My roof is sagging pretty bad on the sun roof and right behind it too. Is there a way to fix this without going to a shop?
You could get the material and re do it yourself.
pretty easy job, just need a can of spray adhesive, I used 3m.
when mine was saggy, I tried to do a temp. fix by gluing those parts, but it fell again.
I am in the process of redoing my headliner and sunroof shuttle, will be trying to reuse the OEM fabric after giving it a few washes and scrubbing off the old foam. Have read that others used this method so I cannot attest to the quality.
1999 M3
2001 525iA
2007 F150 Sold
1995 M3 Sold
1987 528e Sold
1985 325e Sold
My sunroof is also sagging with means I can't use it. Worried if I buy the spray and try myself it might be unsuccessful. Which 3m spray strength so you use?
I don't remember what strength I used, but it was pretty easy, much easier with two people.
The headliner was about $40-$50 if I recall of Amazon.
You could watch a guide off youtube.
Remember not to spray too much or it will bleed through, and do it in segments.
After you do one part, just smooth it down, it is like an easier process of vinyl wrapping.
