Results 1 to 25 of 32
Thread: AC making funny sounds
    Mar 2016
    Inland Empire
    2001 BMW 740i
    Hello everyone I have a 2000 bmw 740i Sport and AC blows cold and works great car runs strong I just hit 130k on the motor. But every time I turn the AC on I hear a groggy sound
    Im thinking I might have to Recharge it?
    Also I'm starting to get light shaking of the car at speeds of around 30 to 40 mph and after that it stops.
    Feb 2009
    KC North, MO, USA
    1996 740iL
    If the air is cold, should not need a recharge. Not sure what groggy means but if it's gurgling, make sure it's draining on each side of the transmission. If it's more of a groan, could be the bearings on the fan motor.
    Mar 2016
    Inland Empire
    2001 BMW 740i
    Yes air is freezing cold and only takes a few seconds to get cold even on a hot day. It sounds more like a whining sound as if a jet engine was whining up and down Its weird lol Also when I turn the AC on my rpm jumps slightly and when I turn it off rpm back to normal
    Driving with AC doesn't lack power or performance just doesn't sound normal
    Feb 2009
    KC North, MO, USA
    1996 740iL
    Idle change is normal. If the sounds is coming from the blower motor area, under the dash, and not from the engine bay, my guess is it's the bearings on the fan. Some info here towards the bottom of the page.
    http://www.wibimmers.com/board/index...wer-motor-diy/
    May 2003
    Texas, USA
    '01 740i, '99 528iT
    Quote Originally Posted by SenorTips View Post
    ...every time I turn the AC on I hear a groggy sound...
    I have the same issue. The compressor makes a growling or low-frequency whirring sound, audible from inside the car (especially at idle). The system blows cold and I have no complaints other than the noise. I hope that doesn't mean the compressor is failing (bad bearings?).
    Frankie
    Texas, USA
    frankies-bmw.com
    Aug 2008
    Austin, TX
    2001 E38 740I Sport
    I have the same noise and I am planning on having the system emptied and the refilled. Just won't happen for the next 3 months. This car is not leaving the garage for another 3 months.
    -Messan
    The above is my 2 cents. Take it or leave it.
    01 Shorty Sporty BLK/BLK
    Dec 2010
    Atlanta, GA
    E38 7er, E46 M3
    Had it in my 2001. Emptied the entire system after pulling everything out for 20 minutes and then refill to the factory specs. Solved the problem for good. I now have it in my 2000 and will do the same. Strangely none of my 1998 E38s had this issue, both are facelift cars with the exact same symptom.
    Jan 2006
    Ft. Lauderdale, FL
    98 740il, 00 540i,04 ZHP
    Quote Originally Posted by Frankie View Post
    You guys need to recharge your systems. When the refrigerant seeps out, some oil goes with it. But probably more importantly, less refrigerant, less oil flow through the system.
    I solved the whine in our E39 compressor by evacuating the system and recharging. The car cooled perfect, you would never have thought. I even put 2 ounces of oil in the system before anything else. It barely helped with the noise. I evacuated it and weighed what I got out. It was at 60% of the factory charge. Put back in the exact charge amount, and no more noise.
    Interestingly, this all came about by me losing A/C cooling in my prefacelift E38. I got all the tools and found out my car was at 50% of the factory charge when I weighed what I got out of it. I didn't have any compressor noises though. Maybe they changed the compressors post 1998?
    IL
    2000 740i sport
    Whats the best way to do this? Im thinking someone with the big professional HVAC machine and not using those cheap cans from an auto parts store?
    Dec 2010
    Atlanta, GA
    E38 7er, E46 M3
    Quote Originally Posted by purplecty View Post
    Yeah better let a pro do it. Really not worth saving a few bucks. Not to mention that $30-40 can will be a waste at the end. They charge $70-80 here in Atlanta.
    Mar 2016
    Inland Empire
    2001 BMW 740i
    Thanks guys I will try relieving all the charge from the factory and recharging it again to full capacity.... I will also keep it updated thanks again BF
    May 2003
    Texas, USA
    '01 740i, '99 528iT
    Update:Problem solved
    A/C system check found leaking schrader valve on high-side (near condenser); evacuated system (only a little over 1 lb -- should be 1.5 lbs); 2 new valves installed; recharged. My system blows snow now, without the growling noise at idle. $265. Ready for summer!
    Frankie
    Texas, USA
    frankies-bmw.com
    Apr 2003
    Seal Beach, Ca.
    2003 540s, 2000 740s
    May I ask if you took your 7 to a BMW dealer or indy, or, did you take it to an A/C specialist to have the system check done/schrader valves replaced?
    Thanks!
    <== Steptronic Sealbeach740
    2000 740i sport: 74k Green/Tan chrome MPars, clear corners, quad brake lights, AIC hi-beams, Hoen fogs, 16x9 screen, MKIV, TFT LCD screen in back, license plate backup camera with "on demand" switch, iPod audio/video (CDC/iPod audio switching, iPod video on 16x9 screen), Basslink, gauge rings, ///M pedals, switched steptronic +/- shifting mode, E46 paddle shifter steering wheel, Dinan engine & tranny software upgrade, DDEs controlled via Euro fog light switch, painted calipers with "BMW" lettering, windows up/sunroof close via remote.
    2003 540i sport: 81k, Sterling grey/grey, MKIV Nav, PDC & CWP - Added license plate backup camera with "on demand" switch, paddle shift steering wheel, windows up/sunroof close via remote, Akebono's, painted calipers with "BMW" lettering, quad brake lights, iPod audio via AUX mode/video via 16x9 screen, BMW TV tuner, ///M pedals & gauge rings.
    Miami
    2000 BMW 740il
    keep us posted i have the same sound.
    May 2003
    Texas, USA
    '01 740i, '99 528iT
    Quote Originally Posted by sealbeach740 View Post
    May I ask if you took your 7 to a BMW dealer or indy, or, did you take it to an A/C specialist...
    Neither. I took it to a local corner auto repair shop (Midas [Muffler] Auto) -- any will do -- as it doesn't require specialized service.
    Frankie
    Texas, USA
    frankies-bmw.com
    Jan 2016
    Houston
    tbd
    I have that same noise in the video above. have an A/C system evacuation and recharge scheduled for tomorrow.
    Looking to buy
    Jul 2015
    Millersville, Md
    2001 750iL
    Quote Originally Posted by 01740ISP View Post
    -Messan
    I have this same noise. I'll be looking forward to seeing how the refill works.
    Jan 2016
    Houston
    tbd
    Quote Originally Posted by Dan750iL View Post
    I will update as soon as i can
    Looking to buy
    Apr 2003
    Seal Beach, Ca.
    Thanks for the info, Frankie.
    Jun 2012
    Long Island
    00 750iL 01 S8 96 Vette
    I have that same noise in my 2000 750. Ice cold AC, but noisy when the compressor is on (sounds like a whirring sound, as depicted in the youtube video). I plan of having system evacuated and recharged. Ill report back...
    WTB the following Highline/Individual parts for my 2001 750iL in Black (updated Apr 2016):
    -front sport seat-back cushion
    -rear U.S. entertainment armrest with radio/MID/seat/phone/shade/etc controls
    -rear digital climate control with rear blower and black leather housing/console
    -glovebox and rear right 2001 LHD 750iL wood trim with flag inlay; maybe the dash pieces too
    Ryan
    Aug 2008
    Austin, TX
    2001 E38 740I Sport
    evacuated mine and had it refilled. Still does the noise at times but it is less noticeable
    I have not driven the car the last few months so this is my impression from when I was getting back from the shop.
    they could not find a leak in the system either even though it was low on freon. They added a dye for next time.
    I hope it helps on yours.
    -Messan
    Jan 2006
    Ft. Lauderdale, FL
    No leak necessary. You slowly lose charge over a long period of time. Considering these cars are 15+ years old, that's long enough to need a recharge without having an obvious leak.
    Jun 2012
    Long Island
    Quote Originally Posted by serious7series View Post
    Brought my 750 to a reputable indy AC shop. He first ran the AC at max and took the air temp coming out the main center face vents: 38 degrees F! He then tested the high and low pressure readings (both were within range @ 100psi and 28psi). He then added 1oz of oil to the AC system (PAG 100 is the correct oil, and the manual calls for a total of 6oz). Made no difference in that sound. He did not evac and refill, as he thought it wouldn't benefit anything.
    I'm at a loss for making that noise go away.
    Ryan
    Jan 2006
    Ft. Lauderdale, FL
    You cannot tell if the system is a little low or full based on the pressures. My 7 didn't start losing cooling ability until it was down to about 50% charge -- interestingly, no compressor noise. Now, even with the 540 at 60% charge, the pressures looked fine and car blew cold, BUT the noise was there.
    Evacuating each car showed my 7 at 50% charge and the 5 at 60% charge. (This is by weighing the tank before and after evacuating and comparing the change against the charge weight on the A/C label). My car instantly started blowing at 28*F vent temp with the ambient around 75-80. The 5 was the same, but the compressor noise in the 5 stopped.
    Long story short, you need to evacuate and recharge with the proper weight. If there is not enough refrigerant in the system, not enough oil gets circulated, since the oil circulates with the refrigerant. Your car is probably low, but you won't know it looking at the pressures. The only way to know is to weight it.
    Feb 2017
    Chicago
    E38 M-Sport & Jaguar XK
    Is that the guibo?
    Quote Originally Posted by Mayorchuck View Post
  1. 2000 323i makes funny sound when headlights are turned on.
    By hothouse in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-05-2016, 10:47 PM
  2. AC dripping somewhere and making sizzling sound
    By rrcompton in forum 1996 - 2003 (E39)
    Last Post: 08-05-2009, 12:12 AM
  3. trasmission making a funny sound
    By chickentoe82 in forum 1991 - 1999 (E36)
    Last Post: 07-23-2009, 05:12 PM
  4. AC makes a click sound
    By beem3 in forum 1991 - 1999 (E36)
    Last Post: 04-24-2008, 02:45 AM
  5. Battery makes hissing sounds?!
    By C///M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-25-2001, 11:49 AM
