Results 1 to 25 of 43
Thread: Highest Mileage seen out of the E38
    Nov 2013
    Austin,Texas
    2000 740iL & 1991 318iS
    I have got up to 202,XXX miles and I want to know how much more I can expect from it. What kind of maintenance had to be done on your 7's. Should I think about selling it by now? Its a 2000 740il very clean chrome m pars, black interior, Cosmos Schwartz
    I've put new *timing chain guides *Oil sep. valve,*chain tensioners, *beysian systems vanos seals, *new gaskets from lower pan to intake gaskets,*crank case vent valve,*crank sensor,*cam sensors both banks,*transmission service fluid+filter*differential service and I'm sure a lot if other things
    Rutland, Vermont
    E30 E38 E46 E85 F150 GTI
    I'd keep driving it. If things break, fix them. It'll never just fall apart on you. If it looks good now and you take care of it, it ahould look good later too. Maybe at some point you'll have a major system failure, like the engine or transmission. Those are fixable.
    In full disclosure I noticed my mileage was up to 191919 the other day, so at 202k, it'll be just another day in the life.
    2000 740i Sport | 2004 330xi | 1988 325i Vert | 2003 Z4 2.5 | 1995 Ford F150 | 2018 GTI
    Nov 2008
    ATL
    1998 740i : 6-1-14 311K
    I have 346k. History of fixes since new: Valley pan (2x), A/C compressor, Torque converter (still in the process), shocks & struts (installed coilovers), Radiator (2x), water pump, fan clutch, Cam position sensor, and drive shaft bearing. Still have not done the timing chain guides (lucky so far).
    You have got so much more to look forward to before anything catastrophic.
    Jan 2016
    Houston
    tbd
    Quote Originally Posted by likedatyalll View Post
    346 with no Guides!!! I guess that's what honest and up-kept maintenance will do for you. well played.
    Nov 2008
    ATL
    Quote Originally Posted by Lamer321 View Post
    Thanks.
    Sep 2011
    Crawfordsville, IN
    96 750il
    Holy cow, man. That is awesome!! I guess the mystery of what actually causes guide failure continues. We might find bigfoot before we know for sure!
    Windy City, USA
    2010 750li & 2008 X5 4.8
    that's got to be a record. 346k and no guides done. congrats.
    (northeast) Indiana
    15 650ix GC & 14 X5 50i
    I have 346k. ... Still have not done the timing chain guides (lucky so far).
    This is the thought running through my head:
    {hmmm, ok...add index marker to mental rolodex....346k on odometer...M62 engine...original timing chain guides still intact}
    Aug 2015
    california
    1996 BMW 740il
    It just depends on the motor from what I've heard. I'm not an expert, but from talking to multiple shops they have told me that if you have a non vanos m62 you are putting less strain on the guides and they are far less likely to go bad then an m62 with vanos. I have a 96 740il with 204,000 miles still on the original guides. And hoping not to touch them, but if it happens it happens and it'll just be another thing to fix.
    Apr 2009
    grimshaw, AB, canada
    1988 735i,'95 740i,x5
    398 on my recently retired '97. Still runs, and drove fine, but. Not worth fixing. So stripping it
    Jun 2015
    Takoma Park, MD
    01 BMW 740il
    What are the intervals of your oil changes?
    Mar 2013
    Albany, ny, usa
    96 M3. 94 E34. 98 750il
    Quote Originally Posted by Bmindt View Post
    I can see the vanos theoretically causing more stress on the guides, but i think there's more to it than that. note** I recently took apart a well maintained M62 non vanos at 150K. The engine was spotless inside, but the guides were in pieces.
    my 98 750 hit 210k on the way to work today. I plan on getting it to at least 300K
    Feb 2013
    The Motor City
    1997 750 IL
    I'm @ about 180K on the 750 and it runs like new. Seems like 300 is not going to be a problem.
    Sep 2014
    Chicago, Il / Denver, Co
    '01 DINAN7 '03 M5
    We can make it sounds more impressive by posting it converted to kilometers lol
    550000km
    Instagram.com/nordmanmg
    Your current situation is not your final destination
    Mar 2013
    Albany, ny, usa
    Quote Originally Posted by xboss View Post
    Mine runs like new also. I work at a new car dealership, and the engine is quieter than most of our new cars.
    Nov 2008
    ATL
    Quote Originally Posted by oatmealwithwate View Post
    8-10k Castrol Edge (gold) full synthetic and I have stretched it to 15k a few times (laziness).
    I have dropped the oil pan twice to check for plastic bits and nothing so far (fingers still crossed).
    Nov 2007
    Lees Summit, Missouri
    97 E38, 00 E39 M, 15 F25
    I have 346k. History of fixes since new: Valley pan (2x), A/C compressor, Torque converter (still in the process), shocks & struts (installed coilovers), Radiator (2x), water pump, fan clutch, Cam position sensor, and drive shaft bearing. Still have not done the timing chain guides (lucky so far). You have got so much more to look forward to before anything catastrophic.
    Congrats on your car bucking the trend! 346 is impressive anyway, with or without the guides. Out of curiosity how long have you owned the vehicle?
    My car is only a few miles from 275k, I have had the chains done while the top end was rebuild more as preventative measure.
    MODS:18' Chrome M-Pars, 6000k Xenon Lowbeams and Chromelined Headlights, 01 Tails, Clear Corners and Side Markers, Boston G2 Sub and Gt22 Amp, Dinan CAI, 20% Tint, Hardwired Passport 8500i X50 Radar, Predator Chromium DDE Angel Eyes, Tri Stitched M5 Sport Steering Wheel, MKII Navigation Retrofit, Einbach Prokit Springs, Quad Brake Light Mod, Dice MB 1500, Powder Coated Valve Covers
    Jun 2015
    Takoma Park, MD
    01 BMW 740il
    I see that the location is in ATL. Was it always in ATL for its lifespan?
    Aug 2011
    2001 740i Sport
    my brothers 98 540i (same engine as these cars) has over 365k miles on it and no guides replaced. It can be done.
    Aug 2013
    Indiana
    95,97 98 2000 2001 750il
    257,000+ on the 95 and climbing. Of course when it finally gives up the ghost I have others to fill it shoes as a daily driver.
    Mar 2012
    Bristol, TN (ish)
    03 325xi, 01 740iL
    I think the "startup rattle" that seems to be more common on the VANOS engines due to the VANOS check valves allowing drainback is the real reason that the VANOS engines (seem to) eat guides more often. The stress on the guides with low oil pressure starts has to be causing them fatigue.
    </speculation>
    Current:
    2009 xdrive35D
    Past:
    2003 325xi
    2001 740iL
    1993 740iL
    Jul 2014
    E46 M3
    247k, give or take 500 miles, odo stopped counting for a week or two (wheel speed sensors)
    "Engine in the front. Drive in the rear. And a big smiley piece of meat in the middle." - Jeremy Clarkson
    Nov 2008
    ATL
    Yup but more so north GA than ATL. The car used to be driven from Cartersville, GA to Chattanooga, TN everyday for work. Now she is more of a local car.
    Quote Originally Posted by victoriabmw27 View Post
    Owned since the end of '99.
    Time to bring her back to her former glory (new shoes (19"), new paint (hood looks horrible) , new stereo, better front seats... maybe a "facelift").
    Dec 2014
    Brooklyn NY
    1994 525i 2001 740iL
    Hello,
    max E38 miles - 506,259 miles, not KM in case listing gone VIN=WBAGJ8329WDM10009
    Stock #: B1376
    VIN #: WBAGJ8329WDM10009
    Mileage: 506259
    Transmission: Auto
    Condition: Excellent
    Exterior: Alpine White
    Interior: Tan
    https://www.hemmings.com/classifieds...l/1876552.html
    Dec 2014
    Brooklyn NY
    owned a 2001 BMW E38 740iL since Nov 2014 @ 139xxx miles now 155xxx miles, White Sports Package, debating if I should sell or not, breaking up is hear to do, but I am getting older. mostly 50 mile round trip no traffic drive avg 25/26 MPG and engine/trans extremely smooth have to learn how to post PHOTOD
  1. goodbye i am out of the e36 family for now..(new e38 owner)
    By Young Pete in forum 1991 - 1999 (E36)
    Last Post: 02-26-2009, 12:30 AM
  2. Airbag light on - out of the blue
    By AgileM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-01-2002, 08:00 PM
  3. How 2 get the best out of the HK system?
    By ///Manuel in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 03-17-2002, 06:55 AM
  4. Replies: 12
    Last Post: 09-10-2001, 04:23 PM
  5. Anyone seen pictures of the SO3's?
    By T///MW in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-19-2001, 04:02 PM
