Autogeek.net Car Care Products
** 10% off @ Autogeek.net - PinnacleWax.com & Wolfgangcarcare.com - Coupon Code = clubmember
Results 1 to 7 of 7
Thread: Headlights
    Apr 2016
    Charlotte
    2002 530i
    Headlights
    What is the best product to clean and restore yellow oxidized headlight?
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    3M 39008 kit followed by LaminX clear shields.
    May 2016
    Nazareth PA 18064
    83 xj,6 76 cosworth
    I have been professionally polishing headlights for 10 years. I own 2 car washes with detailing shops and have been professionally detailing cars for over 25 years but most of you do not have high speed polisher, so a drill will do with a wool pad will do. I mean if you want you can even use toothpaste with a tooth brush if you have a couple hours to kill. With high speed polisher turn down to near lowest setting (can burn plastic), with wool pad, use medium grade compound dupont 7 (white) or its equivalent. I tape off all painted surfaces within 2" of light as to protect paint from being scuffed. Once polished use any polymer or Teflon wax, both are bonding agents and will last longer then a carnauba wax. pending on driving habits (exposure to acid rain parked outside etc) you will need to wax headlights every 2-4 months to maintain.
    Or you can repaint; after polishing, use 2000 grit sandpaper to scuff need special UV paint and re-paint now your good for 3 years.
    South Charleston, West Vi
    1993 325i
    Plast X. It's around $7 a bottle and you can find it at any auto parts place or Walmart. It's been my experience that no matter what you use, you'll have to re-do your headlights every few washes, but this stuff is so easy to use that it doesn't matter.
    It's not about getting from point A to B, it's about every curve in between.
    Mar 2014
    AL
    X5
    Using restoration kits are ok but the best method is to wetsand, polish and apply some sort of clearcoat.
    Madison WI
    05 330i convertible
    M105 and M205 work for me using a Flex 3401 (DA). Sanding would be needed to take out the deep scratches, but 5 minutes gives 80-90% clarification.
    Nov 2002
    So.California
    1995 M3
    Just a fine abrasive compound/polish like M205. If badly pittted, a more aggressive substance is needed. Even wetsanding as someone said.
    Toothpaste is a last resort, but cheap for mild UV damage.
    You might even have some success by hand, however, that will take some time.
    Walk a mile in my shoes and you are a mile away in someone else's shoes.
    Goodridge*UUC sways* Black TME's and mounts( switched from Red)* x-brace*brembo rotors*Zimmerman rear*Pagid*Riken Raptors* Roja Formula 7's (Bronze)* Stromung*Powdercoated AA DSB* OMP strut bar*GC RSM's* M3 alum/leather knob*JTD underpanel *Traffic PRO (sold) *Black hella Ellipsoids w/celis rings * ACS Pedals*ACS handbrake*RE Octane SSK*Wheelskins Eurotones S/ Wheel Cover( tossed-replaced with new one)* Totally Covers Front seat velour covers with custom styling *Rieger roof spoiler-lost it on fwy Stock A/B*URI CP (ditched years ago)*540 HFM (sold) Stock HFM (BeckArnley)*FMS 24 lb inj*Alum rad and some other stuff*Konis w/adj rr's*Vogtland springs ** Passport 8500(sold)*Passpprt 7500 (sold V1-1.8 with POP) No detectors at all.
    Coming...nada
    BMWCCA-303681
  1. how do i get to headlight, need to replace bulb?
    By BKLYNM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-16-2001, 04:45 PM
  2. Ellipsoid Headlights
    By M3Newbie in forum 1992 - 1999 M3 (E36)
    Last Post: 03-16-2001, 01:20 PM
  3. How difficult is it to replace headlight lenses...
    By Andre325i in forum 1991 - 1999 (E36)
    Last Post: 03-13-2001, 07:30 PM
  4. Replies: 22
    Last Post: 03-13-2001, 02:59 PM
  5. can you get your headlight & drl running at same time?
    By 94_325is in forum 1991 - 1999 (E36)
    Last Post: 03-09-2001, 07:10 PM
