Hi all.
I have a 2011 m3 and I would like to use the launch control but can't seem to get it to work. I was wondering if having a piggyback tune on it (chip) will effect it. I bought the car with the tune, exhaust and cold air. I am going to the track the day after tomorrow and really would like to use it. I was just wondering if the tune may be the issue.
Thanks for your help.
Press the brake and then the gas at the same time to engage launch control. Then u can can just press the gas and it will launch if you have smg if you have 6mt I dunno
It's a DCM trans. There is a method to engage it but that's not it. But thanks.
Anyone have any ideas?
Well I figured it out on my own. (thanks any way).
Seems that when you have a memory button set and you use that it won't allow you into launch mode regardless if the setting are correct for the launch mode or not. I turned on everything manually and did not use the preset memory button and it came on.
