Newbie here so excuse the lame question.
I have googled around and not really found anything about this. I have an issue with the rear lights on my 2008 E87. The high level brake light, fog lights and side lights are all illuminated at the same time when I turn the headlights on. Have looked at the FCM and PDC boxes and had new ones (second hand) coded in which didn't cure the issue. Have since found an issue with the wiring to the high level brake which has been sorted, but the fogs and sidelights are both still lit when headlights are on. Is this standard or do I have another issue?? TIA.
Lee
Have you upgraded the lights?
I've just done the lci rear upgrade for my car and had the "Xmas tree" effect....the same as you are describing....
I solved this by coding out the warm and cold bulb checks for the rears, and that solved it!!
Sent from my iPad using Tapatalk
