So this is accurate. About 14 gallons used. =)
20160331_202717.jpgsee
So... I still work on this car myself after Maximum PSI did all the work on the ethanol upgrade.
Worked out a deal with VAC for one of their ATI Super Dampers. I found that if you file the water pump pulley fan tool down a little, it can double as a crank holding tool as well!
Changed the oil while it was up and will soon have a different set of wheels on the car.
95 turbo 330ti. 01 maxpsi m3 e85. 01 m5. 01 m coupe. 03 AIM 996t e85. 06 x3 w/Meyers plow and winter daily. Prussian Motors is hiring!! prussianmotors.com/jobs
Current e39t LS Turbo swap: https://www.bimmerforums.com/forum/s...LS-e39-Touring
Not many cars I'm jealous of, well. ...
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Prussian Motors, man! http://store.prussianmotors.com/
Bought the building in October. I put a lift in the corner for my personal projects. =)
1996 332IS
Built 3.2
OLD
E30
636whp
1/4 mile: 10.91@144.38
http://www.youtube.com/watch?v=L_f7fUVqblI
NEW BUILD
335d
520whp
635wtq
120.51mph trap speed
Thank you sir. It's a pleasure.
We take donations. Honestly, we do buy customers stuff that are in the same boat you are. Usually they are local. Converting an e36/e46 into a track car and dump their interior on us. It's much easier for them to say "here, sell this" and we give them pennies on the dollar. It's a bit of a pita to sell some of this stuff. Half of it we end up tossing ourselves. If you want to send me a list, I could save you the trouble of boxing up the items that I may just toss. Or, if it's easier for you.. box it and ship it!
Thank you Ryan. We moved less than a mile from the shop you visited us at. The new one is about 5 times bigger, but we have almost no outside space for parking. Still, very happy with the upgrade. =)
This is running on some pretty crummy street tires. Can't wait to get some sticky tires on the car.
Left lane was a worked Mustang Cobra on street tires. Said he was putting 675 to the wheels. It was fun to move past him at the end.
675 wheel trapping 123 ?
Sounds like 175+ over estimated.
132 with your e46 is bad ass.
Very impressive.
1996 332IS
Built 3.2
There's definitely more in this car. I had to pedal so much it wasn't funny. I'm known for going through the trap sideways, so I guess it's good I stayed straight. I was trying to avoid having two sets of tires for this car, but it seems to be inevitable.
The highlight of my night however was watching Donovan do this. Didn't even know he was going to be there.
So some Mid 11's and 135ish if she can stick and you stay on it..... I'd say not so bad!!
~Ken~ '99 M coupe THE "original" TT Stage 3 - HTA3586R; 701 whp 672 wtq @ 26.5 psi ; NeverSell - CoupeCartel
12.0 is terrible if you ask me. I'm shooting for 10's. Basically, it's the tire. I also had some issues catching all the gears. Not sure if the clutch was releasing fully or my trans already hates me. (or/Driver)
Mike ran mid tens at 135mph. Don't know what PSI he was running to attain this. He was also on skinnies/slicks, which helps, a ton.
Well yea with some "real" tires 10's are in your future. Will the set from the other car fit?
I can run 14's at almost 140 !
1996 332IS
Built 3.2
Not sure if my other set will fit this car. I'll check it out.
The closest E70/E85 station is about 20 miles from me, so I put this together.
I couldn't get the caps open, so I made a special tool from a BMW sway bar and bolts. Perfect.
