I'd look into a bigger housing. TurboLab is now selling a .82 T3 machined for hx40.
I floated exhaust valves (and bent a couple) on mine at 37psi and 9300 rpm. Presumably from exhaust back pressure. Had kiggly beehive springs with titanium retainers set up at 97lb seat pressure.
I'm sure you won't be running that much boost but it does point to a choke issue. With less boost and your nice wastegate placement, maybe it will work around the issue a bit.
I ended up selling mine and bought a Forced Performance Super99. That should take care of it
1992 3000GT VR4. 4g63 Swap. DSM 2g Auto Trans. 10:1, E85, AEM, FP Super 99 turbo. Best ET 9.98...Best MPH 137.8
Measuring EMBP might be a good idea at the least
I'll look into a bigger turbine housing, I had her over 30psi last season for a while even though the woodruff key was busted.
Downpipe and exhaust are still in progress but all the reinforcements and driveline upgrades/bushings are in
Just need to finish grinding down the calipers to fit the drag radials.
That's looking sweet!
What's up with the CV joint at the rear of the driveshaft, is that an M3 thing?
I thought the CV Joint was standard for all 6 bolt driveshafts.
My 09/96 M3/4/5 has a 6 bolt driveshaft (OEM) and uses a CV Joint at the rear.
My brothers 09/97 M3/4/5 has a 4 bolt driveshaft with a u joint in the middle and at the rear.
DSS offers there drivehafts for both the 4 and 6 bolt diffs, you sure the cv joint on the driveshaft isn't just specific to the 6 bolt design like oem?
So the turbine outlet is 3inch vband, my fabricator had went to 3.5 at the flange, and before the downpipe gets to the transmission he flared it to 4inch.
The new exhaust is massive, but I love it.
I hope you're able to shoot and post some more pics of that downpipe, it is pretty sweet.
So I noticed that your turbine side does not have the external wastegate, and I'm assuming that that's the turbo lab upgrade that's responsible for that. In order to go with an external on my future setup, I'd either have to upgrade the housing or weld the flapper shut. Do you know if that affects flow characteristics at all vs the new housing. And if I weld the flapper in the interim, should I get the adapter plate?
Your rear subframe bushings look like they are either missing the large thick washers on the bottom or you have thin washers that have cupped a lot. Either way you should sort that out to stop the rear subframe from moving around.
Sent from my GTX3582R
Where? The large washer is on there
These are the bushings
The picture of the forward end of the diff you can see the forward subframe mounts. If you look at the large washers you will see that they are quite cupped. This has been a common issue with some of the subframe mounts that are out there. Some people order large thick washers from McMaster-Carr to fix the issue. I made shims and used large thick aluminum washers on mine to make sure the inner bushing was pinched and the poly bushings were firmly retained.
But the bushing itself is cupped?
There's a lot more surface area to a v-banded truck manifold than there is a 30 - 40mm pipe to an exhaust housing.
I am very familiar with the pre heat and sand cool down of cast welded stuff and, in my experience and from seeing other peoples projects, it will crack eventually. There are rods (Ni-Rod) meant for this application, but it's never recommended on stuff that has constant heat/cool and vibration. Feel free to do it, but I didn't bother and went through way more effort making a second wastegate fit on my car. Welding the cast housing would have been way, way easier, but I don't have a good feeling about it.
Additionally, Mike may or may not have been using stainless hotsides - not sure. Either way, Mike is comfortable with it for his application but I wanted to avoid on mine.
