RM European Auto Parts
Page 2 of 2 FirstFirst 12
Results 26 to 32 of 32
Thread: Best guess for negative fuel trim problem ?
  1. #26
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Sorry, kaivon, that's just not the way it works. Fuel pressure RISES when vacuum is removed or lessened. Only a dumbass would REDUCE fuel pressure when the car needs more fuel, and BMW engineers are not dumbasses.
    The rating (3.5 bar in this case) is BASE pressure, at idle and high vacuum conditions. Manifold vacuum is more than TWICE the 8 "PSI" (SIC) stated, at idle, and vacuum is quoted in inches of mercury, not psi anyway.
    Let me just ask you this: HOW MANY fuel pressure tests have you done on BMWs? I've done hundreds. This isn't a damned garden hose, let's stop screwing up the equation by pretending it is.
    Here....I just looked up a basic test......see step # 7.
    https://www.2carpros.com/articles/ho...-and-regulator
    Chris Powell
    BMWCCA 274412
  2. #27
    Sep 2008
    Pawtucket, RI
    1996 328i Sport
    That's actually what I said: Reducing vacuum increases fuel pressure.
    Well MrSkarZ is the one who kind of said that idle manifold vacuum was 8 PSI. His language was unclear, but what he meant was that the vacuum at idle reduces fuel pressure by about 8 PSI compared with no vacuum. I realize you disagree with that, but his statement wasn't nonsensical.
    You know the cheapo method for a lawn irritation system--poking pinholes in a garden hose? If you just let water run straight through, you won't get much flow out of those little holes. But if you put your thumb over the end, you'd create enough pressure to force water out of the pinholes. An FPR on the end of the fuel rail is a lot like your thumb on the end of that garden hose.
    Later BMWs with the 3/2 control valve might be different--as early as the M54, the FPR isn't even controlled by manifold vacuum. But I'm talking about the M50 that MrSkarZ has.
  3. #28
    Dec 2014
    Stuttgart, Germany
    One Too Many
    this ever get solved? i am getting some fuel trim errors..
    "So we've come to the conclusion that BMW just has parts laying around they decide to throw on cars for no reason."
    Interest on a Very Budget Supercharger Build??
  4. #29
    Sep 2008
    Pawtucket, RI
    1996 328i Sport
    I messaged the PO, MrSkarZ, but never heard back.
  5. #30
    Feb 2018
    georgia
    bmw e46 2003 sedan
    can someone help me with this fuel trims?
  6. #31
    Jun 2002
    E39M5, E500 4WD
    You can't judge much of anything about fuel trims when the engine is free-spinning with no load.
    Short term fuel trim is basically for idle and near idle conditions, although it might just continue if there's zero load, like a car that's not moving. However, your bank 1 STFT isn't doing a thing, while your bank 2 is changing. The LTFT will hopefully change when the car is under cruise conditions.
    You'd do better by looking at the primary oxygen sensor numbers; see if Bank 1 sensor 1 is even working. Your fuel trim numbers revving in neutral are pretty meaningless, except for Bank 1 doing nothing while bank 2 changes.
    What's the actual problem you're trying to solve here?
    Chris Powell
    BMWCCA 274412
  7. #32
    Jun 2014
    baku, azerbaijan
    2001 bmw e46 320i
    Quote Originally Posted by deme View Post
    Have you fixed that?
  1. 540i fuel trim problems
    By tswantek in forum 1996 - 2003 (E39)
    Last Post: 02-25-2013, 05:09 PM
  2. 1998 740i - Fuel Trim Problem (P0173) - Please help...
    By rm0310 in forum 1995 - 2001 (E38)
    Last Post: 12-07-2009, 10:16 AM
  3. Running rich--with negative fuel trim
    By Poolman in forum 1996 - 2003 (E39)
    Last Post: 06-05-2009, 05:43 PM
  4. fuel trim problem
    By masurati in forum 1996 - 2003 (E39)
    Last Post: 04-10-2006, 01:11 AM
  5. Fuel trim problems causing CEL on RMS SC M3
    By Titansilber in forum Forced Induction
    Last Post: 07-10-2004, 03:54 PM
