The HX40 is a T3, so I'm sure I can one in that flange type. And dayum, the GT40 is a big boy. But then again the turbine housing on the HX40 is a monster, I wish I had a manifold laying around to test fit. Gonna have to do some digging I guess.
All good points, and the HX40 is a 4" intake diameter. So there would be some tight squeezing in there. I would have to do some engine mount swapping for sure.
The new manifold from Otis is AC compatible, but need new AC lines
Sent from my SM-G935V using Tapatalk
I agree whole-heartedly. And as far as simplicity, bottom mount may require a scavenge pump, so in some ways it's more complicated for a turbo this size. I'm more concerned with fitment issues back there really. Plus, stealthy bottom mount is stealthy. If bottom mount, I'll do what i have to do mount wise to get where I need to be.
I did run GTX4088R 0.95 on a Boostlogic and am now running EFR8374 1.05 EWG on a Steedspeed. AKG mounts, AC but lowered on lowering bracket and carved out tensioner mount, 4 inch oval intake to foglight area and 2.5 hotside under subframe.
Steedspeed is lower than Boostlogic. I think BL is the better manifold. EFR turbine touches FCAB eyeball. Had to grind. Could replace with mini eyeball and have plenty of clearance.
May go to 3.0 oval under subframe piping when I get new TS Steedspeed that is higher mount. 2.5 oval would give great clearance. I have scraped my 2.5 round over the years but its still there 6 years later. On a really low car, you would want oval for under subframe.
^^^no he doesnt, I has it and loves it very very much great manifold
I wish I had it. There is no end in sight on the wait for the new TS Steedspeed. For a big turbo, I think the twinscroll is worthwhile. Among the open manifolds, I'd go with Spa or Boostlogic. Boostlogic has the bigger and better wastegate pipe, but the Boostlogic is not so common these days. Spa is new and relatively cheap.
You can have solace in knowing it's being put to good use
Does suck though, I feel the frustration. Several people sold manifolds or entire set ups for the new steed...
For bottom mounts I'd try and find a boostlogic or max psi tubular. Think those are probably the best bottom mounts currently. Spa is relatively cheap and reliable, but it's a pretty crappy manifold ... from a performance aspect.
I think an extended A/C line is worth the ability to have a twin scroll tubular top mount. Also no need for a scavenge pump and ease of working on the turbo. The heat is inevitable with either setup, just need to manage it. Bottom mount twin scroll is probably somewhat best of both worlds, but it seems like the new version isn't coming around any time soon.
Infiniti G35S Turbo BMW M3/4/5 Ninja ZX6R 636
Penn State University '08...better than your school since 1855
Sigma Lambda Beta International Fraternity Incorporated
UTI Class of '10, BMW "STEPchild"
Acurazine.com Mod Squad
Modified turbine housing and blocked off spa gate port would be ideal. Making WG piping for spa sucks. Routing it sucks, and porting it sucks. Its spa's downfall. Other than that, its probably the best manifold on the market. Taking into consideration that you can trust it won't break, no scavage pump, and you can buy a WG and BOV + SPA + gaskets + bolts/nuts + piping material for the price of a fancy manifold.
I don't think we have seen the choke point of a SPA yet. EGT might get high going for 1200+wheel maybe.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
I was actually looking at the Spa manifold, but I was concerned about the scavenge pump aspect of it. To be honest I think I'd rather go bottom mount as long as it makes sense. I'm fairly certain I could have it ported by my machine shop as well. I'd have little issue blocking the WG port and going with something more custom. The shop I routinely order parts from does their own exhaust work now, so I'm fairly certain they could rig something up.
If only some hero could rescue me with a spare Spa manifold so that I could do a test fit....
