Page 2 of 37 FirstFirst 12345678910111227 ... LastLast
Results 26 to 50 of 903
Thread: E36 Hater's Phase 3, AKA what's a budget build?
  1. #26
    Toronto, Canada
    E36 Turbo
    Quote Originally Posted by E36 HateR View Post
    I have my doubts but i also have my ideas, a little drip in base pressure will open up the walbro as it'll flow more fuel, and nobody thought I would get to 700whp on a single pump or 1000cc injectors.
    To be fair, in your case the math did work out, there wasn't much for anyone to speak against it on your 2.5L.
    I am thinking about dropping in another walbro, it is an easy fit, we will see what happens.
    FWIW, I'm working on testing a new fuel pump setup soon that will support almost 1000WHP on Ethanol on a single pump, be quiet, keep the fuel cool and draw very low amperage.
  2. #27
    Mar 2012
    Renton, Wa
    98 m3
    Im on the fence. 600whp on pump would be nice.
    My goal is 600 on pump no meth and 19-20psi.
    Im almost there, the next revision should do it, but i really like being able to stop at any station and fill up hah.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  3. #28
    Mar 2011
    Utah
    93 M318is Sedan (lol)
    What are your thoughts on turbo lab of america? I've been wanting to get one of the ceramic DBB gt35r CHRA's they make. Have you already got your turbo back from them? P.S. Love your build man!
  4. #29
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Quote Originally Posted by zJACKRABBIT View Post
    I have no experience with them. Have a buddy who had a very bad experience with them... sounds like OP has had good experiences.
  5. #30
    Jul 2002
    Long Island, NY
    98 Turbo M3, 04 E53 X5
    Frank - What shop did you use for machine work?
    Its going to be a busy tuning season for Jordan lol
    98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
    2017 Toyota Tundra Crewmaxx - Family Whip
    2011 Pierce 75' Quint - Fire Apparatus West Islip FD
  6. #31
    NY/FL
    '08 G35S, '98 M3/4/5
    Quote Originally Posted by rajicase View Post
    Turbo lab hasn't gotten a good review from anyone that I've known.
    Infiniti G35S Turbo BMW M3/4/5 Ninja ZX6R 636
    Penn State University '08...better than your school since 1855
    Sigma Lambda Beta International Fraternity Incorporated
    UTI Class of '10, BMW "STEPchild"
    Acurazine.com Mod Squad
  7. #32
    Feb 2012
    1995 BMW M3
    I know they sold a guy here a 35r center section claiming it was genuine Garrett and then when it failed shortly after, he sent it to Garrett and they laughed and told him It was a china copy. Pretty s**tty...
  8. #33
    Los Angeles, CA
    #Project333Ti & Z3 Coupe
    Build thread is missing NAWS bro
  9. #34
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Quote Originally Posted by NOTORIOUS VR View Post
    I was looking at the magnafuel pump and the fuel lab pump, might switch to one of those for a big single pump.
    Quote Originally Posted by vollosso View Post
    Yea i think with the safe drop in compression and large IC/exhaust she should be able to make 600whp on 93 safely.
    Thanks man, they have been good to me in the past, they have had my turbo for a few months but I'm not too upset as the season hasn't started yet for me.
    Quote Originally Posted by NY98M3 View Post
    Lets me and you get on the rollers the same day.
    Quote Originally Posted by e30polak View Post
    Next year ill add some happy happy and some 28 inch slicks lol.
    UPDATE
    Dropped the block and the pistons off at the machine shop for bore/hone and deck/hot tank, might be finished by the end of this week, lets see.
    I just need a crankshaft.
  10. #35
    poconos pa
    e36 m3, turbo e36
    Anthony and I both have the double pump hanger from rallyroad. Eric has awesome products fwiw.
    -sold...replaced by turbo e36
  11. #36
    Feb 2016
    South Florida
    99 fern green turbo m3,
    UPDATE
    Are you going to be running stock fuel lines for your new set up or upgrade?
    Sent from my SAMSUNG-SGH-I537 using Tapatalk
  12. #37
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Quote Originally Posted by beeasy View Post
    Quote Originally Posted by Boostedm333 View Post
    Im looking into fuel upgrades all over the system, although stock lines have been working very well for me.
  13. #38
    Feb 2016
    South Florida
    Ohh ok. Yae mann I was considering stock fuel lines after seeing your dyno chart making 717whp with stock fuel lines. where's my goal is 700whp on e85. But as notorious vr said your set up was a 2.5 which gave you a over head. where's mines is a 3.2.
  14. #39
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Yea if I were you id have 115lb injectors, 2 pumps, and -8 feed and -6 return.
  15. #40
    St. Anthony, IN
    1992 3000GT VR4
    Did you run it down the strip on the 717whp tune? Trap speed?
    1992 3000GT VR4. 4g63 Swap. DSM 2g Auto Trans. 10:1, E85, AEM, FP Super 99 turbo. Best ET 9.98...Best MPH 137.8
  16. #41
    Feb 2016
    South Florida
    Yae am definitely going with the 115lb I wasn't sure if I wanted to run stock lines. But the -8 feed and -6 return sounds good. If I do Decide to run 2 pumps what size do you rec.
  17. #42
    Toronto, Canada
    E36 Turbo
    Not a horrible choice, but they're loud, draw a lot of amps, and heat the fuel up for no reason when cruising.
    The setup I'm talking about is a completely variable/programmable brushless pump setup. The pump and controllers are ready, right now just waiting on have a complete billet aluminum drop in tank setup to be made.
  18. #43
    Aug 2012
    CT
    Twin turbo LS E36 M3
    Keep us posted, I'm intrested
    328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
    9.20 at 150 on 22psi
  19. #44
    Apr 2006
    Minnesota eh?
    86 325es
    The fuel lab pumps are also variable speed but I don't remember what type of input they require to do that. I always thought we need a pump with a flow sensor on the return line so it will run the pump just enough to maintain like 50 lbs/hr of return flow.
  20. #45
    Sep 2008
    Toronto, ON
    6465 328ti
    My guess would be a pwm control perhaps?
  21. #46
    Apr 2006
    Minnesota eh?
    86 325es
    Here are the instructions. Apparently they can be switched from low speed to high with a 5V input, which is probably the way I would do it with megasquirt. Or they can be speed controlled with a PMW signal if your ECU can be set up with a table to do so.
    http://fuelab.com/wp-content/uploads...structions.pdf
    Also apparently they already invented the flow controlled system that i was suggesting. They make a regulator with a pressure transducer and restrictor to measure return flow and adjust pump speed automatically.
    http://fuelab.com/tag/prodigy-fuel-pump-speed-control/
  22. #47
    Mar 2012
    Renton, Wa
    98 m3
    I think i would just run low/high with that.. tuning would be interesting for a Factory ecu...
    But i think pwm would probably add unnecessary wear to the pump..
    1989 535i - sold
  23. #48
    Apr 2006
    Minnesota eh?
    86 325es
    The motors in the fuel lab pumps are brushless so they are transistor controlled. I don't think they are actually turning the power on and off. Probably just shortening the time that the magnets are energized. I think thats how they do it on brushless cordless drills.
  24. #49
    Mar 2012
    Renton, Wa
    98 m3
    My understand of brushless is cursory but the way i understand it is the speed is controlled by the angle at which the magnetic field is applied..
    Regardless i feel like pulsing the power constantly would wear the motor, but perhaps i am wrong
    1989 535i - sold
  25. #50
    Jul 2002
    Long Island, NY
    2 pumps make alot of heat...At Mpact, I saw E85 temps in the 120F's
    Thats 2 - 485 Walbros hung on the RR hanger
  1. Just bought an e36 that sat for a year... what now?
    By morganbressler in forum 1991 - 1999 (E36)
    Last Post: 08-08-2006, 10:30 PM
  2. Replies: 3
    Last Post: 07-23-2006, 04:18 PM
  3. FI with M3 E36 and Z3 Coupe 2.8...what is the difference?
    By Oleg Coupe in forum Forced Induction
    Last Post: 08-27-2005, 06:11 AM
  4. e36 m3 with exhaust, chip, intake... what would it run?
    By ellinopedo182 in forum 1992 - 1999 M3 (E36)
    Last Post: 11-19-2004, 10:11 AM
  5. e36 shift knob usually falls off....what do must replace it with for race usage?
    By Austin in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 04-21-2003, 03:50 PM
