Code:
0x5d8c 5D8C - return pump: error while checking voltage: RFP ON: but expected OFF. - proof good test required! - line defect?
0x5d8d 5D8D - return pump: RFP is not running. Error at voltage check: RFP ON: but expected OFF - proof good test required! - fuse oder relais of pump defective?
0x5d8e 5D8E - return pump: run after time to short - proof good test required!
0x5d8f 5D8F - Info: return pump: release of pump drive cycle. No fault - proof good test required.
0x5d90 5D90 - valve relais: FW open. Error caused by too many recognized individual valve errors- defective fuse?
0x5d91 5D91 - valve relais: FW open. Relay does not close during startup test - defective fuse?
0x5d92 5D92 - valve relais: VRA information via SPI has no effect during FSA Test.
0x5d93 5D93 - valve relais: Medium or high-resistance short circuit of voltage supply_FR or valve after ground registered through start-up test.
0x5d94 5D94 - valve relais: FW is in closed position. Does not switch off during startup test.
0x5d95 5D95 - valve relais: VR open, power supply VR to low while startup-test (checked by Uz clamp_15). - defective fuse?
0x5d96 5D96 - valve relais: short circuit to Uz power supply_clamp_15 monitored by valve relais test.
0x5d97 5D97 - valve relais: Medium or high-resistance short circuit of voltage supply _FR or the valve on ground registered during the cyclical valve relay test.
0x5d98 5D98 - inlet valve (IV) front left: error with cyclical valve and relay test.
0x5d99 5D99 - inlet valve (IV) front left: general error.
0x5d9b 5D9B - inlet valve (IV) front left: valve voltage defective (drift error) cable connection or end level defective?
0x5dda 5DDA - inlet valve (IV) front left: ground short circuit recognized.
0x5ddb 5DDB - inlet valve (IV) front left: Non-classifiable error.
0x5d9d 5D9D - outlet valve (OV) front left: error with cyclical valve and relay test.
0x5d9e 5D9E - outlet valve (OV) front left: general error.
0x5de5 5DE5 - outlet valve (OV) front left: ground short circuit recognized.
0x5de6 5DE6 - outlet valve (OV) front left: Non-classifiable error.
0x5da1 5DA1 - inlet valve (IV) front right: error with cyclical valve and relay test.
0x5da2 5DA2 - inlet valve (IV) front right: general error.
0x5e94 5E94 - inlet valve (IV) front right: valve voltage defective (drift error) cable connection or end level defective?
0x5e29 5E29 - inlet valve (IV) front right: ground short circuit recognized.
0x5e2a 5E2A - inlet valve (IV) front right: Non-classifiable error.
0x5da6 5DA6 - outlet valve (OV) front right: error with cyclical valve and relay test.
0x5da7 5DA7 - outlet valve (OV) front right: general error.
0x5e2b 5E2B - outlet valve (OV) front right: ground short circuit recognized.
0x5e78 5E78 - outlet valve (OV) front right: Non-classifiable error.
0x5daa 5DAA - inlet valve (IV) rear left: error with cyclical valve and relay test.
0x5dab 5DAB - inlet valve (IV) rear left: general error.
0x5dad 5DAD - inlet valve (IV) rear left: valve voltage defective (drift error) cable connection or end level defective?
0x5e47 5E47 - inlet valve (IV) rear left: ground short circuit recognized.
0x5e48 5E48 - inlet valve (IV) rear left: Non-classifiable error.
0x5daf 5DAF - outlet valve (OV) rear left: error with cyclical valve and relay test.
0x5db0 5DB0 - outlet valve (OV) rear left: general error.
0x5e6e 5E6E - outlet valve (OV) rear left: ground short circuit recognized.
0x5e6f 5E6F - outlet valve (OV) rear left: Non-classifiable error.
0x5db3 5DB3 - inlet valve (IV) rear right: error with cyclical valve and relay test.
0x5db4 5DB4 - inlet valve (IV) rear right: general error.
0x5e71 5E71 - inlet valve (IV) rear right: ground short circuit recognized.
0x5e73 5E73 - inlet valve (IV) rear right: Non-classifiable error.
0x5db8 5DB8 - outlet valve (OV) rear right: error with cyclical valve and relay test.
0x5db9 5DB9 - outlet valve (OV) rear right: general error.
0x5e7c 5E7F - outlet valve (OV) rear right: ground short circuit recognized.
0x5e7d 5E7D - outlet valve (OV) rear right: Non-classifiable error.
0x5dbc 5DBC - valve (USV1): error with cyclical valve and relay test.
0x5dbd 5DBD - valve (USV1): general error.
0x5dbf 5DBF - valve (USV1): valve voltage defective (drift error) cable connection or end level defective?
0x5e7f 5E7F - valve (USV1): ground short circuit recognized.
0x5e80 5E80 - valve (USV1): Non-classifiable error.
0x5dc1 5DC1 - valve (USV2): error with cyclical valve and relay test.
0x5dc2 5DC2 - valve (USV2): general error.
0x5f4f 5F4F - valve (USV2): valve voltage defective (drift error) cable connection or end level defective?
0x5e81 5E81 - valve (USV2): ground short circuit recognized.
0x5e82 5E82 - valve (USV2): Non-classifiable error.
0x5dc6 5DC6 - valve (HSV1): error with cyclical valve and relay test.
0x5dc7 5DC7 - valve (HSV1): general error.
0x5dc8 5DC8 - valve (HSV1): ground short circuit recognized.
0x5dc9 5DC9 - valve (HSV1): Non-classifiable error.
0x5dca 5DCA - valve (HSV2): error with cyclical valve and relay test.
0x5dcb 5DCB - valve (HSV2): general error.
0x5dcc 5DCC - valve (HSV2): ground short circuit recognized.
0x5dcd 5DCD - valve (HSV2): Non-classifiable error.
0x5dce 5DCE - UZ-Error: slight undervoltage (voltage too low).
0x5dcf 5DCF - UZ-Error: severe undervoltage (voltage much too low).
0x5dd0 5DD0 - UZ-Error: overvoltage.
0x5dd1 5DD1 - UZ-Error: short circuit of a wheel speed sensor - voltage cable on UBatt. (current flow through aspxx-Pin of the speed sensor_input amplifier).
0x5dd2 5DD2 - UZ-Error: voltage peak on Uz.
0x5dd3 5DD3 - DSC-ECU: ECU-internal: Measured supply voltage at tachometer_voltage_supply_clamp_15 is too low (voltage divider fault).
0x5dd4 5DD4 - DSC-ECU: ECU-internal: wheel speed sensor- driver chip: Error in supply voltage/ ground. Reset-response test error.
0x5dd5 5DD5 - DSC-ECU: ECU-internal: Enable-line cannot be activated (Startup-Test Enable high).
0x5dd6 5DD6 - DSC-ECU: ECU-internal: Enable-line cannot be deactivated (Startup-Test Enable low).
0x5dd8 5DD8 - DSC-ECU: ECU-internal: system startup synchronization timeout has occurred.
0x5dd9 5DD9 - DSC-ECU: ECU-internal: SP-Interface: hardware error detected.
0x5ddc 5DDC - DSC-ECU: ECU-internal: Het-SP-Interface Sends error message not correctly transfered.
0x5ddd 5DDD - DSC-ECU: ECU-internal: No access to transmission table of the Het-SP-Interface .
0x5dde 5DDE - DSC-ECU: ECU-internal: Watchdog-control signals: data error occurred.
0x5ddf 5DDF - DSC-ECU: ECU-internal: Watchdog-Monitoring reports: incorrect status.
0x5de0 5DE0 - DSC-ECU: ECU-internal: Plausibility of VASP-U_bit reference to tachometer supply_voltage _clamp_ 15.
0x5de1 5DE1 - DSC-ECU: ECU-internal: Clockstatus of the SP interface shows missing clock.
0x5de2 5DE2 - DSC-ECU: ECU-internal: DePwm status: software/hardware configurations do not match (DF11i/s).
0x5de3 5DE3 - DSC-ECU: ECU-internal: status_wheel speed output of the SP interface does not match configuration.
0x5de4 5DE4 - DSC-ECU: ECU-internal: Boot Block ROM checksum test error.
0x5dee 5DEE - DSC-ECU: ECU-internal: error in error detection system in status/transfer: SP interface error in the algorithm server .
0x5def 5DEF - DSC-ECU: ECU-internal: ROM checksum test error.
0x5df0 5DF0 - DSC-ECU: ECU-internal: RAM address test error.
0x5df1 5DF1 - DSC-ECU: ECU-internal: RAM check pattern test error.
0x5df2 5DF2 - DSC-ECU: ECU-internal: HET RAM address test error.
0x5df3 5DF3 - DSC-ECU: ECU-internal: HET RAM check pattern test error.
0x5df4 5DF4 - DSC-ECU: ECU-internal: ADC calibration error.
0x5df5 5DF5 - DSC-ECU: ECU-internal: Can RAM check pattern test error.
0x5df6 5DF6 - DSC-ECU: ECU-internal: operating system computing cycle time to high - wrong computing cycle (Task)-Timing.
0x5df7 5DF7 - DSC-ECU: ECU-internal: operating system: low background-computing cycle(task)-activity - system overloaded!
0x5df8 5DF8 - DSC-ECU: ECU-internal: exception error operating system.
0x5df9 5DF9 - DSC-ECU: ECU-internal: Operating system: computing cycle (task) missing or not activated.
0x5dfa 5DFA - DSC-ECU: ECU-internal: undefined fast interrupt request (FIQ) has occurred.
0x5dfb 5DFB - DSC-ECU: ECU-internal: data interruption -> mikrocontroller-mode: Daboard.
0x5dfc 5DFC - DSC-ECU: ECU-internal: program brake -> microcontroller-mode: Paboard.
0x5dfd 5DFD - DSC-ECU: ECU-internal: illegal Opcode found -> microcontroller-mode: undefined.
0x5dfe 5DFE - DSC-ECU: ECU-internal: ROM checksum test error.
0x5dff 5DFF - DSC-ECU: ECU-internal: RAM address test error.
0x5e00 5E00 - DSC-ECU: ECU-internal: RAM check pattern test error.
0x5e01 5E01 - DSC-ECU: ECU-internal: HET RAM address test error.
0x5e02 5E02 - DSC-ECU: ECU-internal: HET RAM check pattern test error.
0x5e03 5E03 - DSC-ECU: ECU-internal: general error of the valve driver status or valve driver registered through cyclical valve relay test.
0x5e04 5E04 - DSC-ECU: ECU-internal: error of permanent enable line monitoring (enable is low after startup test).
0x5e05 5E05 - DSC-ECU: ECU-internal: SP interface transfer impossible to plan.
0x5e06 5E06 - DSC-ECU: ECU-internal: Scheduled data transfer not available.
0x5e07 5E07 - DSC-ECU: ECU-internal: data transfer error (answer of the SP-interface handler).
0x5e08 5E08 - DSC-ECU: ECU-internal: Scheduled built-in-self-test (BIST) incorrect (BIST continuity).
0x5e09 5E09 - DSC-ECU: ECU-internal: Build-in-self-test (BIST)-different signatures, CPU error in algorithm or system server.
0x5e0a 5E0A - DSC-ECU: ECU-internal: general control device error.
0x5e0b 5E0B - DSC-ECU: ECU-internal: FPS error and status transfer: First-in-first-out-overflow in the system server has occurred .
0x5e0c 5E0C - DSC-ECU: ECU-internal: Build-in-self-test(BIST)-dignatures different. CPU error in algorithm or System-Server.
0x5e0d 5E0D - DSC-ECU: ECU-internal: Timeout of the built-in-self-test(BIST). Answer through Algorithm-Server.
0x5e0e 5E0E - DSC-ECU: ECU-internal: operating system computing cycle time to high - wrong computing cycle(Task)-Timing.
0x5e0f 5E0F - DSC-ECU: ECU-internal: operating system computing cycle (Task) is missing or not activated.
0x5e10 5E10 - DSC-ECU: ECU-internal: operating system low background task-activity - system overloaded!
0x5e11 5E11 - DSC-ECU: ECU-internal: undefined fast interrupt request (FIQ) has occurred.
0x5e12 5E12 - DSC-ECU: ECU-internal: Illegaler Opcode gefunden -> Mikrocontroller-mode: undefiniert.
0x5e13 5E13 - DSC-ECU: ECU-internal: program brake -> microcontroller-mode: Paboard.
0x5e14 5E14 - DSC-ECU: ECU-internal: data break -> microcontroller-mode: Daboard.
0x5e15 5E15 - DSC-ECU: ECU-internal: FPS status transfer: SP interface timeout in the system server .
0x5e16 5E16 - DSC-ECU: ECU-internal: FPS error Transfer: SP interface timeout in the system server .
0x5e17 5E17 - DSC-ECU: ECU-internal: FPS status transfer: SP interface error in the system server .
0x5e18 5E18 - DSC-ECU: ECU-internal: Data volume for periphery SP interface exceeds buffer length.
0x5e19 5E19 - DSC-ECU: ECU-internal: Serial-Peripheral-Interface (SPI): ID request not accepted.
0x5e1a 5E1A - DSC-ECU: ECU-internal: Serial-Peripheral-Interface (SPI): transmission failure multi IC.
0x5e1b 5E1B - DSC-ECU: ECU-internal: Serial-Peripheral-Interface (SPI): Transmission error in EEPROM.
0x5e1c 5E1C - DSC-ECU: ECU-internal: energy gap, voltage outside of valid range.
0x5e1d 5E1D - DSC-ECU: ECU-internal: ADC conversion of start error.
0x5e1e 5E1E - DSC-ECU: ECU-internal: Flash reprogramming failed (cells are not writable).
0x5e1f 5E1F - Info: DSC-ECU: Flash Re-programming cycle successfully executed (Info).
0x5e20 5E20 - DSC-ECU: general control device error.
0x5e21 5E21 - DSC-ECU: ECU-internal: exception error operating system.
0x5f03 5F03 - DSC-ECU: ECU-internal: error reading EEPROM values: EEPROM cell defect.
0x5f04 5F04 - DSC-ECU: ECU-internal: reading EEPROM values takes too long.
0x5f05 5F05 - DSC-ECU: ECU-internal: Testpin cable disruption detected through valve drift check for U467.
0x5f06 5F06 - DSC-ECU: ECU-internal: error accessing the valve control outlet.
0x5f16 5F16 - DSC-ECU: ECU-internal: wheel speed of main processor and coprocessor do not match.
0x5f17 5F17 - DSC-ECU: ECU-internal: High-end-timer (HET) - error has occurred .
0x5e22 5E22 - wheel speed sensor front left: line defect or short circuit .
0x5e23 5E23 - wheel speed sensor front left: long-term (several secs.) error suspicion led to error mode.
0x5e24 5E24 - wheel speed sensor front left: signal edge missing (RDF-Typ 11i).
0x5e25 5E25 - wheel speed sensor front left: wrong signal width (>2ms) - correct RDF-type installed?
0x5e26 5E26 - wheel speed sensor front left: air gap too large .
0x5e27 5E27 - wheel speed sensor front left: loss of dynamic signal - proof good test required!
0x5e28 5E28 - wheel speed sensor front left: noise monitor (Noise Monitor) - proof good test required!
0x5e2d 5E2D - wheel speed sensor front left: missing impulse ring wheel FL - proof good test required!
0x5e2e 5E2E - wheel speed sensor front left: wheel slip check wheel FL - proof good test required!
0x5e2f 5E2F - wheel speed sensor front left: drive off fault wheel FL (RDF-signal value invalid) - proof good test required!
0x5efe 5EFE - wheel speed sensor front left: wheel FL max. time range of inplausible sensor values (InplRad) exceeded.
0x5e30 5E30 - wheel speed sensor rear left: line defect or short circuit .
0x5e31 5E31 - wheel speed sensor rear left: long-term (several secs.) error suspicion led to error mode.
0x5e32 5E32 - wheel speed sensor rear left: signal edge missing (RDF-Typ 11i).
0x5e33 5E33 - wheel speed sensor rear left: wrong signal width (>2ms) - correct RDF-type installed?
0x5e34 5E34 - wheel speed sensor rear left: air gap too large .
0x5e35 5E35 - wheel speed sensor rear left: dynamic signal loss - proof good test required!
0x5e36 5E36 - wheel speed sensor rear left: error signal interspersion monitoring (Noise Monitor) - proof good test required!
0x5e3b 5E3B - wheel speed sensor rear left: missing impulse ring wheel RL - proof good test required!
0x5e3c 5E3C - wheel speed sensor rear left: wheel slip check wheel RL - proof good test required!
0x5e3d 5E3D - wheel speed sensor rear left: drive off fault wheel RL (RDF-signal value invalid) - proof good test required!
0x5eff 5EFF - wheel speed sensor rear left: wheel RL max. time range of inplausible sensor values (InplRad) exceeded.
0x5e3e 5E3E - wheel speed sensor rear right: line defect or short circuit .
0x5e3f 5E3F - wheel speed sensor rear right: long-term (several secs.) error suspicion led to error mode.
0x5e40 5E40 - wheel speed sensor rear right: signal edge missing (RDF-Typ 11i).
0x5e41 5E41 - wheel speed sensor rear right: wrong signal width (>2ms) - correct RDF-type installed?
0x5e42 5E42 - wheel speed sensor rear right: air gap too large .
0x5e43 5E43 - wheel speed sensor rear right: loss of dynamic signal - proof good test required!
0x5e44 5E44 - wheel speed sensor rear right: noise monitor (Noise Monitor) - proof good test required!
0x5e49 5E49 - wheel speed sensor rear right: missing impulse ring wheel RR - proof good test required!
0x5e4a 5E4A - wheel speed sensor rear right: wheel slip check RR - proof good test required!
0x5e4b 5E4B - wheel speed sensor rear right: drive off fault wheel RR (RDF-signal value invalid) - proof good test required!
0x5f00 5F00 - wheel speed sensor rear right: wheel RR max. time range of inplausible sensor values (InplRad) exceeded.
0x5e4c 5E4C - wheel speed sensor front right: line defect or short circuit .
0x5e4d 5E4D - wheel speed sensor front right: long-term (several secs.) error suspicion led to error mode.
0x5e4e 5E4E - wheel speed sensor front right: signal edge missing (RDF-Typ 11i).
0x5e4f 5E4F - wheel speed sensor front right: wrong signal width (>2ms) - correct RDF-type installed?
0x5e50 5E50 - wheel speed sensor front right: air gap too large .
0x5e51 5E51 - wheel speed sensor front right: loss of dynamic signal - proof good test required.
0x5e52 5E52 - wheel speed sensor front right: noise monitor (Noise Monitor) - proof good test required.
0x5e57 5E57 - wheel speed sensor front right: missing impulse ring wheel FR - proof good test required.
0x5e58 5E58 - wheel speed sensor front right: wheel slip check wheel FR - proof good test required.
0x5e59 5E59 - wheel speed sensor front right: drive off fault wheel FR (RDF-signal value invalid) - proof good test required.
0x5f01 5F01 - wheel speed sensor front right: wheel FR max. time range of inplausible sensor values (InplRad) exceeded.
0x5e5a 5E5A - wheel speed sensor general: Long-term (several secs.) Error suspicion of 2 RDF led to error mode.
0x5e5b 5E5B - wheel speed sensor general: Long-term (several secs.) Error suspicion of 3-4 RDF led to error mode.
0x5e5c 5E5C - wheel speed sensor general: plausibility rotational direction.
0x5e5d 5E5D - wheel speed sensor general: ABS control not plausible.
0x5e5e 5E5E - wheel speed sensor general: general error while monitoring slip control (Lambda).
0x5e5f 5E5F - wheel speed sensor general: short-term (few secs.) Error suspicion of 2-3 RDF. Temporary, reparable error.
0x5e66 5E66 - wheel speed sensor general: crossed wheel speed sensor lines at front axle.
0x5e67 5E67 - wheel speed sensor general: crossed wheel speed sensor lines at rear axle.
0x5e68 5E68 - wheel speed sensor general: crossed wheel speed sensor lines at front axle - proof good test required!
0x5e69 5E69 - wheel speed sensor general: crossed wheel speed sensor lines at rear axle - proof good test required!
0x5f02 5F02 - wheel speed sensor general: max. numbers of inplausible sensor values (InplRad) exceeded.
0x5e60 5E60 - brake light switch (BLS): Plausibility of BLS signal vs reported BS-signal of DME cable short circuit?
0x5e62 5E62 - brake light switch (BLS): monitoring of the brake light switch (BLS) shows permanent high (but ECU reads a depressed brake pedal) - line interruption or short circuit?
0x5e63 5E63 - brake light switch (BLS): monitoring of the brake light switch (BLS) shows permanent high (but ECU reads a depressed brake pedal) - proof good test required! - line interruption or short circuit?
0x5eee 5EEE - brake light switch (BLS): plausibility 1: plausibility check: pressure sensor versus brake light switch (BLS) (low brake pressure range).
0x5eef 5EEF - brake light switch (BLS): plausibility 2: plausibility check: pressure sensor versus brake light switch (BLS) (middle brake pressure range).
0x5ef0 5EF0 - brake light switch (BLS): plausibility 3: plausibility check: pressure sensor versus brake light switch (BLS) (high brake pressure).
0x5f37 5F37 - brake light switch (BLS): DME reports invalid status of the signal BRAKE SWITCH.
0xD347 D347 - PT-CAN: BusOff or initialising-Error. CAN circuit interrupted?
0xD34B D34B - F-CAN: BusOff or initialising-Error. - CAN circuit interrupted?
0xD34c D34C - PT-CAN: general CAN error. CAN1 passive CAN circuit interrupted?
0xD34d D34D - F-CAN: general CAN error. CAN2 passive CAN circuit interrupted?
0xD354 D354 - PT-CAN: message TORQUE_1 (ID 0xA8) not received or wrong message length (DLC). [transmitter: DME]
0xD355 D355 - PT-CAN: message TORQUE_2 (ID 0x0A9) not received or wrong message length (DLC). [transmitter: DME]
0xD356 D356 - PT-CAN: message TORQUE_3 (ID 0xAA) not received or wrong message length (DLC). [transmitter: DME]
0xD357 D357 - PT-CAN: message VERZOEGERUNG_ANF-ACC (ID 0x0AD) not received (reveived by DSC ECU). [transmitter: ACC]
0x5e6a 5E6A - PT-CAN: message DREHMOMENT_ANF_DSC (ID 0x0B6) could not be sent (sent by DSC ECU).
0xD358 D358 - PT-CAN: message GETRIEBEDATEN (ID 0xBA) not received (reveived by DSC ECU). [transmitter: EGS]
0x5e6b 5E6B - PT-Can: message LENKRADWINKEL (ID 0x0C4) could not be sent (sent by DSC ECU).
0xD359 D359 - F-CAN: message LENKRADWINKEL_OBEN (ID 0x0C9) not received (reveived by DSC ECU). [transmitter: SZL]
0x5e72 5E72 - PT-Can: message GESCHWINDIGKEIT_RAD (ID 0x0CE) could not be sent (sent by DSC ECU).
0xD35A D35A - PT-CAN: message KLEMMENSTATUS (ID 0x130) not received. [transmitter:CAS]
0x5e74 5E74 - PT-Can: message STAT_DSC (ID 0x19E, Status DSC) could not be sent (sent by DSC ECU).
0x5e75 5E75 - PT-Can: message GESCHWINDIGKEIT (ID 0x1A0) could not be sent (sent by DSC ECU).
0x5e76 5E76 - PT-Can: message WEGSTRECKE (ID 0x1A6) could not be sent (sent by DSC ECU).
0xD35F D35F - PT-CAN: message STAT_ARS (ID 0x1AC) not received. [transmitter: ARS]
0xD35C D35C - PT-CAN: message STAT_KOMBI (ID 0x1B4) not received. [transmitter: instrument cluster]
0xD35D D35D - PT-CAN: message STAT_AFS (ID 0x1FC) not received. [transmitter: AFS]
0x5e7a 5E7A - PT-Can: message BREMSDRUCK_RAD (ID 0x2B2) could not be sent (sent by DSC ECU).
0xD35E D35E - PT-CAN: message A_TEMP_RELATIVZEIT (ID 0x310) not received. [transmitter: instrument cluster]
0x5e77 5E77 - PT-Can: message STAT_RPA (ID 0x31D Reifenpannenanzeige) could not be sent (sent by DSC ECU).
0xD360 D360 - PT-CAN: message KILOMETERSTAND (ID 0x330) not received. [transmitter:instrument cluster]
0x5e7e 5E7E - PT-Can: message RAD_TOLERANZ (ID 0x374Radtoleranzabgleich) could not be sent (sent by DSC ECU).
0xD361 D361 - PT-CAN: message FAHRGESTELLNUMMER (ID 0x380) not received. [transmitter:CAS]
0xD362 D362 - CAN-Error: message FAHRZEUGTYP (ID 0x388) not received. [transmitter:CAS]
0xD363 D363 - PT-CAN: message BEDIENUNG_FAHRWERK (ID 0x398) not received (reveived by DSC ECU). [transmitter: CCC,MASK]
0xD364 D364 - PT-CAN: message NETZWERKMANAGEMENT (ID 0x480) not received or wrong message length (DLC).
0x5e83 5E83 - PT-Can: message Netzwerkmanagement_DSC (ID 0x5A9) could not be sent (sent by DSC ECU).
0x5e84 5E84 - PT-Can: message BOS_MELDUNG_DSC (ID 0x5A9, Bremsbelagverschleiss) could not be sent (sent by DSC ECU).
0xD365 D365 - PT-CAN: message BOS_RUECKSTELLUNG (ID 0x5E0) not received. [transmitter:instrument cluster]
0x5e85 5E85 - CAN-Error: message YAW_REQUEST (ID 0xC5) not sent!
0xD366 D366 - CAN-Error: message YAW_ANSWER (ID 0xC7) not received (reveived by DSC ECU).
0xD367 D367 - F-CAN: message EXCH_AFS_DSC (ID 0x118) not received (reveived by DSC ECU). [transmitter:AFS]
0xD368 D368 - PT-CAN: message RWDT_STEA_WHL (ID 0x0C3) not received or wrong message length (DLC). [transmitter: SZL]
0x5e89 5E89 - CAN-Error: message YAW_REQUEST_2 (ID 0xCA) not sent!
0xD369 D369 - CAN-Error: message YAW_ANSWER_2 (ID 0x0CB) missed!
0x5e8a 5E8A - F-CAN: message REGELEINGRIFF_DSC_AFS (ID 0x11E) could not be sent (sent by DSC ECU).
0x5e8b 5E8B - F-CAN: message GESCHWINDIGKEIT_RAD (ID 0x0CE) could not be sent (sent by DSC ECU).
0x5e8c 5E8C - PT-CAN: message STATUS_ANHAENGER (ID 0x2E4) not received (reveived by DSC ECU). [transmitter:AHM]
0x5e6c 5E6C - PT-CAN: message SOLL_MOM_ANF (0xBB) could not be sent (sent by DSC ECU).
0xD36B D36B - PT-CAN: message ST_WEAR_DISK (0x376) not received or wrong message length. (DLC). [transmitter:VGSG]
0x5e6d 5E6D - F-CAN: message SYNC (ID 0x080) could not be sent (sent by DSC ECU).
0xD36C D36C - CAN: Timeout of the message BEDIENUNG_AUDIO_TEL (ID ox1D).
0xD36D D36D - CAN: message BEDIENUNG_TEMPOMAT (ID 0x194) not received or wrong message length (DLC). [transmitter:SZL]
0xD36E D36E - CAN: message BEDIENUNG_WISCHER (ID 0x2A6) not received or wrong message length (DLC). [transmitter:SZL]
0xD373 D373 - F-CAN: message LENKRADWINKEL_OBEN_Gateway TimeOut (ID 0x0C9h) not received or wrong message length (DLC) [transmitter: SZL]
0x5e79 5E7E - PT-CAN: message RAD_TOLERANZ (ID 0x374, Radtoleranzabgleich) could not be sent (sent by DSC ECU).
0xD37D D37D - PT-CAN: message WISCHERGESCHWINDIGKEIT (0x226) not received or wrong message length (DLC) [transmitter: rain sensor]
0xD37E D37E - PT-CAN: message BEDIENUNG_SONDERFUNKTION (0x228) not received or wrong message length (DLC). [transmitter: CCC,MASK]
0xD37F D37F - CAN-Error: message BEDIENUNG_TASTER_DSC (ID 0x316) not received or wrong message length (DLC).
0xD380 D380 - PT-CAN: message BEDIENUNG_TASTER_HDC (ID 0x31A) not received or wrong message length (DLC). [transmitter: CCC,MASK]
0xD381 D381 - CAN-Error: message BEDIENUNG_TASTER_RDC (ID 0x319) not received or wrong message length (DLC).
0xD382 D382 - PT-CAN: message ANF_RADMOM_BREMSE (ID 0xD5) not received or wrong message length (DLC) [transmitter: LDM]
0x5e7b 5E7B - PT-Can: message RADMOM_BREMSE (0xE1) could not be sent (sent by DSC ECU).
0x5ec2 5EC2 - Info: CAN: 4-wheel-drive software is loaded.
0x6f51 6F51 - PT-Can: message HOEHENSTAND_LUFTFEDER (ID 0x212)not received or wrong message length
0x6dcf 6DCF - CAN-message/ air suspension: Signal HGLV_RH_AISP in CAN-message HOEHENSTAND_LUFTFEDER invalid.
0x6dd0 6DD0 - CAN-message/ air suspension: Signal ALIV_AISP in CAN-message HOEHENSTAND_LUFTFEDER invalid.
0x5e61 5E61 - lateral acceleration sensor: Controller Release System (CRS) - suspected error, gradient.
0x5e8e 5E8E - lateral acceleration sensor: measuring range exceeded .
0x5e90 5E90 - lateral acceleration sensor: long-term offset exceeds limit.
0x5e91 5E91 - lateral acceleration sensor: value too high during idle.
0x5e92 5E92 - lateral acceleration sensor: plausibility error, although model validity is inside limits.
0x5e93 5E93 - lateral acceleration sensor: Plausibility error while signal monitoring (out of model validity).
0x5e95 5E95 - lateral acceleration sensor: Controller Release System (CRS) - suspected error, signal gradient.
0x5e96 5E96 - lateral acceleration sensor: Plattform-Software (PSW) - suspected failure.
0x5e97 5E97 - lateral acceleration sensor: Controller Release System (CRS) - suspected error with exceeded measuring range.
0x5e98 5E98 - lateral acceleration sensor: Internal transverse acceleration value outside of range (DrsERRN02).
0x5e99 5E99 - lateral acceleration sensor: Internal self-test failed (DrsERRN04).
0x5f64 5F64 - lateral acceleration sensor 2: Internal value outside of range (Drs2ERRN02).
0x5f65 5F65 - lateral acceleration sensor 2: Internal self-test failed (Drs2ERRN04).
0x5e8d 5E8D - ongitudinal acceleration sensor: long-term offset value outside of range.
0x5e8f 5E8F - ongitudinal acceleration sensor: Error in plausibility monitoring.
0x5eb6 5EB6 - ongitudinal acceleration sensor: (range of values exceeded.
0x5e9a 5E9A - yaw rate sensor: sign error - proof good test required.
0x5e9b 5E9B - yaw rate sensor: intentional signal disruption (static bite) defective.
0x5ea1 5EA1 - yaw rate sensor: intentional signal disruption (dynamic bite) defective.
0x5ea9 5EA9 - yaw rate sensor: Controller Release System (CRS) - suspected error with intentional signal disruption (Static BITE).
0x5eab 5EAB - yaw rate sensor: Controller Release System (CRS) - Suspected error with intentional signal disruption (Dynamic BITE).
0x5eac 5EAC - yaw rate sensor: Plattform-Software (PSW) - suspected failure DRS.
0x5ead 5EAD - yaw rate sensor: Drs-ID does not match the requested ID.
0x5eae 5EAE - yaw rate sensor: checksum of received DRS message is incorrect.
0x5eaf 5EAF - yaw rate sensor: error of ERR or TERR bits. No additional information (ERRNO = 0).
0x5eb0 5EB0 - yaw rate sensor: Internal yawing value outside of range (DrsERRNO1).
0x5eb1 5EB1 - yaw rate sensor: Internal reference variable outside of range (DrsERRNO3).
0x5eb2 5EB2 - yaw rate sensor: Received message too early (DrsERRNO5).
0x5eb3 5EB3 - yaw rate sensor: voltage supply too low (DrsERRNO6).
0x5eb4 5EB4 - yaw rate sensor: voltage supply too high (DrsERRNO7).
0x5eb5 5EB5 - yaw rate sensor: Sensor in initialision (DrsERRNO8).
0x5f58 5F58 - yaw rate sensor: Controller Release System (CRS) - suspected error with intentional signal disruption (Dynamic Bite).
0x5f59 5F59 - yaw rate sensor: Controller Release System (CRS) - suspected error with signal gradient.
0x5d9a 5D9A - yaw rate sensor: DRS sends signal DrsAX1=INITstatus error. (DRS-Typ MM 3.x).
0x5d9c 5D9C - yaw rate sensor: DRS sends signal DrsAY1=INITstatus error (DRS-Typ MM 3.x).
0x5d9f 5D9F - yaw rate sensor: DRS sends signal DrsAY2=INITstatus error (DRS-Typ MM 3.x).
0x5da0 5DA0 - yaw rate sensor: DRS sends signal DrsPSIP1=INITstatus error (DRS-Typ MM 3.x).
0x5da3 5DA3 - yaw rate sensor: DRS sends signal DrsPSIP2=INIT,status error (DRS-Typ MM 3.x).
0x5da4 5DA4 - yaw rate sensor: DRS sends signal DrsAX1=signal fault. resetable (DRS-Typ MM 3.x).
0x5da5 5DA5 - yaw rate sensor: DRS sends signal DrsAY1=signal fault. resetable (DRS-Typ MM 3.x).
0x5da8 5DA8 - yaw rate sensor: DRS sends signal DrsAY2=signal fault. resetable (DRS-Typ MM 3.x).
0x5da9 5DA9 - yaw rate sensor: DRS sends signal DrsPSIP1=signal fault. resetable (DRS-Typ MM 3.x).
0x5dac 5DAC - yaw rate sensor: DRS sends signal DrsPSIP2=signal fault. resetable (DRS-Typ MM 3.x).
0x5dae 5DAE - yaw rate sensor: DRS sends signal AX1=invalid (DRS-Typ MM 3.x).
0x5db1 5DB1 - yaw rate sensor: DRS sends signal AY1=invalid (DRS-Typ MM 3.x).
0x5db2 5DB2 - yaw rate sensor: DRS sends signal AY2=invalid (DRS-Typ MM 3.x).
0x5db5 5DB5 - yaw rate sensor: DRS sends signal PSIP!=invalid (DRS-Typ MM 3.x).
0x5db6 5DB6 - yaw rate sensor: DRS sends signal PSIP2=invalid (DRS-Typ MM 3.x).
0x5db7 5DB7 - yaw rate sensor: DRS sends signal PSIPP=invalid (DRS-Typ MM 3.x).
0x5dba 5DBA - yaw rate sensor: internal error: Ax1SensNotAvailable (DRS-Typ MM3.x).
0x5dbb 5DBB - yaw rate sensor: internal error: Ay1SensNotAvailable (DRS-Typ MM3.x).
0x5dbe 5DBE - yaw rate sensor: internal error: Ay2SensNotAvailable (DRS-Typ MM3.x)
0x5dc0 5DC0 - yaw rate sensor: internal error: PSIP1SensNotAvailable (DRS-Typ MM3.x).
0x5dc3 5DC3 - yaw rate sensor: internal error: PSIP2SensNotAvailable (DRS-Typ MM3.x)
0x5dc4 5DC4 - yaw rate sensor: internal error: PSIPPSensNotAvailable (DRS-TypMM 3.x). DRS MM 3.x (R): DRS - PSIPPSensNotAvailable.
0xD375 D375 - yaw rate sensor: CAN-message counter reports error (DRS Typ MM 3.x).
0xD376 D376 - yaw rate sensor: CAN-message counter reports error (DRS Typ MM 3.x).
0xD377 D377 - yaw rate sensor: CAN-message counter reports error (DRS Typ MM 3.x).
0xD378 D378 - yaw rate sensor: CAN-message counter reports error (DRS Typ MM 3.x).
0xD379 D379 - yaw rate sensor: Check sum of the message is incorrect (DRS Typ MM 3.x).
0xD37A D37A - yaw rate sensor: Check sum of the message is incorrect (DRS Typ MM 3.x).
0xD37B D37B - yaw rate sensor: Check sum of the message is incorrect (DRS Typ MM 3.x).
0xD37C D37C - yaw rate sensor: Check sum of the message is incorrect (DRS Typ MM 3.x).
0x5e2c 5E2C - yaw rate sensor: DRS received through CAN bus does not match configuration (DRS-Typ MM 3.x).
0x5e37 5E37 - yaw rate sensor: DRS-Type wrong or CLUtype-ID7 not permissible (DRS-Typ MM 3.x).
0x5e38 5E38 - yaw rate sensor: DRS reports CheckTimeout. DrsVARCheckTimeout (DRS-Typ MM 3.x).
0x5e39 5E39 - yaw rate sensor: internal error. SensDetectedCRC (DRS-Typ MM 3.x).
0x5e3a 5E3A - yaw rate sensor: internal error. overvoltage recognized.
0x5e45 5E45 - yaw rate sensor: internal error (DRS-Typ MM 3.x).
0xD36F D36F - F-CAN: message CLU1_VDA (ID 0x0D8) not received or wrong message length (DLC) [transmitter: DRS] - Voltage supply DRS defective?
0xD370 D370 - F-CAN: message CLU2_VDA (0x0E3) not received or wrong message length (DLC). [transmitter: DRS] - Voltage supply DRS defective?
0xD371 D371 - F-CAN: message CLU3_VDA (0x0F4) not received or wrong message length. [transmitter: DRS] - Voltage supply DRS defective?
0xD372 D372 - F-CAN: message CLU_St_VDA (ID 0x165) not received or wrong message length (DLC). [transmitter: DRS] - Voltage supply DRS defective?
0x5e46 5E46 - F-CAN: message SYNC (ID 0x80, Synchronisation Sensorcluster) could not be sent (sent by DSC ECU).
0x6dc0 6DC0 - yaw rate sensor: offset-calibration impossible,longitudinal acceleration out of range (DRS-Typ MM3x).
0x6dc1 6DC1 - yaw rate sensor: error occurred during EEProm-access (DRS-Typ MM3x).
0x6dc2 6DC2 - yaw rate sensor: to many unvalid longitudinal acceleration values occured while longitudinal acceleration calibration (DRS-Typ MM3x).
0x6dc3 6DC3 - yaw rate sensor: new DRS sensor detected. Stored serial number does not match to the received paßt nicht zu serial number ongitudinal acceleration sensor calibration required
0x5e9c 5E9C - yaw rate sensor: plausibility error for steering angle sensor .
0x5e9d 5E9D - yaw rate sensor: measuring range exceeded .
0x5e9e 5E9E - yaw rate sensor: sign error.
0x5e9f 5E9F - yaw rate sensor: Offset exceeds limit during idle.
0x5ea0 5EA0 - yaw rate sensor: signal gradient DRS.
0x5ea2 5EA2 - yaw rate sensor: Offset exceeds limit during fast compensation.
0x5ea3 5EA3 - yaw rate sensor: Gain exceeds limit.
0x5ea4 5EA4 - yaw rate sensor: Offset exceeds limit during slow compensation.
0x5ea5 5EA5 - yaw rate sensor: plausibility error, although model validity is inside limits.
0x5ea6 5EA6 - yaw rate sensor: Plausibility error while signal monitoring (out of model validity).
0x5ea7 5EA7 - yaw rate sensor: redundancy error.
0x5ea8 5EA8 - yaw rate sensor: Controller Release System (CRS) - suspected error with measuring range DRS.
0x5eaa 5EAA - yaw rate sensor: Controller Release System (CRS) - suspected error with intentional signal disruption (Dynamic Bite).
0x5f7a 5F7A - yaw rate sensor: DRS error associated with DRS_1.
0x5f66 5F66 - yawrate sensor2: DRS2-ID does not match the requested ID.
0x5f67 5F67 - yawrate sensor2: checksum of received DRS messages is incorrect.
0x5f68 5F68 - yawrate sensor2: error of ERR or TERR bits. No additional information (ERRNO = 0).
0x5f69 5F69 - yawrate sensor2: Internal yawing value outside of range (DrsERRNO1).
0x5f6a 5F6A - yawrate sensor2: Internal reference variable outside of range (DrsERRNO3).
0x5f6b 5F6B - yawrate sensor2: received message too early (DrsERRNO5).
0x5f6c 5F6C - yawrate sensor2: voltage supply too low (DrsERRNO6).
0x5f6d 5F6D - yawrate sensor2: voltage supply too high (DrsERRNO7).
0x5f6e 5F6E - yawrate sensor2: Sensor in initialision (DrsERRNO8).
0x5f7b 5F7B - yaw rate sensor: DRS-error associated with DRS_2.
0x5ee2 5EE2 - pressure sensor: plausibility pressure sensor signal_lines . (DS-Typ 5: DSLine+DSLine2 = 5Volt).
0x5ee4 5EE4 - pressure sensor: error in voltage supply.
0x5ee5 5EE5 - pressure sensor: line fault.
0x5ee6 5EE6 - pressure sensor: line fault. signal inverted.
0x5ee7 5EE7 - pressure sensor: error with Power Up self-test (POS).
0x5eed 5EED - pressure sensor: DS offset invalid.
0x5ec4 5EC4 - pressure sensor: Test pulse error.
0x5f28 5F28 - pressure sensor: line error of temperature signal. - short circuit on +12V, ground?
0x5f29 5F29 - pressure sensor: Temperature signal error. Parity failure, Transmission error (Ds-Typ DS5).
0x5f2a 5F2A - pressure sensor: Temperature signal outside of range (DS-Typ DS5).
0x5e86 5E86 - internal pressure sensor Mc1: error in voltage supply (ciruit 1).
0x5edd 5EDD - internal pressure sensor Mc1: error with Power On self-test .
0x5ede 5EDE - internal pressure sensor Mc1: line fault channel 1.
0x5edf 5EDF - internal pressure sensor Mc1: line fault channel 2.
0x5ee1 5EE1 - internal pressure sensor Mc1: plausibility fault.
0x5e87 5E87 - pressure sensor Ci1: error in voltage supply (ciruit 1).
0x5ee3 5EE3 - pressure sensor Ci1: Error with Power-On self-test .
0x5ee8 5EE8 - pressure sensor Ci1: channel 1 line fault.
0x5ee9 5EE9 - pressure sensor Ci1: channel 2 line fault.
0x5eea 5EEA - pressure sensor Ci1: plausibility fault.
0x5e88 5E88 - pressure sensor Ci2: error in voltage supply (ciruit 2).
0x5eeb 5EEB - pressure sensor Ci2: Error with Power-On self-test .
0x5eec 5EEC - pressure sensor Ci2: channel 1 line fault.
0x5ef1 5EF1 - pressure sensor Ci2: channel 2 line fault.
0x5f27 5F27 - pressure sensor Ci2: plausibility fault.
0x5eba 5EBA - steering angle sensor: status error. steering angle Signal invalid or steering angle Signal only relative. centre position unknown. leared quadrant active. turn onto end position.
0x5ebb 5EBB - steering angle sensor: signal fault - proof good test required.
0x5ebc 5EBC - steering angle sensor: sign error.
0x5ebd 5EBD - steering angle sensor: Signal remains at constant level.
0x5ebe 5EBE - steering angle sensor: range LWS.
0x5ebf 5EBF - steering angle sensor: signal gradient LWS.
0x5ec0 5EC0 - steering angle sensor: long-term offset falls below limit.
0x5ec1 5EC1 - steering angle sensor: plausibility error for speed sensor .
0x5ec5 5EC5 - steering angle sensor: CAN-message counter reports error.
0x5f0d 5F0D - steering angle sensor: Segment-segment find algorithm found wrong segment.
0x5f0e 5F0E - steering angle sensor: SFA no sector was found at a speed > 25 km/h - temporary Error.
0x5f63 5F63 - steering angle sensor: LWS not matched (LWS-Typ: LWS4,RWDT_STEA_WHL).
0x5ec6 5EC6 - steering angle sensor: signal not OK.
0x5ec7 5EC7 - steering angle sensor: serial number invalid.
0x5ec8 5EC8 - steering angle sensor: Signal STWA_TOP=invalid received.
0x5ec9 5EC9 - steering angle sensor: the LWS-serial number stored in DXC is incorrect.
0x5eca 5ECA - steering angle sensor: read out of the stored LWS serial number failed.steering angle sensor calibration required
0x5ecb 5ECB - steering angle sensor: Signal STWA_TOP_COMP in F-CAN-Botschaft LENKRADWINKEL_OBEN (ID C9h) invalid.
0x6dc6 6DC6 - steering angle sensor: SZL code Timeout
0x6dc7 6DC7 - steering angle sensor: SZL not encoded
0x6dc8 6DC8 - steering angle sensor: Signal ALIV_COU_STWA_TOP in F-CAN-message LENKRADWINKEL_OBEN2 (ID 0xC9) received.
0x5ed4 5ED4 - implausible DSC controlling: Yawing regulation (FZR controlling) not plausible.
0x5ed5 5ED5 - implausible DSC controlling: emergency brake initiated (due to implausible control: blockage of wheels enabled).
0x5ed6 5ED6 - Info: longterm calibration: LWS-, DRS- und AY-sensor-longterm calibration deactivated.
0x5eda 5EDA - variant code: coding value not permissible in EEPROM.
0x5edb 5EDB - variant code: coding value outside of range.
0x5edc 5EDC - variant code: coding value not released for this project. vehicle variant sent by CAS is not accepted
0x5efb 5EFB - variant code: variant switch could not be read from EEPROM.
0x5efc 5EFC - variant code: no vehicle type data received.
0x5efd 5EFD - Info: variant code: new variant coding value set.
0x5f23 5F23 - variant code: EEPROM configuration ACB Hba Value in EEPROM invalid.
0x5f2c 5F2C - variant code: EEPROM content invalid.
0x5f60 5F60 - variant code value does not match to the vehicle.
0x5f18 5F18 - variant code: EEPROM Configuration FZR: trailer stability control value in EEPROM invalid.
0x5f4d 5F4D - variant code: ASWVARCON not possible to read.
0x6dc4 6DC4 - variant code: variant code invalid.
0x6dc5 6DC5 - variant code: SZL Coding byte does not exist, DXC execute Coding procedure.
0x5f1e 5F1E - Info: variant code: trailer stabilization logic deactivated through EEPROM.
0x5ef9 5EF9 - DSC-Software: ECU-internal: Timeout in software startup phase.
0x5efa 5EFA - DSC-Software: ECU-internal: asynchronous computing cycle (task) counter in Software.
0x5f20 5F20 - DSC-Software: ECU-internal: Software requests full shutdown of system.
0x5f21 5F21 - DSC-Software: ECU-internal: Software only requests EBV function.
0x5f22 5F22 - DSC-Software: ECU-internal: Software requests ABS function only.
0x5f30 5F30 - DME-Error: DME sends engine speed=invalid.
0x5f31 5F31 - DME-Error: DME sends medium_effective torque=invalid.
0x5f32 5F32 - DME-Error: DME sends unprocessed_gas pedal=invalid.
0x5f33 5F33 - DME-Error: feedback from requested DME servo unit (ASR,MSR) is zero.
0x5f34 5F34 - DME-Error: check sum or timeout errors in the message TORQUE_1.
0x5f35 5F35 - DME-Error: check sum or timeout errors in the message TORQUE_2.
0x5f36 5F36 - DME-Error: check sum or timeout errors in the message TORQUE_3.
0x5f6f 5F6F - DME-Error: DME sends torque_current_value=invalid (PT-CAN, ID 0xA8, Signal TORQ_AVL).
0x5f70 5F70 - DME-Error: DME sends status clutch switch=invalid (PT-CAN, ID 0xA8, Signal ST_SW_CLT).
0x5f71 5F71 - DME-Error: DME sends torque_current_minimum=invalid (PT-CAN,ID 0xA9, Signal TORQ_AVL_MIN).
0x5f72 5F72 - DME-Error: DME sends torque_current_maximum=invalid (PT-CAN,ID 0xA9, Signal TORQ_AVL_MAX).
0x5f73 5F73 - DME-Error: DME sends torque value=invalid (PT-CAN, ID 0xA9, Signal TORQ_AVL_SPAR_POS).
0x5f74 5F74 - DME-Error: DME sends angle of accelerator=invalid (PT-CAN, ID 0xAA, Signal ANG_ACPD).
0x5f75 5F75 - DME-Error: DME sends torque_driver_choice=invalid (PT-CAN, ID 0xAA, Signal TORQ_DVCH).
0x5f76 5F76 - DME-Error: DME sends value engine speed=invalid (PT-CAN ID 0x0AA, Signal RPM_ENG).
0x5f77 5F77 - DME-Error: DME sends torque value=invalid (PT-CAN, ID 0xA8, Signal ST_RCPT_ENG_DSC).
0x5f78 5F78 - DME-Error: DME sends status of motor=invalid (PT-CAN, ID 0xA8, Signal ST_RCPT_ENG_DSC).
0x5f2e 5F2E - EGS-Error: EGS sends EGS_not_alive ODER checksum invalid (PT-CAN, ID 0xBA, Signal ALIV_GRB, CHKSM_GRB).
0x5f2f 5F2F - EGS-Error: EGS sends gearbox_status=invalid ODER gear shift lever=invalid ODER gearbox_negativelift=invalid (PT-CAN, ID 0xBA, Signal RPM_GRB_NEGL, ST_GRLV_ACV, ST_GR_GRB).
0x5f07 5F07 - DSC-ACC-interface: Timeout when receiving CAN messages for ACC.
0x5f08 5F08 - DSC-Acc-interface (ECD): ACC sends ACC not alive (PT-CAN, ID 0xAD, Signal ALIV_DCRN_BRP_ACC).
0x5f09 5F09 - DSC-Acc-interface (ECD): ACC sends valid check of the fixed value failed (PT-CAN, ID 0xAD, Signal ST_DCRN_BRP_TAR_ACC, DCRN_BRP_TAR_ACC).
0x5f2d 5F2D - DSC-Acc-interface (ECD): ACC sends checksum of received ACC message is incorrect (PT-CAN, ID 0xAD, Signal CHKSM_DCRN_BRP_ACC).
0x5f25 5F25 - ARS-ECU: Timeout while receipt of CAN messages (temporarily curable fault).
0x5f26 5F26 - ARS-ECU: ARS alive-Error (message ID 0x1AC, Signal ALIV_COU_ARS).
0x5f1f 5F1F - ARS-ECU: ARS reports status invalid (message ID 0x1AC, Signal ST_ARS).
0x5f10 5F10 - brake pad wear: front axle sensorcheck failed. - BBV-sensor disconnected?
0x5f12 5F12 - brake pad wear: front axle wear limit reached.
0x5f14 5F14 - brake pad wear: plausibility fault. wear conditions ot the BBV front axle sensor does not match to the calculated wear value or does not match to the reset value.
0x5f11 5F11 - brake pad wear: rear axle sensorcheck failed. - BBV-sensor disconnected?
0x5f13 5F13 - brake pad wear: rear axle wear limit reached.
0x5f15 5F15 - brake pad wear: plausibility fault. wear conditions ot the BBV rear axle sensor does not match to the calculated wear value or does not match to the reset value.
0x5f1a 5F1A - Info: Performance reduction activated through DSC command.
0x5f1b 5F1B - Info: Performance reduction deactivated through DSC command.
0x5f1c 5F1C - Info: active brake interference with overheated brake pads.
0x5ef2 5EF2 - pressure sensor_ACC_front: Offset-Error.
0x5ef4 5EF4 - pressure sensor_ACC_front: Plausibility error.
0x5ef6 5EF6 - pressure sensor_ACC_front: line fault (DS2Add1).
0x5ef8 5EF8 - pressure sensor_ACC_front: voltage supply error.
0x5ef3 5EF3 - pressure sensor_ACC_rear: Offset-Error.
0x5ef5 5EF5 - pressure sensor_ACC_rear: Plausibility error.
0x5ef7 5EF7 - pressure sensor_ACC_rear: voltage supply error.
0x5f50 5F50 - valves general: over temperature error.
0x5f45 5F45 - brake fluid level too low.
0x5f47 5F47 - instrument cluster: instrument cluster Alive-Error.
0x5f48 5F48 - instrument cluster: instrument cluster sends time or temperature=invalid (PT-CAN, ID 0x310, Signal TEMP_EX,T_SEC_COU_REL)
0x5f49 5F49 - instrument cluster: instrument cluster sends milage=invalid (PT-CAN, ID 0x330, Signal MILE_KM)
0x5f4a 5F4A - instrument cluster: instrument cluster sends brake pad wear_front_or_rear=invalid
0x5f4b 5F4B - instrument cluster: instrument cluster sends status_handbrake switch=invalid (PT-CAN, ID 0x1B4, Signal ST_IDLI_HABR)
0x5f5c 5F5C - CAN-message/instrument cluster: trailer stabilization logic because of CAN-message INSTR3 (ID 0x615) deactivated
0x5e65 5E65 - instrument cluster: OP_PUBU_DSC Signal invalid (message BEDIENUNG_TASTER_DSC, ID 0x316)
0x5ec3 5EC3 - instrument cluster: OP_PUBU_TPCT Signal invalid (message BEDIENUNG_TASTER_RDC, ID 0x319)
0x5f52 5F52 - CCC/MASK-Error: CCC reports operation_tire pressure control invalid
0xD36A D36A - PT-CAN: message STAT_SOLL_MOM_UMSETZUNG (ID 0x0BC) not received or wrong message length (DLC). [transmitter:VGSG]
0x5de7 5DE7 - clutch gearbox-ECU: VG-ECU Reports: function test failed
0x5de8 5DE8 - clutch gearbox-ECU: clutch deactivated through diagnostics
0x5de9 5DE9 - Info: clutch gearbox-ECU: VG-ECU reports uncomfortable VG clutch control (PT-CAN, 0xBC, Signal ST_TXU_ERR)
0x5dea 5DEA - Info: clutch gearbox-ECU: reduced moment governing due to friction in VG
0x5dec 5DEC - clutch gearbox-ECU: clutch temporarily deactivated
0x5f39 5F39 - clutch gearbox-ECU: VG-clutch defective - position of clutch unknown
0x5f3a 5F3A - clutch gearbox-ECU: VG-clutch defective - clutch is open - rear wheel drive!
0x5f3b 5F3B - Info: clutch gearbox-ECU: VG-ECU reports loss in placement accuracy. Uncomfortable control (PT-CAN, ID 0xBC, Signal ST_TXU_Err).
0x5f3c 5F3C - is executing the torque request not satisfactionelly
0x5f3d 5F3D - clutch gearbox-ECU: VG-Clutch does not transmit drive torque to front axle. Target values not executed- ALL-WHEEL DRIVE LOSS
0x5f3e 5F3E - clutch gearbox-ECU: message ST_WEAR_DISK (ID 0x376h): Signal_disk sends error code
0x5f3f 5F3F - clutch gearbox-ECU: message ST_WEAR_DISK (ID 0x376h): signal_Kette sends error code
0x5f41 5F41 - Info: clutch gearbox-ECU: emergency control of power take-off gear clutch enable. control of power take-off gear adopted adjustment control of clutch)
0x6dc9 6DC9 - Info: clutch gearbox-ECU: End-of-line test is running ? expected end after 30 sec.
0x6dca 6DCA - clutch gearbox-ECU: End-of-line test failed. VG-clutch is not working!
0x5f54 5F54 - CAS: Fahrgestell-NR ungueltig
0x5f55 5F55 - CAS: Motor-Typ ungueltig
0x5f56 5F56 - CAS: CAS sendet Signal KL_15 invalid oder Signal KL_R invalid oder Unplausibilitaet zwischen Signal KL_15 und WakeUp Signal (PT-Can (ID 0x130h),Signal ST_KL_R,ST_KL_15).
0x5f57 5F57 - CAN: general CAN fault Time-Out alle CAS Botschaften (ID 0x130h),(ID 0x380h),(ID 0x388h)
0x5f61 5F61 - AFS: AFS reports status invalid (message ID 0x1FC, Signal ST_FN_AFS)
0x5f62 5F62 - AFS: signal exchange AFS-DSC invalid
0x5f79 5F79 - trailer module: trailer-Signal invalid
0x5f51 5F51 - Hydraulic brake assistant : EEPROM-invalid entry (HPS, HVV)
0x5f53 5F53 - Hill Descent Control: HDC EEPROM invalid entry
0x5ecc 5ECC - Hill Descent Control: MASK/CCC sends Operation_HDC=invalid. (PT-CAN, use_chassis ID 398h, Signal OP_HDC)
0x5ecd 5ECD - Hill Descent Control: MASK/CCC sends Signal=invalid. (PT-CAN, use_special function ID 228h, Signal ID_SPFN)
0x5ece 5ECE - Hill Descent Control: SZL sends Signal_Checksumme or Signal_Alive=invalid. (use_speed control ID 194h, Signal CHKSM_CCTR, ALIV_CCTR)
0x5ecf 5ECF - Hill Descent Control: SZL sends Signal_OpPUshButtonAcc=invalid. (use_speed control ID 194h, Signal OpPushButtonACC)
0x5ed0 5ED0 - Hill Descent Control: SZL sends Signal_OpGapcAcc=invalid. (use_speed control ID 194h, Signal OpGapcAcc)
0x5ed1 5ED1 - Hill Descent Control: SZL sends Signal_OpModChoCcca=invalid. (use_speed control ID 194h, Signal OpModChoCcca)
0x5f2b 5F2B - PT-Can: message ANZEIGE_HDC (ID 0x32D) could not be sent (sent by DSC ECU)
0x5f4e 5F4E - Hill Descent Control: MASK/CCC sends Signal_Taster_HDC=invalid. (PT-CAN, use_push button_HDC ID 31Ah, Signal OP_PUBU_HDC)
0x5f5d 5F5D - Electronic brake pre-filling: EEPROM-entry of EVB function invalid
0x6dcb 6DCB - Electronic brake pre-filling: Signal ST_CLCTR_V in PT-CAN-message TORQUE_3 (ID 0xAA) invalid
0x5f5e 5F5E - brake pad wiper: EEPROM entry invalid
0x5f5f 5F5F - hill-hold startup assistant: EEPROM entry invalid
0xD374 D374 - PT-CAN: message STAT_GANG_RUECKWAERTS (ID 0x3B0) not received or wrong message length (DLC). [transmitter: LM]
0x5f7c 5F7C - DSC-ECU: ECU-internal: VAFS-Prozessor: VAFS-SP-Interface transfer fault of the VAFS-Controllers
0x5f7d 5F7D - DSC-ECU: ECU-internal: VAFS-Prozessor: wrong memory access on VAFS-Controller
0x5f7e 5F7E - DSC-ECU: ECU-internal: VAFS-Prozessor: ADC calibration of VAFS-Controllers
0x5f7f 5F7F - DSC-ECU: ECU-internal: VAFS-Prozessor: ADC conversion start failure on VAFS-Controllers
0x5f80 5F80 - DSC-ECU: ECU-internal: VAFS-Prozessor: ADC transfer fault of the VAFS-Controllers
0x5f81 5F81 - DSC-ECU: ECU-internal: VAFS-Prozessor: software transfer fault (ASW-PSW)
0x5f82 5F82 - DSC-ECU: ECU-internal: VAFS-Prozessor: general HSW-error of VAFS-Controllers
0x5f83 5F83 - DSC-ECU: ECU-internal: VAFS-Prozessor: CAN-hardware error of VAFS-Controllers
0x5f84 5F84 - DSC-ECU: ECU-internal: VAFS-Prozessor: CAN message-timeout of VAFS-Controller
0x5f85 5F85 - DSC-ECU: ECU-internal: VAFS-Prozessor: CAN signal fault ot the VAFS-Controllers
0x5f86 5F86 - DSC-ECU: ECU-internal: VAFS-Prozessor: general VAFS-error of VAFS-Controllers
0x5f44 5F44 - clutch: clutch pedal never activated
0x5f46 5F46 - clutch: clutch pedal permanently activated
0x5ed7 5ED7 - Reverse gear switch: monitoring reports: switch permanent backward
0x5ed8 5ED8 - Reverse gear switch: monitoring reports: switch permanent forward
0x5ed9 5ED9 - PT-CAN: Signal STATUS_GEAR_BACKWARDS in message STATUS_GANG_RUECKWAERTS (ID 3B0h) invalid (used by Hill-Hold-Function)
0x5ed2 5ED2 - brake pad wiper: RLS sends invalid signals in message REGENSENSOR_WISCHERGESCHWINDIGKEIT (PT-CAN, ID 0x226)
0x5ed3 5ED3 - brake pad wiper: SZL sends signal OP_WISW=invalid (F-CAN, ID 0x2a6, Signal OP_WISW)
0xD383 D383 - LDM-Error: checksum error
0x6f4b 6F4B - LDM-Error: Alive-Error
0x6e59 6E59 - LDM-Error: monitoring accelerator pedal, LDM-brake request against accelerator pedal inplausible
0x6df8 6DF8 - LDM-Error: monitoring release, LDM-brake request without release
0x5e55 5E55 - CAN-Error: message LDM_Anforderung_Radmoment_Sollwert invalid
0x5e56 5E56 - CAN-Error: message G237 LDM_Anforderung_Radmoment_Sollwertverteilung (vorne/hinten) invalid.
0x5e53 5E53 - Info: Hydraulische Fading Control: HFC is active for more than 500 ms and temperature of the brake discs is over the limit 550 degrees
0x5e54 5E54 - Info: Hydraulische Fading Control: HFC is active and temperature of the brake discs is over the limit 700 degrees
0x60ac 60AC - detection deflation system: RPA coding data inplausible
0x60ad 60AD - detection deflation system: RPA standardisation data inplausible
0x60ae 60AE - detection deflation system: RPA-FASTA-Data inplausible
0x60af 60AF - detection deflation system: RPA inactive due to overly large pneumatic suspension height difference at the front axle
0x60b0 60B0 - detection deflation system: RPA inactive due to overly large pneumatic suspension height difference at the rear axle
0x94B0 94B0 - SZL: error entry for SZL: LWS-Error: synchronisation via Sub impossible
0x94B1 94B1 - SZL: error entry for SZL: LWS-Error: connection test for PDA abortive
0x94B2 94B2 - SZL: error entry for SZL: LWS-Error: light of ambience too bright
0x94B3 94B3 - SZL: error entry for SZL: LWS-Error: no referring trace found
0x94B4 94B4 - SZL: error entry for SZL: LWS-Error: sensor error: distance of referring trace out of range
0x94B5 94B5 - SZL: error entry for SZL: LWS-Error: illigal code
0x94B6 94B6 - SZL: error entry for SZL: LWS-Error: angle step too large
0x94B7 94B7 - SZL: error entry for SZL: LWS-Error: measuring range exceeded (overflow)
0x94B8 94B8 - SZL: error entry for SZL: LWS-Error: angle verification via Main and Sub incorrect
0x94B9 94B9 - SZL: error entry for SZL: LWS-Error: LWS not calibrated: EEPROM defective
0x94BA 94BA - DSC-SZL: error entry for SZL: exposure time=0
0x94BB 94BB - DSC-SZL: error entry for SZL: dropping by comparator
0x94BC 94BC - DSC-SZL: error entry for SZL: CRC Error in coding data block
0x94BD 94BD - DSC-SZL: error entry for SZL: CRC Error within limits of RAM save
0x94BE 94BE - DSC-SZL: error entry for SZL: digital angle out of range Praediktionsbereich
0x94BF 94BF - DSC-SZL: error entry for SZL: StartUp process communication Timeout
0x94C0 94C0 - DSC-SZL: error entry for SZL: WakeUp TimeOut illumination control
0x94C1 94C1 - DSC-SZL: error entry for SZL: Error 16
0x94C2 94C2 - DSC-SZL: error entry for SZL: LWS not matched
0x94C3 94C3 - DSC-SZL: error entry for SZL: general sensor error
0x94C4 94C4 - DSC-SZL: error entry for SZL: reference trace not found
0x94C5 94C5 - DSC-SZL: error entry for SZL: CRC Error within limits of RAM save
0x94C6 94C6 - DSC-SZL: error entry for SZL: reserved for CRC refering trace
0x94C7 94C7 - DSC-SZL: error entry for SZL: StartUp LWS Shadow zero point data CRC Error
0x94C8 94C8 - DSC-SZL: error entry for SZL: StartUp LWS Shadow end of line data CRC Error
0x94C9 94C9 - DSC-SZL: error entry for SZL: StartUp EEPROM loading not successful
0xC987 C987 - SZL: error entry for SZL: LWS-Error: no message on F-CAN. BusOff-Error.
0xC995 C995 - SZL: error entry for SZL: LWS-Error: Signal or value above threshold, not used wheel speed >300km/h: F-CAN wheel speed, communication with DSC.
0xC996 C996 - SZL: error entry for SZL: LWS-Error: Signal or value below threshold wheel speed < 300km/h: F-CAN wheel speed, communication with DSC.
0xC998 C998 - SZL: error entry for SZL: LWS-Error: Signal or value below threshold wheel tolerance comparison < -5%: F-CAN wheel tolerance comparison, communication with DSC.
0xC99A C99A - SZL: error entry for SZL: LWS-Error: Signal or value above threshold, not used wheel tolerance comparison > 5%: F-CAN wheel tolerance comparison, communication with DSC.
0xC994 C994 - SZL: error entry for SZL: LWS-Error: no signal or value timeout (message not received within implemented time): F-CAN wheel speed, communication with DSC.
0xC997 C997 - SZL: error entry for SZL: LWS-Error: no signal or value timeout (message not received within implemented time): F-CAN wheel tolerance comparison, communication with DSC.
0xC99B C99B - SZL: error entry for SZL: LWS-Error: no signal or value timeout (message not received within implemented time): F-CAN Sync.
0xC99C C99C - SZL: error entry for SZL: LWS-Error: no signal or value timeout (message not received within implemented time): no communication with DSC.
0x94E0 94E0 - SZL: error entry for SZL: LWS-Error: EEPROM - defective: Prozessor defective.
0x9500 9500 - SZL: error entry for SZL: LWS-Error: low voltage: UBatt < 8.5 V.
0x9501 9501 - SZL: error entry for SZL: LWS-Error: high voltage: UBatt > 16,5 V.
0x9510 9510 - SZL: error entry for SZL: LWS-Error: FGR/ACC-Switch hanging(all pushable switches): mechanical problem, contact.
0x9511 9511 - SZL: error entry for SZL: LWS-Error: FGR/ACC-Switch inplausible: incorrect combination occurred in speed control switch.
0x9512 9512 - SZL: error entry for SZL: LWS-Error: FGR/ACC-Switch defective : voltage coded arm (recall / ACC) interrupted as the case may be short circuit or LED interrupted / short circuit.
0x9518 9518 - SZL: error entry for SZL: LWS-Error: switch for windscreen wiper (all pushable switches): mechanical problem, contact.
0x9519 9519 - SZL: error entry for SZL: LWS-Error: switch for windscreen wiper inplausible: incorrect combination occurred in switch of windscreen wiper.
0x951A 951A - SZL: error entry for SZL: LWS-Error: switch for windscreen wiper -switch defect : voltage coded arm (RS / IntervallPoti) interrupted as the case may be Kurzschluß-LED unterbrochen / short circuit or LED interrupted / short circuit.
0x9520 9520 - SZL: error entry for SZL: LWS-Error: switch for audio/telephone: mechanical problem, contact.
0x6dd1 6DD1 - ECU: detection of wrong HET execution speed(e.g.caused by mismatched HET prescale factors).
0x6dd2 6DD2 - ECU: wrong HET duty cycle(HetPin 14 is tested with a test duty).
0x6dd3 6DD3 - wheel speed sensor front left: WssFl speed comparison (MonCTM) to sec. path (AS/SCON) failed.
0x6dd4 6DD4 - wheel speed sensor rear left: WssRl speed comparison (MonCTM) to sec. path (AS/SCON) failed.
0x6dd5 6DD5 - wheel speed sensor rear right: WssRr speed comparison (MonCTM) to sec. path (AS/SCON) failed.
0x6dd6 6DD6 - wheel speed sensor front right: WssFr speed comparison (MonCTM) to sec. path (AS/SCON) failed.
0x6dd7 6DD7 - gearbox: Signal ST_RSTA Invalid in CanMsgGETRIEBEDATEN.
0x6f52 6F52 - CAN-Error: message LENKRADWINKEL_OBEN_2 (0xC9h) missed or wrong DLC received (DLC).
0x6dd8 6DD8 - Kombi-Error: SignalFRC_INTM_WAY_BOS_RSTG_2_F invalid in CanMsgBOS_RUECKSTELLUNG.
0x6dd9 6DD9 - Kombi-Error: SignalFRC_INTM_WAY_BOS_RSTG_2_R invalid in CanMsgBOS_RUECKSTELLUNG.
0x6df1 6DF1 - Varianten codierung EEPROM Konfiguration VHC ungueltig
0x6df2 6DF2 - Getriebefehler: Signal ST_MOD_GRB in CAN message gear box data inplausible
0x6df3 6DF3 - ECU intern: VAFS (Value Added Function Server) versions incompatible
0x6df4 6DF4 - ECU intern: VAFS (Value Added Function Server) Transfer Timeout
0x6df5 6DF5 - ECU intern: VAFS (Value Added Function Server) Data Checksum Error
0x6df6 6DF6 - ECU intern: VAFS (Value Added Function Server) general Spi Error
0x6dff 6DFF- DSC-ECU: ECU-internal: RAM-buffer for parameter invalid
0x6e0d 6E0D - internal pressure sensor Mc1: temperature of pressure sensor am brake main cylinder 1 outside of valid range
0x6e0f 6E0F - DCC: Error in Interface to instrument cluster
0x6e11 6E11 - DCC: acceleration while control cycle too wide
0x6e12 6E12 - DCC: deacceleration while control cycle too wide
0x6e13 6E13 - DCC: brake request current not permitted
0x6e14 6E14 - DCC: acceleration request current not permitted
0x6e15 6E15 - DCC: the controller
0x6e16 6E16 - DCC: parameter error
0x6e17 6E17 - DCC: plausibility failure (Phz against BLS while DCC acceleration)
0x6e18 6E18 - DCC: plausibility failure (angle of acceleration pedal while DCC brake maneuver)
0x6e19 6E19 - DCC: release nicht abgewartet
0x6e1b 6E1B - PT-CAN: message ANF_RADMOM_PT (ID 0xBF) could not be sent (Sent by DSC-SG).
0x6e1c 6E1C - PT-CAN: message ANZEIGE_ACC_DCC (ID 0x193) could not be sent (Sent by DSC-SG).
0x6e1d 6E1D - DME-Error: Alive-Counter der empfangenen DME-message RADMOM_PT_1 (PT-CAN, ID 0xB4) falsch.
0x6e1e 6E1E - DME-Error: checksum der empfangenen DME-message RADMOM_PT_1 (PT-CAN, ID 0xB4) falsch.
0x6e1f 6E1F - DME-Error: Alive-Counter der empfangenen DME-message RADMOM_PT_2 (PT-CAN, ID 0xAC) falsch.
0x6e20 6E20 - DME-Error: checksum der empfangenen DME-message RADMOM_PT_2 (PT-CAN, ID 0xAC) falsch.
0x6e21 6E21 - DME-Error: DME sends ST_INTF_PT=invalid (PT-CAN, RADMOM_PT_1, ID 0xB4).
0x6e22 6E22 - DME-Error: DME sends ST_PENG=invalid (PT-CAN, RADMOM_PT_1, ID 0xB4).
0x6e23 6E23 - DME-Error: DME sends WMOM_PT_AVL=invalid (PT-CAN, RADMOM_PT_1, ID 0xB4).
0x6e24 6E24 - DME-Error: DME sends ANG_ACPED_REAL=invalid (PT-CAN, RADMOM_PT_1, ID 0xB4).
0x6e25 6E25 - DME-Error: DME sends WMOM_PT_MAX=invalid (PT-CAN, RADMOM_PT_2, ID 0xAC).
0x6e26 6E26 - DME-Error: DME sends WMOM_PT_MIN_LOW=invalid (PT-CAN, RADMOM_PT_2, ID0xAC).
0x6e30 6E30 - internal pressure sensor Mc1: Plauisibilitaet of one pressure sensor against BLS falsch.
0x6e31 6E31 - internal pressure sensor Mc1: Plauisibilitaet of 3 pressure sensors against BLS falsch.
0x6e32 6E32 - internal pressure sensor Mc1: Offseterror.
0x6e33 6E33 - internal pressure sensor Mc1: testpulse error.
0x6e4a 6E4A - Ventil Relais: VR not off, while Watchdog suppressed (FSA)
0x6e52 6E52 - DCC: Level 2 switch off (no Reaktion on Level 1 switch off)
0x6e53 6E53 - F-Can: invalid Signals in message BEDIENUNG_TEMPOMAT (0x194)
0x6e54 6E54 - variant code: invalid variant value causes timeout beim Parameteraustausch
0x6e58 6E58 - yaw rate sensor: Info-Block not complete received. (DRS Typ MM 3.x)
0x6e84 6E84 - DCC: Error beim DCC EEPROM by reading data (EEPROM Error)
0x6f65 6F65 - PT-CAN: message STAT_KOMBI (ID 0x1B4) wrong checksum or Alive-counter Error
0x6f56 6F56 - PT-CAN: message RADMOM_PT_1 (ID (0xB4) not received [transmitter: DME]
0x6f57 6F57 - PT-CAN: message RADMOM_PT_2 (ID (0xAC) not received [transmitter: DME]
0x6d95 6D95 - DSC-ECU: ECU-internal: Analog Digital converter: Self test Error
0x6d97 6D97 - DSC-ECU: ECU-internal: System IC timing faulty
0x6E60 6E60 - CAN-Error: message LDM_request_wheel_torque_brake Signal WmomEcbaEnb invalid
0x6E92 6E92 - coding Error: message D5 received however ECU coded on DCC features
0x6DF7 6DF7 - PT-Can: message BESCHL_DATEN (ID 0x2B3) could not be sent (sent by DSC ECU)
0x6E49 6E49 - RDC - Signal StatusBreakDownTyre invalid
0x6E78 6E78 - SW Reset while VRoff or ELoff -turn IG off/on.
0x6E79 8E79 - DSC-ECU: FSA -Voltage to low for valve relais test to execute
0x6E7B 6E7B - DSC-ECU: ADC Selftest Error in VAFS controller
0x6E80 6E80 - Brake overheated while ECBA- control cycle
0x6E81 6E81 - break pad sensor front: line fault
0X6E82 6E82 - break pad sensor rear: line fault
0x6E9E 6E9E - EMF: CRC Error SafgRqWmomEmf (RQ_WMOM_EMF QU_RQ_WMOM_EMF)
0x6E9F 6E9F - EMF: RQ_WMOM_EMF QU_RQ_WMOM_EMF permanent inconsistent
0x6EA0 6EA0 - EMF: RQ_WMOM_EMF QU_RQ_WMOM_EMFtemporarily faulty
0x6EA1 6EA1 - PT-CAN: message VEH_MOD (0x315) signal ADJU_MOD_VEH invalid
0x6EA2 6EA2 - EEPROM: Configuration SW_Sperre in EEPROM invalid
0x6EA3 6EA3 - EMF: Signal ST_ACT_EMF invalid
0x6F63 6F63 - RDC: message STAT_RDC wrong DLC or message not received
0x6F70 6F70 - EMF: message ST_RQ_EMF (0x1FD) wrong DLC or message not received
0x6F71 6F71 - EMF: message ST_RQ_EMF (0x1F1) wrong checksum or Alive-counter Error
0x6F72 6F72 - EMF: message VEH_MOD (0x315) wrong DLC or message not received
0x6F73 6F73 - EMF :message VEH_MOD (0x315) wrong checksum or Alive-counter Error
0x6E9B 6E9B - variant code faulty
0x6EA6 6EA6 - PT-CAN: message MSA (ID 0x308) Signal ST_MSA_FN invalid
0x6EA7 6EA7 - PT-CAN: message MSA (ID 0x308) Signal ANO_ENG_STA_STOP_MSA invalid
0x6EA8 6EA8 - PT-CAN: message MSA (ID 0x308) Signal RQ_ENG_STA_MSA invalid
0x6F74 6F74 - PT-CAN: message MSA (ID 0x308) Timeout
0x6F75 6F75 - PT-CAN: message MSA (ID 0x308) wrong checksum or Alive-counter Error
0x6EC2 6EC2 - EEPROM Configuration REF invalid, supported by Ax-signal
0x6EC3 6EC3 - steering angle Sensor: Signal invalid, status Error
0x6EC4 6EC4 - steering angle sensor: status Error. steering angle Signal invalid or steering angle Signal only relative. centre position unknown. leared quadrant active. turn onto end position
0x6EC5 6EC5 - variant code faulty vehicle variante 0x00 invalid
0x6EC6 6EC6 - variant code faulty vehicle idenification number not readable
0xFFFF Unknown error location
