Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 85
Thread: N62 4.8L big bore throttlebody fits m62tu engine
  1. #51
    Jun 2008
    Windsor ON,Canada
    00 BMW 540i6
    Just wanted to post my experience with this mod. I sourced a used throttle body from a 550i. Also purchased a brand new pigtail for the 550i. I followed this exact wire diagram( I actually just re pinned the new 550 connector with the old m62 wires.
    Now the wires on the end of the m62 pins are smaller than the new n62 pins so after re pinning the new connector I enlarged the holes at the end with a spike tool to actually fit on the n62 throttle body.
    The throttle body(n62) bolts directly to the flange with no modification need( I have the m60 manifold)
    Now my experience driving with it(Dinan intake stock maf stock intake tube to throttle body, m60 manifold Dinan cat back Dinan stage 3 tune.) car pulls very strong(butt Dyno) but I did notice that to take full advantage of the throttle body you need to also upgrade or in large the intake tube before the throttle body the stock tube is only 78mm. I made a custom tube to fit and can definitely say(again butt dyno) it definitely helped power through out the entire rev rang especially up top. Was a great mod especially for the price in my opinion.
  2. #52
    Houston
    2001 740il
    Quote Originally Posted by BavarianM50 View Post
    do you have the DUDMD tune to compensate for larger throttlebody and all that stuff he does to make the car pull through all the RPMs?
  3. #53
    Jun 2008
    Windsor ON,Canada
    00 BMW 540i6
    Quote Originally Posted by Zedbimmer View Post
    No I’m running a Dinan stage 3 tune
  4. #54
    Nov 2016
    Hansville, wa
    2001 750il Chrome line
    I got a throttle body off of Ebay with the pigtail. It turned out to have different color wires. I went through TIS and figured out where each wire goes and made up a spreadsheet. I removed and replaced the TB several times trying to get it to work with no luck. I eventually ordered a new TB and after resoldering the plug for about the tenth time the car fired right up with no problems.
    I have an appointment with the dealer to install the stage 4 engine and transmission tune. I was going to go with DUDMD but because of the transmission tune I figured I would let the dealer do both. I can't wait to feel the extra power. Now I just need to get the 3.15 diff in.
    01' 750il Chromeline
    95 M3 LS swapped
    07 M5 Manual
    06' M5, Spartan wheels and a 507hp V10
    00' 740il Dinan, CAI, Romulus exhaust, Stage 5 engine and transmission tune, 750 brakes, camber plates, strut tower brace. Sold
    00' 323i wagon for daughter
    03' 525i wagon for the wife, sold
    98' 740i for the daughter, wrecked
    92' 525i with over 200k, wrecked
    02' R1200 CLC, hit by a bus and broken in half. That one made the news!
    It's like herpes there is no cure but if treated properly you can live with it for the rest of your life
  5. #55
    Everett, WA, USA
    '01 740i, '93 300ZX TT
    Quote Originally Posted by acspecialists View Post
    I got a throttle body off of Ebay with the pigtail. It turned out to have different color wires..... I was going to go with DUDMD but because of the transmission tune I figured I would let the dealer do both. I can't wait to feel the extra power. Now I just need to get the 3.15 diff in.
    1. Wire colors don't matter, pin number to pin number do. I bought a pigtail that none of the colors matched up with what has been documented and mine still fired right up because I matched pin/function to corresponding ping/function.
    2. Dima does an Alpina trans tune, he doesn't have the ability to do a Dinan trans tune. For the price you pay at the dealer, I'm willing to bet you could pay for a dyno tune with Dima and gain more power in the end.
  6. #56
    Nov 2016
    Hansville, wa
    The reason I did the color chart was to make it easier to follow during the soldering process. That is to say I agree with you but just took it one step further. Dima price wise is about the same as the dealer for the same tune. I did not know that he had an tranny tune? Also not that I ever plan on selling the car Dinan is more widely known than DUDMD. It started life in 00 and I figured I would keep it that way.
    95 M3 LS swapped
    07 M5 Manual
  7. #57
    Nov 2016
    Hansville, wa
    You called it Piotrc70, even though I called in advance and made an appointment I got surprised with an additional $400 labor quote at the dealer. With both tunes that took the cost to almost $900! My DME will be on it's way to Dima today.
    95 M3 LS swapped
    07 M5 Manual
  8. #58
    Everett, WA, USA
    That's really crappy of them. Any idea on the additional labor cost? It shouldn't take them any more than an hour to flash both. Shoot, I think with flashing both AND taking a spin with Dima, I spent maybe 2 hours there? I think you'll be really pleased with getting the flash. If you're doing the Alpina trans tune, it takes a little getting used to. The trans likes to stay in the highest gear for the speed (guessing for better mileage) so if you needed to step on it say 20-30% to catch that yellow light, it may not be enough to downshift like with the factory tranny tune. Everything else from there is an upside though.
  9. #59
    May 2013
    Rochester, NY
    2001 740i Sport
    Quote Originally Posted by PiotrC70 View Post
    This sounds to me like a good thing. I find the factory trans tune a little too eager to downshift at times when it's capable of doing what I wanted without a downshift. Waiting until you're a little closer to max power for the current gear / RPM before downshifting might not be quite as smooth an experience in some ways but it's possibly a little better for gas mileage and definitely gives a little more driver control over what the car is doing without having to shift manually.
  10. #60
    Nov 2016
    Hansville, wa
    I asked and Dima said no trans tune.
    The dealer said it would take two hours at $165 per hour. Additionally if it took more hours they would charge more. $165/hr seems a bit high to me but I guess they have to pay for the coffee and cookies in the waiting are somehow. The service writer also commented that they don't do many Dinan upgrades any more.
    95 M3 LS swapped
    07 M5 Manual
  11. #61
    Nov 2016
    Hansville, wa
    Sent my DME in on Wednesday and just got it back. Plugged it in and the car fired right up. I'm in the middle of swapping the diff to a 3.15 so I can't drive it yet.
    95 M3 LS swapped
    07 M5 Manual
  12. #62
    Jan 2013
    orlando, fl
    2001 BMW 540i 6speed
    anyone have the part number for the pig tail that goes form the n62 tb so i can wire it in to the m62 harness?
    540i 6spd DUDMD tuned-weekend brute, sounds like an M5 throaty V8 "Vtec-ish" cam noise.
    Hummer- 35inch MT's, Adventure offroad package.
    check out my video gear
    https://kit.co/Lv5multimedia/mobile-videographer-set-up
    Best Oil hands down for bmw
    https://www.amazon.com/gp/product/B0...1441c0abde2552
  13. #63
    Jun 2008
    Windsor ON,Canada
    00 BMW 540i6
    Here is the part number for the 550i throttle body pig tail # 12 51 7 602 973. Also if you type in to eBay search “550i throttle repair” it will pull up a bunch of them
  14. #64
    Missouri
    '02 540i/6
    Anyone happen to have a link to the 4" MAF?
    2002 BMW Titanium Silver 540i/6-speed Sport - ZHP Shift Knob - M5 Clutch/TTV Racing 15.6lb Flywheel - M60 Intake Manifold - N62 84mm TB - Dinan Intake Tube - 4" MAF Tube - DUDMD Tune - Magnaflow Resonator - Eibach 18mm Rear Sway Bar - Powerflex Front Sway Bar Bushings - CDV Delete - UUC SS Brake Lines - Koni Yellow Shocks/Struts - Eibach Springs - Zionsville Radiator & FDM
  15. #65
    Nov 2016
    Charlotte, NC
    '02 540i-6, '97 540i-6
    Quote Originally Posted by Iamthebull View Post
    Here's a link to one I'm selling on eBay: https://www.ebay.com/itm/323822240828
    Others like it are listed there too. I'm impressed with the quality of the MAF, but I decided not to do the mod.
  16. #66
    Missouri
    '02 540i/6
    Quote Originally Posted by R Shaffner View Post
    Looks like I found the main manufacturer of this. Thank you for your link though!
  17. #67
    Mar 2017
    Margate, Florida, Broward
    2001 BMW 740iA M Sport
    TB
    tb
  18. #68
    Missouri
    '02 540i/6
    Just ordered the throttle body for my M62tu 540i. I'm assuming this is the harness I will need? https://www.ebay.com/itm/For-BMW-E60...wAAOSwux5YSWmE
  19. #69
    Jun 2008
    Windsor ON,Canada
    00 BMW 540i6
    Yup.
  20. #70
    Missouri
    '02 540i/6
    Yup.
    Thank you. Ordered. Now to order the M60 manifold.
  21. #71
    IL
    2000 740i sport
    Anyone local to IL interested in a prefacelift intake manifold?
  22. #72
    Aug 2017
    SFBayArea
    '03 540iA, '91 850i
    MAF to TB connection
    I am in the process of doing this upgrade as well. I’ve already contacted DUDMD and he suggested the MK4 MAF which I got off eBay and I decided to spend the $$$ to get the big bore throttle body upgrade with wiring harness from Turner. Three questions:
    1). What is being used to connect the larger MAF to the larger TB?
    2). Does the stock harness connect to the MK4 MAF?
    3). I have a custom made flange that connects to the M60 IM. Does the inlet of the flange need to be bored out for the larger diameter TB? I understand there is a possibility of the flange breaking when trying to increase the ID.
    '91 850i 6sp CB42360
    '00 528iA sold
    '01 740iA Msport sold
    '01 540iA sold
    '03 540iA M-sport II with e46 m3 SMG style steering wheel with working paddle shifters, ISC N1 coilover front, Bilstein B8/Eibach sport rear, 19" Avant Garde Anthracite M359, Hella euro spec headlights, M5 aftermarket (Umnitza) foldable mirrors (painted body color), M60 IM (custom painted body color 354), powder coated valve covers (@Finish Logic; Concord,CA), Dynavin N7, Bavsound speakers, Cerwin-Vega sub (in spare wheel hub), soundproofed doors, trunk, under rear seat, wheel wells
  23. #73
    Nov 2016
    Hansville, wa
    1, I just ordered some miscellaneous hoses and adaptors until I was able to hook things up. The hard part is connecting to the TB, I ended up cutting down the original intake boot and sliding a hose over it.
    2, You install your MAF sensor in the new 4" housing.
    3, The TB should bolt right up in place of the old one. It is only a few MM larger on the inside.
    95 M3 LS swapped
    07 M5 Manual
  24. #74
    Oct 2012
    San Jose, Ca
    540i/6, 911 C4
    My m62 TB was faulty and threw codes p0221 amd p0120. I figured this was a good time to try this n62 TB upgrade.
    Purchased a used one on ebay along with the n62 connector. Cleared codes and installed the n62 TB. Now on cold starts the car idles very violently, entire car shakes for about 30 seconds. Once warmed up she drives and idles fine. That is, until the next cold start.
    Anyone have an idea what could be wrong...?
    EDIT: she runs fine now, I'm. Not entirely sure what happened I did the pedal 30 second key in reset prodedure or the Dme readapted the TB itself.
    Sent from my SM-N920T using Tapatalk
  25. #75
    Nov 2016
    Hansville, wa
    You have to reset the throttle position. I think it is turn on the key wait 30sec, turn the key off, turn the key back on and start. I can't remember if a battery nap is required? You may also have to reset the adaptations with INPA. They were all learned with the old TB and maybe even a bad one. You could just wait for the car to relearn as well.
    95 M3 LS swapped
    07 M5 Manual
  1. dinan cold air intake and big bore throttle body fits 06-10 550i/650i 06-08 750i
    By brewers650i in forum Engines, Performance Parts & Software
    Last Post: 03-24-2015, 01:49 PM
  2. Z3 E36/7 Riot Racing 68mm Big Bore Throttle Body - S52 and M52 (2.8L)
    By kobayashi in forum Z3,Z4,Z8 Classifieds
    Last Post: 09-25-2012, 10:20 AM
  3. Installing a Big Bore Throttlebody
    By jrhaile in forum 1991 - 1999 (E36)
    Last Post: 09-08-2005, 12:38 PM
  4. Does Big Bore Throttlebody Help 95 M3?
    By GQ_Style in forum 1992 - 1999 M3 (E36)
    Last Post: 05-15-2003, 03:32 AM
  5. anyone modded w/big bore throttle bodies??
    By 232is PoWeR in forum 1991 - 1999 (E36)
    Last Post: 06-22-2001, 02:52 AM
