Pulley and headers wake up the e55 AMG is you don't have them already. My wife loves hers.
1992 3000GT VR4. 4g63 Swap. DSM 2g Auto Trans. 10:1, E85, AEM, FP Super 99 turbo. Best ET 9.98...Best MPH 137.8
There was a member here who pushed his E55 AMG to its limits and then rebuilt it and tried again. It was a few years ago. I don't recall the details but he posted them.
Buddy has one with 190mm pully, long tubes and meth that put down 529/598 on 91.
Turbo E36 M3 with all the things..
Nice
― George Orwell
I almost bought an e55 with a bunch of bolt ons (pulley/tune/intercooler/etc...) a few years ago. I liked everything about the car besides I felt like I was driving a tug boat. I do however feel the coilover conversions that are available now may liven up the car a ton. Def had power in a straight line though.
Saw your car was on the dyno. Hope to see some good numbers after you fixed the problems you been having !
Thanks man, having a few issues, car is making over 700whp by 6000rpm and climbing fast, 22-23psi, if she holds to 7600 rpm it will make over 850whp with a few more psi, chasing down issues, having a random miss up top, going to switch to an obd2 computer and harness for the race event this weekend, swapping parts tonight and sending it tomorrow morning.
Lookin good dude.
1989 535i - sold
1999 M3 Tiag/Dove - sold
Is this still a rodded m52 with the nv top end w/ vanos? I see the IG is hot right now lol
Finally got the car sorted, 869whp/688wtq, stock 2.8 pistons, eagle rods, cutring/copper combo, non vanos head, s50 cams, rk tunes obd2, sxe369 turbo.
Boost vs power dyno?
1989 535i - sold
So it's a budget motor build? Relying on E85 to help the pistons? That's big power to me.
No RPM referenced runs?
That's a lot of damn power for a relatively mild sounding combo!!
How much boost is required for this power with that setup? Also, is this basically a bit over stock M52 compression because the NV head probably has smaller combustion chambers?
Why such a variance in hp between runs?
They were different boost levels.
