Page 2 of 4 FirstFirst 1234 LastLast
Results 26 to 50 of 88
Thread: N62 4.8L big bore throttlebody fits m62tu engine
  1. #26
    Mar 2013
    Albany, ny, usa
    96 M3. 94 E34. 98 750il
    so what was OP's car putting down on the Dyno?
  2. #27
    Feb 2009
    KC North, MO, USA
    1996 740iL
    Non productive posts removed.
  3. #28
    Jul 2014
    Socal, California
    01 BMW 740il
    So now we know this fits and is good to go hows the performance? Hp gains or just throttle response? Bored out my stock TB a bit,not sure how much but probably just 2mm a while back since i didnt want to mess anything up or get a lean code. Recently created my own MAF housing from a 4" spectre aluminum tubing since i noticed my stock MAF had a giant crack on the side of it (tiny or no air leak). As far as performance i really felt it lit from 2.5k-4k rpm and then thats where the m60b40 manifold kicks in (4k rpm) so it felt goood all the way to redline since the b40 mani moves the powerband to 4k but my mpg dropped about 4mpg and it sometimes bogged or wouldnt respond as quick so i went back to my stock broken MAF housing.
  4. #29
    Oct 2015
    Marina Del Rey, CA
    2000 740 M Sport,
    Here is a link describing how I ported and polished my n62 throttle body athttps://www.facebook.com/kenneth.w.w...1602705563083/
  5. #30
    Aug 2012
    Austin TX USA
    2006 M3 ZCP/2001 540iT
    OP did you ever make it to a dyno?
    2001 540it Black/Black --- 2006 M3 Competition Pkg Black/Black
    **FOR SALE - E39 DINAN 540I 4" intake and filter - gently used PM ME for details.
  6. #31
    Aug 2012
    Austin TX USA
    Great post OP. So 4 months in, what are your impressions and did you ever make it to a dyno to test out?
    Quote Originally Posted by e38MSport69 View Post
    Well peeps in the quest for speed on the cheap. I already had installed a late m60 intake manifold 3-3/4 maf housing and a custom intake similar in design to the the one that AFE offers except I have a larger velocity stack inside the cone filter. I spent a grand to have the car tuned on the dyno with tuning done by Active Autowerkes. The last piece of the puzzle was the thottle body so instead of giving Dinan almost a grand I ordered an N62 4.8l thottle body. I ported and polished it before installing it.The only hassle was getting the connector from harness to convert the connector to the new throttle body I have the conversion wiring chart and will post it.Attachment 569177
    Here is the wiring chart to convert from M62tu wiring to the N62 connector.
    Attachment 569178
    Have at it peeps. This throttle body is 4mm bigger than the stock one. I have been running mine for over a week with no codes.
    Quote Originally Posted by Brahh740il View Post
    you needed a tune for that MAF
  7. #32
    Dec 2010
    Atlanta, GA
    E38 7er, E46 M3
    I had a Dinan Cold Air Intake laying around in my garage. I got bored the other day and decided to play around with the new E38.
    I sourced a throttle body from a E60 550i ($20 shipped LOL), rounded the square edges, then polished it.
    I’m only missing the earlier design M60B40 intake manifold with the velocity stacks and the 4” mass air flow meter housing.
    The VANOS M62 motor is so weak once pass 5k RPM. Hope this will help a little.
  8. #33
    IL
    2000 740i sport
    Quote Originally Posted by Reflex View Post
    I wanted to try this as well... Can't you use one of these?
    https://rover.ebay.com/rover/0/0/0?m...2F253225935479
    Doesn't the M60 manifold help gain power at higher RPMs but lose Torque at lower RPMs?
  9. #34
    Dec 2010
    Atlanta, GA
    E38 7er, E46 M3
    Quote Originally Posted by purplecty View Post
    When I was building my ‘98 740iL to Dinan specs, I bought a MAF housing from those guys. The issue I noticed with the aluminum MAF housing was that it got so hot where you couldn’t lay a finger on it. Does it effect the performance? That I don’t know but there must be a reason other than the cost on why BMW opted for the plastic housing rather than aluminum. So this question came to my mind; Is the N62TU MAF housing bigger that the M62TU MAF housing? Since it uses a much bigger throttle body (85 MM), it is a possibility that it has a bigger MAF housing as well where we can just swap in the M62TU MAF sensor in. However I am not certain yet.
    I’m not sure if you lose power with an early M60B40 intake manifold. I read yes answers and no answers.
  10. #35
    Jun 2013
    Toronto, Ontario
    '95 740i
    I think numbers stay pretty similar, but the tq curves are different.
    People can argue "Makes no more power, 280tq vs 282tq" for instance, but the 280 might not show up for very long, where 282 can show up from 800rpm <--- extremem examples.
    It's my biggest pet peeve with people, "Bro my 2.4L makes 400whp" . . . yeah but only at 5500rpm-5508rpm it's virtually useless.
    || 1995 740i || M60B40 || DUDMD || ̶o̶r̶i̶e̶n̶t̶ ̶b̶l̶u̶e̶ Mercedes Brilliant Blue Metallic || Style 168 Wheels 1" Spacers ||
  11. #36
    IL
    2000 740i sport
    Ok im going based off reading. I have always wanted to give this a go but it never gave me enough motivation based on the results i have read... My buddy has an e60 550i i will take a look at his MAF housing and compare it to the e38...
    Sent from my SM-N910T3 using Tapatalk
  12. #37
    Dec 2010
    Atlanta, GA
    E38 7er, E46 M3
    Awesome dude. Please measure the inner diameter. It would be great if we could stick to the plastic MAF housing instead of aluminum. Not to mention we can source them for 1/3 of the price online and even less from junk yards.
  13. #38
    IL
    2000 740i sport
    Realoem shows the housing for the MAF on the e60 is a part of the air filter box...
    http://www.realoem.com/bmw/enUS/show...diagId=13_1166
  14. #39
    Dec 2010
    Atlanta, GA
    E38 7er, E46 M3
    Sourced a 90MM MAF housing. Practically a copy of our stock Bosch MAF housing but bigger. Just placed the order. Will keep you updated.
  15. #40
    IL
    2000 740i sport
    From where? You can probably cut out what you need from the n62 air filter housing as well...
  16. #41
    Dec 2010
    Atlanta, GA
    E38 7er, E46 M3
    Found out from a friend that the N62TU MAF is somehow smaller than the M62TU MAF housing.
  17. #42
    IL
    2000 740i sport
    Any updates on this?
  18. #43
    Jul 2011
    hillsborough n j
    2001 540i sport 6spd
    So has anyone reviewed this mod yet? Butt dyno or real dyno?
    ~2001 540i/6speed~
    Schmiedman M5 headers, SPEC stage2+ kevlar clutch, JBR 11lb lightweight flywheel, ESS Tuning m60 manifold software tune, 3" SS freeflow OBX catback, afe cold air intake, m60 intake manifold, Cdv delete, powerflex urethane sway bar bushings, M5 rear sway bar ,Autozone replacement driver side blinker light bulb, 545 short shifter zhp weighted, "dsc off" sticker, m5 3.15 lsd differential, m5 chassis rods, akebono ceramic pads, G2 caliper epoxy, ecs braided lines, BC-Racing br-plus series w/swift springs 8/6~
    On the night that I go back in time, you will be shot by terrorists. Please take whatever precautions are necessary to prevent this terrible disaster.
  19. #44
    Jan 2013
    orlando, fl
    2001 BMW 540i 6speed
    Quote Originally Posted by topaz540i View Post
    im getting the tb and harness this next week so ill let you know lol
    540i 6spd DUDMD tuned-weekend brute, sounds like an M5 throaty V8 "Vtec-ish" cam noise.
    Hummer- 35inch MT's, Adventure offroad package.
    check out my video gear
    https://kit.co/Lv5multimedia/mobile-videographer-set-up
    Best Oil hands down for bmw
    https://www.amazon.com/gp/product/B0...1441c0abde2552
  20. #45
    Mar 2011
    Greenville, NC
    2001 7-S62, 2002 X5 S2,
    Or bolt my stuff on :-P
    https://www.ebay.com/itm/223218633230
    2001 | DINAN 7 Sport | S62 Swapped 6-Speed
    DINAN Springs & Exhaust | 750 Brakes | M-Pars | Monsoons | NBT Nav/Radio
    Dual Pane Glass | Black & Sand Int.
    2001
    | 750iL | AlpineWeiss III
    @scotthduke on Instagram
  21. #46
    Mar 2016
    Idaho
    540i. 525i
    N62 to M62TU throttle body swap on e39
    I’ve been looming at this thread for awhile and decided to do this. I’m so sorry but I don’t understand the labels on the wiring conversation diagram.
    N62 connector has bl brn w rd pl brn/rd for a total of 6 wires.
    Could you please tell me what colors each of these should solder to on the M62TU throttle body harness?
  22. #47
    Jan 2019
    Norman, OK
    2008 BMW 750Li
    Well done on the conversion! I'm actually looking at doing the opposite. I have an 08 750Li E66 with the N62TB drive by wire. Its my only frustration on the
    car- It has a lag-surge on acceleration and I have not been able to fix it with computer updates etc...
    I'd actually like to convert to a drive by cable set up like the 94-98 E38s have. Do you think this is possible? The goal is not necessarily more performance, but
    smooth, linear acceleration.
  23. #48
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Not a chance - if you have lag you have a problem that needs rectifying first - and strangely the most likely cause is the gearbox which is known to cause these kind of problems. I have the same engine in my 650i and it is lightning-quick on acceleration, but is was quite sluggish until I had the gearbox fluid, filter and seals replaced....
    My BMW Repair YouTube Channel
  24. #49
    Mar 2016
    Idaho
    540i. 525i
    Can you please tell me what colors on the N62 to connect to which color wires on the M62tu? I’m not smart enough to figure out your wiring chart, sorry to bother you
  25. #50
    Sep 2017
    Las vegas
    540i
    Does the flange between the tb and manifold need to be expanded for the n62 tb when doing this conversion?
  1. dinan cold air intake and big bore throttle body fits 06-10 550i/650i 06-08 750i
    By brewers650i in forum Engines, Performance Parts & Software
    Last Post: 03-24-2015, 01:49 PM
  2. Z3 E36/7 Riot Racing 68mm Big Bore Throttle Body - S52 and M52 (2.8L)
    By kobayashi in forum Z3,Z4,Z8 Classifieds
    Last Post: 09-25-2012, 10:20 AM
  3. Installing a Big Bore Throttlebody
    By jrhaile in forum 1991 - 1999 (E36)
    Last Post: 09-08-2005, 12:38 PM
  4. Does Big Bore Throttlebody Help 95 M3?
    By GQ_Style in forum 1992 - 1999 M3 (E36)
    Last Post: 05-15-2003, 03:32 AM
  5. anyone modded w/big bore throttle bodies??
    By 232is PoWeR in forum 1991 - 1999 (E36)
    Last Post: 06-22-2001, 02:52 AM
