
    P.S. Excellent installation of the fan though!
    Victoria, Canada
    1991 850i
    The one in front of the condenser is a pusher fan so you'd want to make sure the get that, but it is also a two stage fan so you'd need to get a fan that will run at two speeds based on temperature.
    I'm pretty certain my aux fan comes on at low speed when I turn the A/C on.
    From my understanding the aux fan comes on low at 91 degrees and on high at 99 degrees. The thread where I got most of my information was from the M3 guys. The consensus over there is that the fan should be wired into the higher temp setting to come on at the higher threshold.
    http://www.bimmerforums.com/forum/sh...ring-DIY/page3
    I will continue to monitor the situation, but so far the temp gauge hasn't budged from top dead centre at all.
    Nov 2015
    Turku - Finland
    1991 850i 6 Speed
    You have tested that the fan actually turns on while the engine is idling and going above normal?
    Just leave it running and keep an eye on the needle or better yet if you have a way to measure (make sure) it does not overheat while doing this.
    Victoria, Canada
    1991 850i
    That's just it, the engine has not gone above normal temperature at all. Not while city driving, not while stopped at lights, not while idling at home. I will try the leave it idling for longer this weekend.
    Victoria, Canada
    1991 850i
    Ok, so a few changes. I wired it to the green and black wire to have it come on at a lower temperature, but I'm finding that the fan comes on when the needle is a hair past centre, and will come on when I turn the A/C on
    BUT
    It will blow the 30 amp fuse everytime it comes on the second time, everytime.
    Can anyone think of why this is? The wiring is laid out pretty clearly in the original post. Any advice would be appreciated.
    I do plan to order an adapter and use the temperature sensor that came with the package to turn the fan on at 90 degrees, but until then I would like it to work!
    EDIT: I also have a Hayden fan control module with a blade temperature sensor that sticks through the rad, anyone have any experience with these?
    May 2013
    Salinas CA.
    1993 BMW 850CI
    Hi, I envy you somewhat living in Victoria. I have fond memories from visiting twice. I have used the Hayden temperature sensor, and it does work well. In the end though I believe that a hose adapter with a probe that measures the coolant would be more satisfactory. Nice write up, and I have thought about this electric fan before. Could that fuse have blown because both fans came on at the same time? One of the first things I did to my car after replacing filters and fluids, and all fuel and vacuum lines was to change my plastic main cooling fan, and also the original coolant surge tank. I'm sure many of us are watching your experiment.
    Victoria, Canada
    1991 850i
    Thanks Mike, I'm originally from back east but this is home now
    UPDATE!!! So I have discovered that the fuse for the auxiliary fan AND the Spal fan are blowing when the Spal fan is attached to the Aux fan coolant temperature sensor.
    Looks like there is far too much draw on the same circuit, or something as the fans will start once and run, but the second time and both 30 amp fuses blow. From what I have read the fans have a very large draw to start up.
    THE FIX: I bought this:
    http://www.ebay.ca/itm/141638068422?...%3AMEBIDX%3AIT
    to go withe the 195 degree Spal cooling sensor. It goes on at 195 and turns off at 175 degrees F.
    THE TEMP FIX: I attached the grey wire that was attached to the temperature sensor to a ground attachment. With this set up the fan is an "always on" fan. With both fuses replaced they seem to run nicely on multiple start ups, and the Spal fan has not blown a fuse since. Though the fan can stay as an "always on" set up I'll be looking to throw in the adapter and sensor when it arrives.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Yes, that's the sensible way to do it - with its own in-line temperature sensor so that you can get the coolant temperature within normal limits.
    Victoria, Canada
    1991 850i
    As you also suggested earlier Timm Now, am I right to assume that the hose from the water pump to the rad on the passenger side it the right hose to adapt? Anyone happen to know the inner diameter?
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Yes, from the lower hose on the RHS (when viewed from behind) of the radiator
    Calgary, Canada
    '91 E31 850i,'05 E53 4.4
    thanks for this write-up. I've put this modification off for many years even with the proper parts.
    Perhaps this winter and with tihs discussion, I'll finally get it done.
    I swear, my cars are like a girlfriend.
    Sometimes its a rough ride, sometimes its smooth motorin'.
    Sometimes she doesnt like how i treat her and sometimes i dont like how she behaves.
    BUT at the end of the day, she loves it when I am inside her.
    Christchurch,New Zealand
    93 fjord grey 850csi
    What i have done on an E30 project car with a M54b30 motor fitted was to move the sensor that is fitted to the radiator on the cool side of the radiator to the hotter side via a steel piece of pipe with a nut welded to it so the sensor will bolt in and the pipe is then fitted to the top hose where the water is at its hotttest
    i actually thought the fan switched on low at 95 deg c and panic mode at 105 deg c
    which to me seemed a little ludicrous as the coolant boils at 107 roughly and since it takes that measurement at the hot side god knows how hot the coolant is nearer the motor is it always struck me as a dumb place to fit that sensor but knowing bmw there is a good reason for it
    the main reason i did that was i had no room to fit the viscous fan any way with the newer motor i am of course curious why BMW fitted viscous fans rather than going electric anyway
    Jul 2010
    Rural Northern Nevada
    1991 850i
    Extreme Electric Fan Project
    1991 850i (e31), 6-speed, 155K miles. I have been following this thread and one on the 5-series forum for a couple of years. https://www.bimmerforums.com/forum/s...electric%20fan The 5-series thread is centered on using a two-speed 88-92 Ford Taurus 3.8L electric puller fan. rated at 2500 cfm (high range). Most of the posters source their fans from a junkyard. I got a new one from RockAuto for $70.
    For the most part I followed peezen's excellent instructions, along with the comments on the 5-series forum, with some exceptions: I built my own controller since the Ford fan draws 60 Amps on startup; I mounted the fan (with some modifications) directly to the stock shroud; and I got a severe case of "while-you're-in-there-itus." I decided to go with a complete cooling system rebuild: new Saleri water pump, all new hoses and clamps, new belts, tensioners and hoses, new radiator (less than $100 from Rock Auto) and new crankshaft position pulse generators. I didn't have any problems with my car but it was about time.
    Getting the old fan off was a bear, I bent my official BMW tool, so I welded up a tool out of 2" bar that went around the hub and caught 3 bolts. Still needed a 3' breaker bar on the wrench to get it off. The shroud came off, as well as belts, tensioners, hoses, water pump, etc. I had to move the hydraulic pump to get the bottom pulse generator off, so I disconnected the hydraulic hoses, so all the Pentosin bled out - might as well bleed the whole system, clean the filters, and replace all the fluid. I bought a case of 7.1 a couple of years back, so I had plenty. Everything went back together.
    Fan/Shroud Marriage:
    The stock shroud is pretty sturdy, (I checked and a replacement is $70 at RA), the Ford shroud is thicker and stiffer, so I figured if I mated the two it would hold up. The Dremel with a diamond blade made quick work of the flange around the ford shroud, along with a cutout to accommodate the expansion tank. I bolted the Ford shroud/fan to the inside of the BMW shroud after some test fittings to clear the shaft on the front of the water pump where the old fan was mounted. The Ford fan is smaller than the BMW shroud opening, so I made some sheet metal panels to block the openings, pop-riveted them to the assembly, and sealed them with some clear silicone.
    After everything was together used my Schwaben coolant tool to draw and hold a 20 lb vacuum in the whole cooling system with the heaters on full and the key at position II to get aux pumps on, and the heater cores open. Switched a couple of valves and about 3.5 gallons of coolant got sucked into the system. Started the motor and very little bleeding was necessary. Topped off the overflow tank.
    Controller: I've been using the "Desert Option"temp sensor on my radiator - 91/96C vice the stock 95/99 (I think) so I used that to control the two-speed fan. Picked up the signals (ground) at the sensor, and used a control relay plus a 60A and a 30A power relays to power the fan. The control relay is wired to the Hot When Run aux fusebox peezen mentioned. Power was sourced from under the BATT+ box on the left firewall. The controller box fits on the firewall just behind the coil. The control relay makes sure only one of the power relays is enabled at the same time, otherwise the fan will go into Warp 5 and self-destruct. I hooked up the LEDs while I was developing and testing the controller, and left them there because...
    Results:
    It's about 75 in my garage, a lot colder outside, so I didn't think I could give it a good test. I started it up (no leaks!) and it seemed to idle smoother than before. After about a half-hour at idle, with the temp gauge a tick left of the middle indicator (normal) the low seed fan came on, and stayed on for about 15 minutes, then the high-speed fan came on. The temp gauge stayed steady a tick left of the middle indicator the whole time.
    I'll update this post and answer any questions after I've done some road testing.
    Victoria, Canada
    1991 850i
    Awesome write up! I bought that exact fan, the Lincoln MKVIII version, for my Discovery 2 and have been waiting for summer to do that conversion. Such a powerful fan!
    I'm glad I was able to help in some way, nice work!
  1. Spal electric fan wiring DIY
    By E36M3E in forum 1992 - 1999 M3 (E36)
    Last Post: 11-18-2017, 12:00 PM
  2. M42 electric fan conversion options
    By M42 Technik in forum 1991 - 1999 (E36)
    Last Post: 10-15-2016, 08:34 PM
  3. Spal single relay kit and other parts relating to electric fan conversion
    By felonious monk in forum Engines, Performance Parts & Software
    Last Post: 11-30-2013, 07:18 AM
  4. *DIY Volvo Electric Fan Conversion
    By AHenry014 in forum E34 Common Problems and DIY Fixes
    Last Post: 05-23-2013, 10:49 AM
  5. spal electric fan ??
    By M3corey in forum 1992 - 1999 M3 (E36)
    Last Post: 11-19-2002, 08:37 PM
