Page 5 of 37 FirstFirst 12345678910111213141530 ... LastLast
Results 101 to 125 of 903
Thread: E36 Hater's Phase 3, AKA what's a budget build?
  1. #101
    Ship, Pa
    Red Sled, RC51
    4.5
    "Believe nothing you hear, half of what you read"
  2. #102
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Well dont I feel insignificant now......
  3. #103
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by rajicase View Post
    the bigger the tip
    The moar powers. Feel insignificant young grasshopper!!!
    1989 535i - sold
    1999 Tiag/Dove M3 - sold
    1998 Turbo Arctic/black - current
    2004 TiAg/Black - Current
    PTE6870 | 1.15 ar | Hp Cover, Custom Divided T4 bottom-mount, 3.5" SS exhaust, Dual Turbosmart Compgates, Turbosmart Raceport BOV, 3.5" Treadstone Intercooler, 3.5" Vibrant resonator and muffler, Arp 2k Headstuds | Arp 2k Main studs | 87mm Je pistons | Eagle rods | 9.2:1 static compression, Ces 87mm cutring, Custom solid rear subframe bushings, Akg 85d diff bushings, 4 clutch 3.15 diff, , Poly engine mounts, UUC trans mounts W/ enforcers, 22RPD OBD2 Stock ECU id1700 E85 tune, 22RPD Big power Transmission swap w/ GS6-53
  4. #104
    Feb 2012
    1995 BMW M3
    Quote Originally Posted by vollosso View Post
    the bigger the tip
    Well..... My tip is bigger than your tip sooo.....
    Now thats a tip
  5. #105
    Sep 2014
    Connecticut
    1999 328IC & 1995 325iC
    can I ask where you got the fender flares from?
  6. #106
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    I've got a 4 inch tip. Looks great imo.
    Attachment 569463
    Another of the 4" tip
    Attachment 569464
    These look great, for the longest time I was a fan of the dual but I think a single looks great too.
    Quote Originally Posted by Fender13Bender View Post
    4.5
    ive always loved the look on your car matt.
    Quote Originally Posted by frankievig View Post
    They are chelsea denofa flares.
  7. #107
    Feb 2012
    1995 BMW M3
    Quote Originally Posted by E36 HateR View Post
    I was too. But after I got the single 3" exhaust with the 4" tip I changed my view. I think with the right tip, 4" is the perfect size imo, single looks great.
  8. #108
    NY/FL
    '99 Acura CL, '98 M3/4/5
    I've always found it difficult to like single tip exhausts on the e36, idk why.
    Acura 2.3 CL BMW M3/4/5 Ninja ZX6R 636
    Penn State University '08...better than your school since 1855
    Sigma Lambda Beta International Fraternity Incorporated
    UTI Class of '10, BMW "STEPchild"
    Acurazine.com Mod Squad
  9. #109
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Quote Originally Posted by Da Infammus 1 View Post
    Its because you were a master tech lol
  10. #110
    Jun 2012
    South fla
    97 332i, 90 535i
    Quote Originally Posted by hakentt View Post
    Non vanos head is inferior, it has wider valve stems, this means less flow and heavier valves.
    this is false, I run a nv head with vanos added on my drag car. Makes plenty of power with no drop off in sight
  11. #111
    Jun 2012
    South fla
    97 332i, 90 535i
    going to need another fuel pump or a boost-a-pump. Big Wally won't get you all the way to 800whp.
    Edit2: car looks great!![/QUOTE] a walbro 450 rewired with a relay to the battery maxed out at 855 on race gas but I would imagine on e85 you're gonna need 2 of them!
  12. #112
    Aug 2012
    CT
    Twin turbo LS E36 M3
    I really need to re wire mines.
    2 questions, does anyone have an idea how much rewording helps? Maybe a percent value or something
    2. What do you guys do about the tiny wires from the stock fuel pump hanger to the actual pump? I drilled a hole on the top of my hanger and ran 12awg wires through, but every now and again I have to reseal the top because it will start leaking fuel
    328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
    9.20 at 150 on 22psi
  13. #113
    Feb 2012
    1995 BMW M3
    I pulled the 2 pins out of the stock fuel pump hanger where the OE connector went and pulled the two wires through there. Perfect fit for 12 gauge wire.
  14. #114
    Aug 2012
    CT
    Ahhh snap, that's brilliant. Thanks
  15. #115
    Feb 2012
    1995 BMW M3
    Yeah fit the wires that came with the walbro harness perfectly. Was so tight I had to put a bit of lube on the wires to get them through(hehehehehthatswhatshesaid)
    I didn't use any sealant or anything and so far no leaks or anything..
  16. #116
    Jun 2012
    South fla
    97 332i, 90 535i
    Looks like I have a new little project! I just spliced a 12g wire into the factory connector which I'm now questioning heavily!
  17. #117
    Feb 2012
    1995 BMW M3
    Quote Originally Posted by Bke36Is View Post
    You are making 8bajillionWhps on stock wiring??
  18. #118
    Jun 2012
    South fla
    97 332i, 90 535i
    Not stock wiring just using the stock connector for the fuel pump with 12 gauge wiring
  19. #119
    Mar 2012
    Renton, Wa
    98 m3
    this is what i did. I also soldered better wiring underneath. These pins are big enough.
    I used stranded pure copper 10awg though.
    And it helps a lot... 14v vs I dont know 12v or something..
    1989 535i - sold
  20. #120
    Jun 2012
    South fla
    97 332i, 90 535i
    Exactly what I did so I feel a little better! Lol. I measured voltage at the connector on stock wiring and it was 11.9x volts @ 4k rpm and just to be sure it wasn't a faulty alt I checked the output and it was right at 14.2 ish volts
  21. #121
    Oct 2013
    Macon, Ga
    1993 BMW 325is
    Just cause it makes plenty of power doesn't mean it makes as much as it could. Not saying you're wrong cause I've heard this vanos vs non-vanos head quite a lot and no one has ever tested the two back to back with dyno and datalogs to back it up, but I wouldn't say that it's false either
    Sent from my Nexus 6P using Tapatalk
    '93 325is: ZF swap, Borla Type X muffler, cat delete, X Pipe, Tune, Powerflex bushings (subframe, diff, RTAB, LCAB), Apex ARC8's, Raceland Ultimos, Corbeau seat, Renown steering wheel, M3 front and rear bumpers, BMW motorsports moulding, Euro tails, Depo headlights (soon to be retrofitted)
  22. #122
    Jun 2012
    South fla
    97 332i, 90 535i
    Quote Originally Posted by tyr283 View Post
    It already makes more power than it should! I think that being a boosted motor, 6mm valve stems vs 7mm valve stems wouldn't make much of a difference but I'd like to see some comparisons of anyone here has done so
  23. #123
    Mar 2012
    Renton, Wa
    98 m3
    its like nearly 10% more flow i think... If you convert to 6mm..
    1989 535i - sold
  24. #124
    Jun 2012
    South fla
    97 332i, 90 535i
    Wow didn't think it was that much! Thanks for the info, time to build my s52 head!
  25. #125
    Mar 2012
    Renton, Wa
    98 m3
    you just do 6mm valves with different guides and retainers it works. Can use all oem bmw gear.
    1989 535i - sold
  1. Just bought an e36 that sat for a year... what now?
    By morganbressler in forum 1991 - 1999 (E36)
    Last Post: 08-08-2006, 11:30 PM
  2. Replies: 3
    Last Post: 07-23-2006, 05:18 PM
  3. FI with M3 E36 and Z3 Coupe 2.8...what is the difference?
    By Oleg Coupe in forum Forced Induction
    Last Post: 08-27-2005, 07:11 AM
  4. e36 m3 with exhaust, chip, intake... what would it run?
    By ellinopedo182 in forum 1992 - 1999 M3 (E36)
    Last Post: 11-19-2004, 11:11 AM
  5. e36 shift knob usually falls off....what do must replace it with for race usage?
    By Austin in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 04-21-2003, 04:50 PM
