Ran into the same problem when I swapped in a glovebox with trim into mine. You need to swap out the latch. it's #8 in this diagram:
http://www.realoem.com/bmw/enUS/show...diagId=51_1056
Current Fleet:
E34 1991 M5 Macaoblau on Complete (ruined)Leather Champagne - http://forums.bimmerforums.com/forum....php?t=1705166
Past:
E34 1989 535i 5-Speed AlpineweissII on Natur - Parted
E34 1992 525i 5-Speed Islandgrun on Pergament - Parted
E34 1995 540i 6-Speed ShwarzII on Shwarz - Sold to Sneezy.
E34 1995 525i 5-Speed Calypso Red on Parchment - http://forums.bimmerforums.com/forum....php?t=1748143 - Sold locally.
E39 1998 528i 5-Speed Black on Black - Sold locally.
E34 1993 M5 Alpinweiss on Black - http://forums.bimmerforums.com/forum...lpinweissII-M5 - Parted
Latest update: Alcantara rear shelf
Before
Alcantara Rear Shelf-1 by Nick Butler, on Flickr
Pull the rear seat
Alcantara Rear Shelf-2 by Nick Butler, on Flickr
Alcantara Rear Shelf-3 by Nick Butler, on Flickr
UGHHH so nasty. Fuck lol
Alcantara Rear Shelf-5 by Nick Butler, on Flickr
Peel off the old fabric
Alcantara Rear Shelf-6 by Nick Butler, on Flickr
Lay down your piece of alcantara
Alcantara Rear Shelf-8 by Nick Butler, on Flickr
Alcantara Rear Shelf-9 by Nick Butler, on Flickr
Trim the edges and speaker grills
Alcantara Rear Shelf-10 by Nick Butler, on Flickr
Alcantara Rear Shelf-11 by Nick Butler, on Flickr
Alcantara Rear Shelf-12 by Nick Butler, on Flickr
Careful with the speaker grills. I broke several tabs on both sides reinstalling.
Alcantara Rear Shelf-14 by Nick Butler, on Flickr
Let it dry and get it back in the car!
Alcantara Rear Shelf-16 by Nick Butler, on Flickr
Alcantara Rear Shelf-18 by Nick Butler, on Flickr
Alcantara Rear Shelf-19 by Nick Butler, on Flickr
Alcantara Rear Shelf-20 by Nick Butler, on Flickr
I'm obviously happy with the change :P The old fabric was garbage and this was a great prep session before I tackle the headliner!
Cheers boys
Looks great!
A few questions if you don't mind-
-Was that Alcantera brand, or another?
-How was it working with the contours?
-Did you use a steamer?
-What glue did you use?
-Is there a foam backing, if so, thickness?
I am also looking to redo my rear deck, head liner, A,B and C pillars. I found this stuff locally, but it has almost no stretch.
https://keystonbros.com/auto/auto-fa...eet-suede.html
Just wanted to add my experience as I had the headliner, pillars, and package shelf done with Alcantara. First, be careful about the choice of material. There are lots of ultra suede type products, but in my research I found that Alcantara brand is the best regarding fade resistance and is substantially more robust. Second, Alcantara comes without foam backing which is fine for everything except the headliner. You can cover the headliner with a high quality foam-backed headliner material first and then apply the Alcantara. You can try applying directly to the headliner shell but you have to make sure there are no surface imperfections otherwise they will show through, plus getting nice fitment where the headliner meets the pillars might show some gaps. Third, Alcantara does not stretch so getting it around contours requires steam. Fourth, Weldwood Landau Top Adhesive is good because it has heat resistance. I had an experienced interior guy install mine. Labor cost was about $700. Alcantara is about $110/yard from Gulf Fabrics in Florida. You'll need 4-5 yards. Hope this helps.
Figured you guys would get a kick out of seeing exactly how far my baby has come.
Thoughts on this before / after? Slight upgrade, yea?
OriginalInterior-3 by Nick Butler, on Flickr
OriginalInterior-2 by Nick Butler, on Flickr
OriginalInterior-4 by Nick Butler, on Flickr
OriginalInterior-1 by Nick Butler, on Flickr
Update: Black interior trim pieces.
...I've been collecting interior bits New pieces include:
Black leather shift boot
Black leather e brake boot
Black kick panels
Black triangle piece in-between glove box and door
Black lower seat belt cover
Late model glove box latching bracket
Black glove box
And lastly, I recovered the OEM M5 shift surround with black alcantara.
Here are the finished pics. I'm really happy now that the interior truly feels "black". Its come a long way!
BlackInteriorTrim-3 by Nick Butler, on Flickr
BlackInteriorTrim-2 by Nick Butler, on Flickr
BlackInteriorTrim-10 by Nick Butler, on Flickr
My view
BlackInteriorTrim-5 by Nick Butler, on Flickr
4 seater FTW
BlackInteriorTrim-9 by Nick Butler, on Flickr
BlackInteriorTrim-8 by Nick Butler, on Flickr
BlackInteriorTrim-7 by Nick Butler, on Flickr
Yum, new leather
BlackInteriorTrim-12 by Nick Butler, on Flickr
BlackInteriorTrim-11 by Nick Butler, on Flickr
BlackInteriorTrim-6 by Nick Butler, on Flickr
I'm considering wrapping the wood trim with alcantara as well, not 100% sure what to do there yet. I bought a new wood insert set in a lighter finish but it didn't fit... I wasn't under the impression that there was any difference in the euro vs north america dash pieces. Anyone want to comment on that?
Alrighty!
The final two pieces I need are upper rear seat belt covers. Easy, since I can still buy them new.
Yup, the rear seat belt covers are cheap and available (weird, right??).
Sir Butler, you are quite literally an inspiration. That interior originally was actually worse than my M5, which I thought impossible, and it looks amazing. I have big plans for mine and will be using your thread to keep me going during the eventual, massive, expensive swap.
I'm sure you plan on a headliner re-wrap; thoughts on the carpet? I don't think grey looks bad at all, and wouldn't advise dying the carpet (ask me how I know).
Thanks my dude You're too kind. Its been a lot of work and yes - there is still a little more to do, and I can tackle it when time allows. The hardest parts are done and I'm SO happy with the 180* its done! Not sure about the carpet. I'd like to get a set of new black floor mats but its not really on the horizon yet.
Interior is looking fantastic!
Good luck finding black factory mats. I gave up and went with silver... And have since not treated them very well
I will have to find an aftermarket brand I like and install the factory anchors myself.
Damn! The shift boot and steering wheel leather is 100% awesome!
Where did you get the shift boot?!?
Rear storage box is missing.
Its much nicer now than it was, well done!
I'm not sure about the alcantara for the wood trim, though I have seen it done. Maybe some 3M darker wood color or carbon fiber?
Tommy L.
(oOO \ (IIII) (IIII) / OOo)
-o- (##########) -o-
2001 BMW M5 LMB LHD Euro
Bilstein PSS, Black Kidneys, Dinan Rear Anti-sway Bar, Matte Black Style 65, UUC SSK w/DSSR, Alpine iLX-007, Alpine MRV-F 340 Amp, Boston Acoustics Pro components, Alpine MRP-M450 Amp, Infinity Kappa 102.7W Sub x2
Current Garage:
1993 BMW M5
1994 BMW 525i Touring 5spd
2004 Ford SVT Lightning
That ^
The under dash interior pieces I have are all from a euro E34. The new wood pieces I bought were from a US spec car and they didn't fit. The wood piece left of the steering wheel was too short and the smaller piece right side of the steering wheel didn't have the correct curve.
Is there an early vs late style wood for the dash pieces? Help me guys! My plan is to recover the wood thats installed at the moment and have a back up set in a lighter shade.
I believe the only difference in wood trim is due to the driver side glovebox since it requires different under dash panels. Should be the same trim between us and euro, just different if you have the driver glovebox.
^My understanding as well.
Updates: removed inner turbine fins and steering bits
Thanks for the tip. Looks good in person, just a little more aggressive. Here is a comparison shot. I only did the rears to see if it looked like a staggered setup.
Untitled by Nick Butler, on Flickr
Back at it!
SteeringBits-1 by Nick Butler, on Flickr
SteeringBits-2 by Nick Butler, on Flickr
Inner Turbine fan delete is all the rage!!! Looks good, Mr. B.
I loved replacing all of the steering links, that was the last part in my full suspension refresh (round 1 at least). Keep an eye on that center link from Lemforder. Last thing I'm trying to do is jinx you, but mine only lasted about 2k miles before the joints were useless (just out of warranty, unfortunately). I replaced with another Lemf anyway
She feels AMAZING!!!!! !! ! ! ! Oh wow, I'm so happy with how tight the steering is. This car is go kart tight and needs to be flogged on some more back roads asap! I should take the back roads all the way to Colorado just to show you this car.
All good news peeps! I'll admit that I had my doubts about the handling from the E34 chassis -I've been corrected. I know I might be asking for a fight but .. Why would anyone want an E30 M3 when these cars are 1/4 the price?
You steering wheel is making me drool......where is it from ? I have a non airbag car but that would be great to go with the new shifter knob I bought last year. I also have the solution to this inner turbine fan removal.......get 9's I really never noticed until I saw your picture today but there is a difference front to back. Nice work as always
