Page 4 of 6 FirstFirst 123456 LastLast
Results 76 to 100 of 127
Thread: Maximum PSI Stage 2 e46 M3 burning E85/E70; The pleasure of owning and driving.
  1. #76
    Suffolk, Virginia
    35D X5, 335d
    Quote Originally Posted by bubela View Post
    Not sure if my other set will fit this car. I'll check it out. The closest E70/E85 station is about 20 miles from me, so I put this together. I couldn't get the caps open, so I made a special tool from a BMW sway bar and bolts. Perfect.
    I highly recommend Mickey ET Street S/S drag radial. I just cut a 1.64 60ft in a 3885lb e91. Love the tire!
    OLD
    E30
    636whp
    1/4 mile: 10.91@144.38
    http://www.youtube.com/watch?v=L_f7fUVqblI
    NEW BUILD
    335d
    520whp
    635wtq
    120.51mph trap speed
  2. #77
    Suffolk, Virginia
    35D X5, 335d
    The supra people have a joke. What the difference between a 600whp supra and a 1200whp surpra? 2 tenths.
    Hahaha
    OLD
    E30
    636whp
    NEW BUILD
    335d
    520whp
    635wtq
  3. #78
    May 2003
    quebec
    |99 Turbo M3 | 2K7 335|
    sale pending on my E36.. then I need to find one of those MaxPSI E46 ;-)
    _____________________________
  4. #79
    Norristown PA
    mostly bmw
    Quote Originally Posted by gnarfy View Post
    Sounds like a good plan.
    Quote Originally Posted by futureroadracer View Post
    I might just go this route.
    95 turbo 330ti. 01 maxpsi m3 e85. 01 m5. 01 m coupe. 03 AIM 996t e85. 06 x3 w/Meyers plow and winter daily. Prussian Motors is hiring!! prussianmotors.com/jobs
    Current e39t LS Turbo swap: https://www.bimmerforums.com/forum/s...LS-e39-Touring
  5. #80
    Sep 2008
    NJ
    96 M3, 97 M3
    shoot me an email sales@maximumpsi.com , we can take you to the moon!!
  6. #81
    Louisville, KY
    turbo m3
    Where are you posting these days, Ryan (if I remember correctly your name)?
    E90post?
    This is my signature....
  7. #82
    Suffolk, Virginia
    35D X5, 335d
    Quote Originally Posted by BadBoostedBmwM3 View Post
    Where are you posting these days, Ryan (if I remember correctly your name)? E90post?
    Diesel section of e90post. I'm still around, just busy with life/kids.
    OLD
    E30
    636whp
    NEW BUILD
    335d
    520whp
    635wtq
  8. #83
    Louisville, KY
    turbo m3
    I was just about to say... That's quite a bit of torque to get that pig moving.
    About the sane here. Working on the kids part... But, I've been enjoying the hell out of 6.7 powerstroke with a few parts missing.
  9. #84
    Norristown PA
    mostly bmw
    I had to move the carpet over next to the car while I was working on it because the fawn dog wanted to watch. Not long after, I turn around and there are two dogs.
  10. #85
    Apr 2006
    Manchvegas
    Boosted M3’s
    Man you have skills ;-)
    I wish I could do a 1.64 60ft
    1997 Cosmos E36 M3/4/5 Boost Logic GT40/94r .85 Technique Tuning
    Stock motor
    1998 Estoril E36 M3/4/c4 Steed Speed2 Gt40/94r 1.06 Technique Tuning,
    Built motor, Best ET ( 9.63 @ 142.61 mph MS100+meth ) 10/08/21
    Best mph ( 10.08 @ 144.66mph MS100+meth ) 9/18/19
    build thread:
    http://www.bimmerforums.com/forum/showthread.php?2269817-Habbit-continued-Turbo-build-V
  11. #86
    Suffolk, Virginia
    35D X5, 335d
    Quote Originally Posted by Mod Addict View Post
    Man you have skills ;-) I wish I could do a 1.64 60ft
    Thanks but not really. It's an automatic. Hahaha.
    OLD
    E30
    636whp
    NEW BUILD
    335d
    520whp
    635wtq
  12. #87
    Manchester, N.H.
    96 332IS 6466 turbo
    Honesty is the best policy.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  13. #88
    Sep 2008
    NJ
    96 M3, 97 M3
    Bump!!
  14. #89
    Norristown PA
    mostly bmw
    Not much to report. I literally moved to work, so I don't commute anymore. That said, I still have a couple thousand miles on this car since picking it up from Maximum PSI. Took it to the park the other day with the dogs in tow. I try to keep the paint clean, but the dogs keep the back seat a bit dirty. I run errands, bank, food shopping, home supply store, etc. I pretty much always go across the bridge when I leave so I reach 4th gear with my foot still in. Haven't been back to Atco since getting an alignment and new tires. Maybe soon. Also, my home supply of e71 is getting low. I heard that e86 is coming out of the tap now-a-days. =) Look forward to seeing how the car adapts to the "high test".
  15. #90
    Jul 2002
    Long Island, NY
    98 Turbo M3, 04 E53 X5
    Love this E46 M3. I need one in my life.
    98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
    2017 Toyota Tundra Crewmaxx - Family Whip
    2011 Pierce 75' Quint - Fire Apparatus West Islip FD
  16. #91
    Norristown PA
    mostly bmw
    Got a fresh batch and mixing with the old, in-tank. Figure I'd let the ECU adjust a little before e85 is in use. Plan is to see how it performs in the 1/4 at Bimmerfest a couple weeks from now.
  17. #92
    Norristown PA
    mostly bmw
    The clutch I bought the car with does not seem to release at high RPM as quickly as I would like. So, I went with this unit from Maximum PSI. I've heard good things.
    I conjured my inner-Perry, but I'm calling it a day. Should be able to test drive tomorrow night.
  18. #93
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    You're sure it isn't a hydraulic issue? I was having high epm disengagement issues and it was my slave /worn rubber clutch line.
  19. #94
    Vancouver, B.C., Canada
    '97 M3
    What is the weight of that clutch/flywheel combo?
    Sent from my GTX3582R
  20. #95
    Norristown PA
    mostly bmw
    Yup, pretty sure it's not a hydraulic issue. Everything looks solid on the car. We'll find out soon. Finished up earlier today but it's raining. Not a fan of driving this car in the rain.
    The clutch/flywheel combo is indeed quite heavy. I wanted to weigh it, but forgot to. I even already re-used the box if shipped in (I could have grabbed the weight off the shipping label). I'm guessing it's in the 40 pound range.
    Once thing that's noticeable so far is the resistance on the clutch pedal. I'm sure everything will like the decreased load. (including my knee!)
  21. #96
    Norristown PA
    mostly bmw
    Installed the new clutch and broke it in on the way to Bimmerfest. I like it better than the outgoing single disc clutch. Also, no more release issues. Held tight and shifted smooth.
    As often the case with me, my first run of the day was my best. Not to say I have any good slips to show for it. The track didn't seem prepped well, and spun a lot, but still had fun trying!
  22. #97
    May 2003
    quebec
    reaction time is good, but you can make better then 16.3sec I am pretty sure
    ;-P
  23. #98
    Apr 2008
    Bay Area, California
    01M5, 99M3 Supercharged
    That is a badass gauge you have on the left.
  24. #99
    Norristown PA
    mostly bmw
    I got my old 17" 275 MT drag radial to fit the e46 m3.
  25. #100
    Norristown PA
    mostly bmw
  1. Maximum PSI Turbocharged E46 M3 in European Car Magazine/Tuner GP!
    By mike radowski in forum Forced Induction
    Last Post: 12-18-2013, 10:15 PM
  2. Maximum Psi Turbo E46 M3 - Bimmerfest and Mfest Recap
    By maximumpsi in forum Forced Induction
    Last Post: 06-07-2013, 03:08 PM
  3. For sale brand new BMW e46 m3 wheel well housing covers. Pair of left and right
    By MalikSaab in forum Georgia sponsored by Harrison Motorsports
    Last Post: 11-28-2011, 09:15 PM
  4. Replies: 23
    Last Post: 09-28-2009, 02:18 PM
  5. Test-fit e46 M3 "front" wheels on the rear of my Touring
    By dmoffitt in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 01-23-2009, 01:06 PM
