Results 1 to 7 of 7
Thread: 93 318 Window motor wiring diagram
    May 2015
    United States
    E36 M3
    I have a 93 318 window motor that does not work. I've tried various things, but there seems to be something I can't pinpoint (I am no expert). The short version is auto window down functions, nothing else does. Tried multiple window motors, same story.
    For the interim I am thinking to bypass all the wiring and wire the motor direct to a 12v source. However, I have no idea what wires do what. This isn't like the newer E36s with 3 very simple wires. This plug has 6 pins in it. Does anyone know what each color does, any diagrams out there.
    This is driver side coupe.
    South Carolina
    2004 330 vert 2004 X5
    The window motors in 92/93 e36s are very different than 94-98 e36s. The electronic controls are inside that big square part on 92/93. Starting in 94 they moved the controls from the motor to the body control module (ZKE). The only replacement that will work for your car is one from a 92/93 e36. Those are getting harder and harder to find. My suggestion is to try a new switch. You should be able to swap switches with the passenger side. If you end up needing a new switch be careful to get the correct one. They are color coded on the bottom and early e36 switches use a large style connector. Later ones use a much smaller connector
    One other thing to keep in mind if you need a replacement motor. On 94-98 e36s the coupe drivers motor is the same as a sedan passenger motor. Not sure why but they swapped driver/passenger motors. I don't know if that holds true for 92/93 but I suspect it does only because the regulator remained the same 92-98. If the regulator is the same then it makes sense the rule about sedan passenger/coupe driver motors would remain the same.
    May 2015
    United States
    E36 M3
    I was able to find a spare, that I think worked, but this motor does the exact same thing as the one in the car. I guess its possible the exact same thing is wrong with the motor, but I am leaning towards a wiring issue.
    However, if someone can tell me what wires I need to apply direct power to I can probably test both.
    Dec 2014
    Alexandria, Va
    1996 328is, 2003 325ci
    Think about what you are doing here. If you replaced the motor and it acts like the old motor it's not the motor. The motor goes one direction or the other depending on the power and ground signal. Something else is missing here. I don't know the early versions but if it were me I would start looking for a broken wire in the harness between the door and the chassis
    May 2015
    United States
    E36 M3
    I know its not the motor, and I know it is in the wiring. Ideally I'd like to see what each wire actually does, narrow it down.
    Feb 2016
    Herndon, Virginia
    1992 325is
    I wonder if anyone figured this out . I have a 325is driver motor that only goes down . I can swap it into the passenger side and it goes both ways. I am sure there is a break in the wiring somewhere.
    I have a few ideas (maybe the black wire is broke) I need to jumper it over to find out.
    '92 325is
    '17 Mustang GT for a Daily
    Aug 2017
    Bay Area, CA
    E36 Ford 302 swap
    Sorry to bring up an old thread. So it's definitely not possible to cut the wires above the connector on a 96, and splice it into a 92? These dang door cards are too big to fit the flat metal door card replacements
  1. E36 WTB 92-93 coupe window motors and door wire harnesses
    By KREATURE in forum Exterior Lighting & Body Parts
    Last Post: 09-09-2013, 09:03 AM
  2. '92 318 Window motor.. will it work in M3 wiring harness??????
    By SecondtoNone in forum 1992 - 1999 M3 (E36)
    Last Post: 08-12-2007, 01:22 AM
  3. Would '93 318 window motors work in '95 M3????
    By SecondtoNone in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-08-2007, 09:34 AM
  4. E34 535i window control wiring diagram needed
    By epj3 in forum 1988 - 1996 (E34)
    Last Post: 06-13-2005, 06:16 AM
  5. Window motor wiring help
    By geha13 in forum 1991 - 1999 (E36)
    Last Post: 05-12-2004, 07:19 PM
