Wow...just "a bit" of a difference. Hah! Looking good!
Which reminds me...I need to start tearing into the M62TU I pulled out of my 540iT...
Alvin Caragay
Mpire Automotive (https://www.facebook.com/MpireAutomotive/)
'96 AC Schnitzer S3 Sport CLS Replica (https://www.facebook.com/ACSS3SportCLSR)
'02 E39 540iAT
That's an impressive transformation
Thanks everyone it's been a long task but I've loved doing it!
The car will come in the garage tomorrow once I've made space and I'll start pulling the 7 cylinder out its done its job
will be a week or so till the standalone arrives so waiting on that so not a massive rush to get it in can take my time on it really
I'm definitely suffering from engine envy
Absinthe makes the tart grow fonder
Wow, that's some tight confines.... Do you crawl in thru the sunroof?
Is your buddy brushing his teeth there??
NICE!! What does the (332) mean?
That's wheel hp I think. 16% loss I saw on the screen
Nice low rpm torque! Are those crank hp and tq?
Nice numbers! I plan to dyno my car in a few months with my 4.5 and jag supercharger
E85 fueled, Eaton m112 supercharged 4.5L M62TU, TTV racing flywheel, Spec stage 2+ clutch, 88c thermostat, eibach sway bars, wavetrac 3.15 lsd, m5 steering box, Quantum 340lph fuel pump, Dinan camber plates, some powerflex bushings, Supersprint headers, M5 cats, 2001 gas pedal upgrade and many other things done. all diy by me
385hp crank. 332hp at the wheels I think works out as a 16% drivetrain loss.
How hot the manifold got i think it needs something more free flowing to free more horses up the tu manifolds are just rubbish.
The torque feels a proper animal being that low down
I can't remember the specs of the bottom end build on this one Jon. Are you doing anything to alleviate the normal bottom end problems that seem to occur with serious low-end torque? You're making a fair bit there!
All I've got is widened ring gap and decompression rods what else should I of done?
Personally I think that should be all you need. This should be excellent!!
Yeah, I just couldn't remember what all you had done when you put this one together. Sorry for causing alarm!
Is the torque also corrected to be at crank? Good numbers regardless. Crossover point of torque and hp not at correct rpm, that is why I'm asking.
HP and torque are on different scales. I think that would roughly account for the discrepancy.
Aha, yes. Scales are different.
Yeah screw the crank stuff, it's essentially meaningless, but that is some good wheel torque! Coming through on the promise of low early torque delivery. Over 400wtq from 2500 to 4700ish (maybe just a little different if the rpm scale is off... But close enough...), that's gotta be fun on the street.
2003 M3CicM6 TiAg
Former:
1985 MB Euro graymarket 300SL
Nice, Torque is king.
Nice to see you finally built and running again Jon shame about the issue with the photobucket pics.
1999 540 Auto with Eaton M112 supercharger
Airlift 3H/P management, M5 steering box, M5 LSD, Eibach/Dinan front and rear anti roll bars, PM Modifich door boards, 4 Eton 6.5s, Sound Magus VS3500.1, 2 x 10" Kove audio subs, Alpine ICS X7 Headunit, 19" BBS Hammer Sports RT245/RT246, Muffler delete, electric coolant fan.
