Page 1 of 37 123456789101126 ... LastLast
Results 1 to 25 of 903
Thread: E36 Hater's Phase 3, AKA what's a budget build?
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    I started with the e36 chassis as my second car, after owning an e30, swapped an m54 into my white e36 coupe and enjoyed that for a year, then swapped the driveline into a clean red sedan I found, then one day I got my butt handed to me by 2 of my buddies in hondas in Yonkers and that was where the madness began.
    Tried building a rodded engine with an hx40 and ebay cast bottom mount and it was working great until I decided to beat on the car without getting it tuned, and blew 5 ringlands, dropped in a stock bottom end 2.5L block and made 500whp at 13psi on e85.
    That worked well but I always wanted to make more power and so the fever started, I quickly learned that adding boost would worsen the addiction but satisfy me until I felt the need to turn it up some more. Swithced to a top mount manifold and upped the boost, on my original tune, 20psi made 600whp/470wtq and enjoyed that at Mpact, really competed well.
    Afterwards me and Jordan of Rk-Tunes got together and we decided to test the limits of the stock bmw bottom end, 26.5psi showed an impressive 717whp/550wtq and was holding together fine, then the stupidity rolls in.
    My turbo blew one night racing some friends of mine, I removed it and sent it out to get rebuilt, but as many of my fellow enthusiasts in this forum know, the addiction doesn't go away. I ended up buying a 160 dollar ebay turbo and put it on my car, maxed out the controller and went to town, it drove great and made plenty of power (butt dyno). My tuner advised me to let him revise the tune because it was seeing much more boost down low and knocking because she was seeing 24psi at 3200rpm, but w.e i'm dumber than I look so I decided it'll be fine, then the ebay turbo blew after a beating and being pushed very hard. Got an hx40 6064 and threw it back in and WOW it felt great to be back in a 60mm turbo that wasn't choking up top.
    A few weeks later during a 2nd gear rip riding the limiter at 7600rpm she developed severe rod knock. I believe it was due to them being weaked from the the countless knocking from the ebay turbo loading up the engine hard at low rpm, but on to a new chapter.
    It has been parked as I started a new job and I needed a dailty that I could tow to the track with so I got sidetracked and bought a 2016 Ram 1500 sport.
    That short story brings us to the current state/plans, because after a small purchase today I am back on track to rebuilding my E36.
    s52 block bored to 86.5
    CP s50 stock compression pistons for 86.5mm
    m52 crank 84mm
    Eagle 135mm rods with arp rod bolts
    Non vanos head with s50 cams and vanos added
    cutring headgasket
    6764 hx40 (billet wheel modified by Turbo Lab of America)
    Twin scroll t3 tubular polish export manifold
    single walbro 485 fuel pump
    115lb injectors from RK-tunes
    Built 2.93 188mm 4 clutch differential by the Diff god himself (Jthayer)
    M3 rear suspension/axles/brakes+ DSS shaft
    315 drag radials out back
    End result should be 9.5:1 compression 2.96L 7600rpm single vanos I6 and aiming for 8xxwhp/6xxwtq
    The goal here is a street car that can get ROMPED on with 8xxwhp and still drive home.
    Dropping the block off to the machine shop Monday, heres some pictures of my car rotting away while I enjoy my truck
    Car needs to be done by mid june the latest, as Mpact is in july and I need to be prepared for all the 6870 cars that are coming(doubt ill be able to keep up lol)
    Lets rock!
    Sep 2008
    Toronto, ON
    6465 328ti
    Quote Originally Posted by E36 HateR View Post
    I need to be prepared for all the 6870 cars that are coming(doubt ill be able to keep up lol) Lets rock!
    Word lol, I know of at least 4-6 of em coming out.
    Can't wait though! Get to work SON!
    NY/FL
    '08 G35S, '98 M3/4/5
    Hopefully our cars will be done around the same time!
    Infiniti G35S Turbo BMW M3/4/5 Ninja ZX6R 636
    Penn State University '08...better than your school since 1855
    Sigma Lambda Beta International Fraternity Incorporated
    UTI Class of '10, BMW "STEPchild"
    Acurazine.com Mod Squad
    Feb 2009
    Arizona
    1998 e36
    Now you are talking big. That is impossible with 91 octane.
    Non vanos head is inferior, it has wider valve stems, this means less flow and heavier valves.
    Sep 2008
    Toronto, ON
    6465 328ti
    Quote Originally Posted by hakentt View Post
    Now you are talking big. That is impossible with 91 octane. Non vanos head is inferior, it has wider valve stems, this means less flow and heavier valves.
    Who said he would be using 91 octane? Lol
    Ps.......
    #WhereThePicsAt
    Apr 2006
    Minnesota eh?
    86 325es
    Your funny.
    Feb 2009
    Arizona
    1998 e36
    Quote Originally Posted by e30kid89 View Post
    He said he blew two engines already so obviously he is not using racing fuel
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Hell yea bro, cant wait.
    Quote Originally Posted by Da Infammus 1 View Post
    Yea man lets hope
    i made good power with my non vanos head, it'll be fast.
    Your funny.
    Comedian
    Your right I use e70 from the local pump that costs 1.50 a gallon.
    NY/FL
    Update your own damn build thread instead of posting here, people are waiting to see your 60 day hack build.
    St. Anthony, IN
    1992 3000GT VR4
    The stock 64mm turbine wheel likely won't get you to 800whp without some major drive pressure. Also, the journal bearing isn't going to like life there long with those pressures.
    Phase 3.5 should include a ball bearing turbo with a better turbine.
    Edit: also going to need another fuel pump or a boost-a-pump. Big Wally won't get you all the way to 800whp.
    Edit2: car looks great!!
    1992 3000GT VR4. 4g63 Swap. DSM 2g Auto Trans. 10:1, E85, AEM, FP Super 99 turbo. Best ET 9.98...Best MPH 137.8
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Quote Originally Posted by familyMAN View Post
    I have my doubts but i also have my ideas, a little drip in base pressure will open up the walbro as it'll flow more fuel, and nobody thought I would get to 700whp on a single pump or 1000cc injectors.
    As far as the turbine goes, the 10 blade 64 is what im hoping to get me to 8xx, and i was still 3 inch dp with 3inch exhaust. Switching up to a short 3.5 dp to a 4inch exhaust setup will show gains especially in the 30psi range.
    Dec 2007
    Gatineau,Quebec,Canada
    1990 329tis e30
    So jealous on that rear m3 suspension.
    St. Anthony, IN
    1992 3000GT VR4
    I understand the tricks, but bottom line, you don't have enough fuel for a true 800whp, backed by trap speed.
    Does a second walbro squeeze in? Cheap way to add plenty of fuel. Also, did you punch in the relief? If not, flow drops off dramatically at higher pressure. You'll be hitting that if you are going to try to kill the holset pushing it to 800 with the small backside.
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    I am thinking about dropping in another walbro, it is an easy fit, we will see what happens.
    Dec 2007
    1990 329tis e30
    What if you put an external pump in line under the car,i think is going to help a lot.
    St. Anthony, IN
    1992 3000GT VR4
    Either an 044 inline or a second walbro 4xx in tank will do the job. Enough fuel to kill the journal bearing and holset shits itself.
    BTW. I have the same turbo. 67mm turbolab wheel and comp cover on a stock turbine that I rebuilt and assembled. .70AR open T3. Trapped 129 at 35psi. Now running 41ish on the street.
    Still making power but to get the most of the comp wheel on my 2.0, it will take closer to 50psi and I'm already pushing the limits of reliability. FP Xona rota 95-67 is likely my next turbo since it will bolt on to my manifold and downpipe.
    Sep 2008
    Toronto, ON
    6465 328ti
    Go dual pumpers. I think your 3.0L will be a lot more thirsty for fuel than the 2.5L.
    I'm in the process of doing this plus lines from the tank--->rail---->return.
    Huntsville, AL
    95 M3
    Interesting build combo with the S50 pistons with an 84mm crank. Your taking a piston designed for certain deck HT and dropping it down 1mm into a cylinder. Interested to see the results.
    WOT
    NY
    skateboard
    Please leave. Then record video of car running .
    K Thanks.
    Hi 5
    Franklin
    ― George Orwell
    Aug 2012
    CT
    Twin turbo LS E36 M3
    hell yea, this should be sick. I cant wait to see this thing in PA.
    328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
    9.20 at 150 on 22psi
    Mar 2012
    Renton, Wa
    98 m3
    Excited to see it man!!
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Quote Originally Posted by hsvturbo View Post
    Lets see, i may just deck the block to bump compression, or leave it at 9.2:1 to be able to make lots of power on 93.
    Quote Originally Posted by GG///M3 View Post
    K Thanks.
    Hi 5
    Franklin
    Hi5
    Quote Originally Posted by dburt86 View Post
    I hope so man, we will meet up for sure when its done.
    Quote Originally Posted by vollosso View Post
    Thanks man, me too!
    poconos pa
    e36 m3, turbo e36
    Do you even run 93? I thought you ran e85 only
    -sold...replaced by turbo e36
    Ship, Pa
    Red Sled, RC51
    Quote Originally Posted by beeasy View Post
    This. Went the lower compression this time?
    "Believe nothing you hear, half of what you read"
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Quote Originally Posted by Fender13Bender View Post
    Im on the fence. 600whp on pump would be nice.
  1. Just bought an e36 that sat for a year... what now?
    By morganbressler in forum 1991 - 1999 (E36)
    Last Post: 08-08-2006, 10:30 PM
  2. Replies: 3
    Last Post: 07-23-2006, 04:18 PM
  3. FI with M3 E36 and Z3 Coupe 2.8...what is the difference?
    By Oleg Coupe in forum Forced Induction
    Last Post: 08-27-2005, 06:11 AM
  4. e36 m3 with exhaust, chip, intake... what would it run?
    By ellinopedo182 in forum 1992 - 1999 M3 (E36)
    Last Post: 11-19-2004, 10:11 AM
  5. e36 shift knob usually falls off....what do must replace it with for race usage?
    By Austin in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 04-21-2003, 03:50 PM
