Results 1 to 15 of 15
Thread: FS: Getrag 245 5 speed overdrive transmission from 84' 318i
    Jun 2014
    San Pedro, CA
    E21, E34, E39, POS2015VW
    FS: Getrag 240 5 speed overdrive transmission from 84' 318i
    **Edited from incorrectly labeled "Getrag 245".
    The last 7 of donor VIN are 8700056 FYI.
    Thanks, group, for clearing up the muddy naming conventions...
    The transmission came from a running car with approximately 170k-200k. Manufactured 04/1983.
    Buyer should renew seals before installing, but this is a great transmission for 2002 owners as well as e21 folks, or early e30 drivers running the m10 motor.
    The shift plate and shifter are included as well.
    My tiny garage means I'm willing to part with it for cheap.
    If you're local I'll help you install it. If you're not local, I'll eat the shipping cost.
    Allen
    Please pm me for phone
    monterey, ca.
    e21, e30 m3. e46 330ci
    G240
    Tom D
    77 e21 - m42
    88 e30m3
    04 330 dinan3
    84 r1000rt
    02 r1150rs
    all of them gray
    14 f800gsa - red headed stepchild!
    Jan 2014
    USA
    04 ZHP, 83 320i, 00 M5
    PM'd
    Jun 2014
    San Pedro, CA
    Tom, is it not common practice to refer to them as 245 since they use the complete guide sleeve assemblies as the 245/4?
    Aug 2013
    gainesville,fl.
    1977 320i
    I'm no expert but, as far as I have seen the g240 was introduced in the e21 1983 model year and used on e30 4 cylinders. I've never heard of a 240 referred to as a 245. Kind of like calling an m20 an m10 because they share the same chassis?
    Oh, and the numbers should be right on it.
    Jan 2014
    USA
    From what I am reading around the internet this transmission was also the same for the 83 320i? I currently have an automatic trans and it is definitely going to be replaced with a manual soon.
    _________
    1980 320i - Kashmir Metallic - Sold in 1993
    1985 535i - Cosmosblau Metallic - Sold in 1995
    1985 535i - 1985-06 - Delphin Metallic - Sold in 2016
    1983 320i - 1982-09 - Kashmir Metallic - Currently own!
    2004 ZHP - 2003-08 - Titanium Metallic - Currently own!
    2000 M5 - 2000-02 Titanium Silver - Currently own!
    Jun 2014
    San Pedro, CA
    Andrew, can you clear this up for us?
    Jun 2005
    Texas
    E21, E24, E34, E46
    Quote Originally Posted by charter21p5 View Post
    It has the same guts, but the mounting ears are different and it has no speedometer driver. The E30 318i transmission is really only useful in 318i's. And half of them had a ZF transmission instead.
    Fullerton, CA
    Quote Originally Posted by Allenwilson33 View Post
    I did a little thing here that will help ...
    http://www.bmw2002faq.com/forums/top...transmissions/
    As you can see near the bottom of that thread, local guy Gary Summers proved the 240 is still useful, just not as conventional (so a bit more custom fiddling for the 02 guys).
    Jun 2014
    San Pedro, CA
    Quote Originally Posted by dups View Post
    I'm no expert but, as far as I have seen the g240 was introduced in the e21 1983 model year and used on e30 4 cylinders..
    I got lucky with my 83' iS being built in August of 82', as I got under the car to see 245.0.520.00 stamped on mine. But for the record, the one I'm selling is the 240 / 5 speed overdrive.
    Is it possible to convert that electrical speedo to mechanical?
    monterey, ca.
    nope
    Tom D
    77 e21 - m42
    88 e30m3
    04 330 dinan3
    84 r1000rt
    02 r1150rs
    all of them gray
    Jun 2014
    San Pedro, CA
    lovely. So Layne's right about it being useless for all except 318i then...
    How hard is it to complete fabrication to jam it in an 82'?
    monterey, ca.
    not useless, just less then desirable.
    it will bolt directly to the back of the M10. it has the same single mount rear support so I suspect it's the same as an E21. it also uses the same shifter platform as the E21, but you will need an 83 E21 driveshaft and you lose the speedo drive.
    Tom D
    77 e21 - m42
    88 e30m3
    04 330 dinan3
    84 r1000rt
    02 r1150rs
    all of them gray
    Jun 2005
    Texas
    E21, E24, E34, E46
    Quote Originally Posted by SkiFree View Post
    Slight error there, the 245 was not used until 9/79. Previous E21's were 4 speed. The euro optional 5 speeds up to that point were close ratio.
    Quote Originally Posted by Tom D View Post
    It's been a while since I looked, but I was thinking it has dual rear mounts. Not a huge thing, just usually not worth messing with to have a car with no speedometer.
    Fullerton, CA
    Quote Originally Posted by Layne View Post
    Right, I did not make the distinction between overdrive and close ratio for that reason.
    Somewhat on topic, had a good talk with a friend at BMW Classic about the 245. Apparently they even used them on some early M3 Group-A cars, I told him BS till he shot over some pictures and shut me up. He said they "just had them around and needed to use them up".
  1. FS: Getrag 6 speed manual transmission for V8 (S/M60/2)
    By OnUrleft in forum Drivetrain & Transmission Parts
    Last Post: 01-16-2014, 08:20 AM
  2. FS Engine and Transmission from 84 633csi
    By jonwalton in forum 1976 - 1989 (E24)
    Last Post: 04-29-2012, 05:21 PM
  3. FS: 5 speed automatic transmission from '98 M3 58k miles
    By Eric Giles in forum Drivetrain & Transmission Parts
    Last Post: 03-02-2011, 11:50 PM
  4. 318 GetRag 5-speed manual transmission tranny trans 318i 318is
    By toyosupr in forum Drivetrain & Transmission Parts
    Last Post: 11-05-2009, 06:04 PM
  5. FS: Getrag 5 speed transmission
    By croatan in forum Drivetrain & Transmission Parts
    Last Post: 09-23-2007, 10:36 AM
