Results 1 to 4 of 4
Thread: FS:E36 LS Swap Kit
    Northern CA
    96 328is
    FS:E36 LS Swap Kit
    Recently ripped apart my LS swapped e36 due to engine failure. All parts have 3k miles on them or less
    I have a wiring specialties e36 ls1 swap harness for sale. Comes with their flashed ecu, the coolant setup for the stock gauge, and the adapter oil pressure sensor. Only modification to the harness is the maf wires were extended to run the intake on the passenger side. Also comes with
    electric fan with plug wired to work with pcm
    looking to get $950 or best offer
    also have the rest of the full swap kit pulled from my completed swap
    steel driveshaft with jtr flange and t56 yoke: $400
    jtr headers painted with ceramic header paint: $400
    vorshlag power steering kit:200
    vorshlag t56 throw out bearing and aluminum master cylinder: $400
    replica vorshlag motor and trans mounts. Trans mount has sent from speed bump but still works: $400
    Aug 2017
    salem, or
    E36 318IS LM7 swap
    Are any of these parts still for sale by chance?
    Quote Originally Posted by AdamE36M View Post
    May 2017
    Miami
    99 323I Conv
    Do you still have the harness and headers?
    Mar 2018
    Arizona
    1998 328I
    hello do you still have the jtr flange?
  1. New age hot rods e36 ls swap kit - No Longer Available
    By Nightridere3695 in forum Drivetrain & Transmission Parts
    Last Post: 10-24-2015, 10:27 AM
  2. e36 ls swap kit - No Longer Available
    By 1FRacing in forum Drivetrain & Transmission Parts
    Last Post: 05-05-2015, 12:07 PM
  3. E36 Wtb s52 or ls swap kit
    By brandon10s in forum BMW Parts Wanted
    Last Post: 09-19-2012, 05:22 PM
  4. E36 FS: Full ZF swap kit minus trans
    By Asmod3us in forum Drivetrain & Transmission Parts
    Last Post: 03-23-2010, 06:03 AM
  5. E36 FS: Full ZF swap kit minus trans
    Last Post: 03-10-2010, 08:06 AM
