Nice! Whens dyno day?
Sent from my SM-N920P using Tapatalk
Wont be able to tune it in time, a few differences but i think it will be okay, if its a little lean at 30psi ill just add 5 to 7 psi at the rail.
Actually i just spoke with my tuner, he said it should be fine,if anything I can bump the fuel pressure a little to be safe but it should only be lean on spool up if theres a dramatic difference.
What turbine housing are you running?
1992 3000GT VR4. 4g63 Swap. DSM 2g Auto Trans. 10:1, E85, AEM, FP Super 99 turbo. Best ET 9.98...Best MPH 137.8
T3 .70ar bep housing, sane as before.
1997 Cosmos E36 M3/4/5 Boost Logic GT40/94r .85 Technique Tuning
Stock motor
1998 Estoril E36 M3/4/c4 Steed Speed2 Gt40/94r 1.06 Technique Tuning,
Built motor, Best ET ( 9.63 @ 142.61 mph MS100+meth ) 10/08/21
Best mph ( 10.08 @ 144.66mph MS100+meth ) 9/18/19
build thread:
http://www.bimmerforums.com/forum/showthread.php?2269817-Habbit-continued-Turbo-build-V
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
I wonder what this would look like on a top mount setup, poking outta the hood n chit!
My Steedspeed has no creep
Only 3.5" exhaust though.
Sent from my GTX3582R
Sorry for delayed reply - they're dumped. I can't feasibly tie them in with the steering linkage and such in the way. I'd have to re-work my turbo manifold. That will be my next project for my next engine - new manifold with boost control as a priority.
I considered this back when dealing with creep - the prob is, unless you have a stainless turbine housing, the flange will eventually crack and break off. Not might. Will.
This mod isn't uncommon... I think depending on use case, might is still the better word here you simply cannot say with 100% certainty that it will crack and break off every single time.
And there are stainless housing options out there (Tial, BW) so there's that as well.
Its more uncommon than it is common. I researched it heavily. It's most common in Sweden/etc. and when I asked around there were people saying to avoid it as they've had issues. The guys that didn't mind the risk are mostly in Sweden as well, and they tend to not mind because they pull engines out of chassis each year and swap in stockers for inspection/MOT/etc. So, just a heads up. I'm all for easy and effective but welding to a cast housing induces a potential headache.
I've seen it done here enough times... that said, I still don't think you can say with absolute certainty that it will crack. But you should certainly be aware that it could and in a bottom mount setup be ready to deal with the (potential) issue. For sure going w/ a stainless housing would be the right way to do it though.
While we're on this (off)-topic, would 309 filler be best for welding onto a cast housing?
[QUOTE=E36 HateR;29313167]
Seems Legit!
Shes going to be a screamer lol
When welded properly, they will not crack. Maximum psi has 40 or so e46 kits running with that same set up. They have had some SS manifolds crack even with proper penetration and back purging, but from my last discussions with Mike, I do not believe they have had any issues with the modified turbines. It's all in the preparation, material selection, rod selection, and penetration. Pre heat the cast iron (I forget the proper temp), weld this to a carbon steel pipe with the right filler metal, then weld the carbon steel pipe to the stainless steel wastegate flange with the right filler metal. Done.
Try it out with you own car and you will see what happen in a year ,bullshit that you have seen it many times because it will crack eventualy, search on Swedish/Norway forums and you will see the pics with cracks .
328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
9.20 at 150 on 22psi
So far so good with mine.
My worry is less with the weld, but more with the rigid design.
Especially since I'm returning into the DP. I think if it was setup for open dump, I would have less worry of cracking. There is a lot of force going on there when all assembled, then you have expansion due to heat, and movement of pipes.
I added a flex immediately after the WG, just before it ties into the DP.
I wouldn't bet $ it won't crack, but I'll hope it doesn't .
1996 332IS
Built 3.2
