Originally Posted by
jehu
Did you ever sort this out? I have a 1212 which by the way is bank 2 (Left). Autologic scan described the fault as "Short to Positive (+). I replaced the #2 O2 sensor today and it came back shortly after restarting.. had the Alternator replaced so the battery was disconnected for a while thus clearing the ECU. It wasn't a new part I used so there is a chance that sensor is also faulty but it wasn't causing a fault in the 540 from which i removed it however that was several years ago now. Anyway I figure the next step is to test the car harness O2 connector for the correct values.. If anyone can point me to that procedure it would be helpful. I'll note that I recently within 15,000 miles totally re-sealed the intake. new throttle body gasket, new rear manifold cover (CCV) and gasket and new in take manifold gaskets. There was no fault for the MAF from the Autologic scan but its not new .
I am suspecting some damage to the wiring as this CEL appeared recently on a drive through rather deep and frozen slush and snow from a two day long sleet, snow and freezing rain storm and I was often driving in deep substantially frozen precipitation when this popped up..
