Final boost @ each power?
1989 535i - sold
1999 M3 Tiag/Dove - sold
1989 535i - sold
Yea the BW's flow amazing, very quiet turbos compared to holset, but the proof is in the pudding.
1989 535i - sold
I don't want to talk for him but another forum member just made some really big power (as in more than me) with an m52 with stock pistons and non vanos rods as well.
1989 535i - sold
It's way to application specific to say a component can handle X amount of power. Some people think I'm lucky my dumpster of a motor stays together but they are missing a lot of the little details that go into making a lot of power and keeping it alive. Then again some people do just seam to be lucky lol. S52/m52 rods are junk, that's all I know for certain.
Yea 912 rwhp through an auto is serious business, because we know what the screen would have showed if he were spinning the rollers through a manual.
Some pics from pocono raceway, went 161 entering at 63mph, had to start in 2nd bc of the long gearing.
nice pics! had a good time, they need to have more of these but invite only
98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
2017 Toyota Tundra Crewmaxx - Family Whip
2011 Pierce 75' Quint - Fire Apparatus West Islip FD
That is some awesome power on a budget build. It appears you are making peak HP below 7000rpm. Is this your intent, or do you think the cams are to small or maybe the turbo falling off up top? 1000 hp at the crank is no joke and with m52 pistons,lol. Must be a wild ride!
WOT
Why NV. Just for larger valve springs. And, how did you adapt the vanos? Provisions there, just switch valve covers and cams?
This is my signature....
Yea man, i agree.
Lol sure is wild, it peaks around 7100-7300, we are reving to 7600, im sure its the camshafts, s50's will only get us so far.
Have to modify te head a bit to fit the vanos unit, but the dual valvesprings are what I wanted.
Signed up fir FL2k17 last night, see ya in Bradenton
Getting ready fir fl2k, just filling my fuel cell and strapping the car to the trailer
Not hurting any feelings in ocean city this weekend?
Are these 135mm rods?
Went to fl2k, ran a bunch of fast cars, i was by myself so im waiting for videos to surface.
