Hello i have:
M50b25 non vanos
Eagle rods
Custom pistone
Gt35 turbo at 0.8 bar
M51 TDS crankshaft
On Monza i destroyed One connecting rod bearing, do you know if Turbodiesel crankshaft is a trouble on this engine?
I used good solution?
I used a M51 crank to stroke my M52B20. Be careful with setting the cam timing. The M51 crank has only one keyway in the front and its not engaging the crank sprocket! I have it ca. 11000km now and a did couple of trackdays with no problems regarding the diesel crank.
