Center console Cupholders and Coin Holder in good shape?
Hello everyone,
this is a long over-due update to this thread. I can't believe it's been 6 months and I'm just sitting on e36 parts. Some of you I PM'ed a reply, but I just wanted to put all this in the thread anyway.
The car was removed from the parking lot where I was storing it in early March. It was sold.
That was damaged in the accident.
At that point the car was gone, so I didn't have any of these pieces.
No, they were sold with the engine.
Not sure why the mods listed this in upstate NY (maybe because my profile had me living there once?) But the car was in Long Island. Anyway, this part was damaged in the accident.
Yes! Sorry I haven't replied. Both are still available. The Stealthboxes have deteriorated rubber though - they need new foam rubber gaskets. The lighted weighted shift knob works, but the backlight wire was accidentally damaged in the removal process. You'll need to do some repair there too.
The exhaust was sold. The folio is available. I'll PM you some info on it.
They are, but they have been wrapped in CF to match other parts of my interior.
The interior for sale can be seen here:
https://flic.kr/s/aHskFHWUMr
1995 OBD I Cosmos Black M3 - RIP: gone but not forgotten
Do you have the driver side front fender and door? I am looking for these in good condition (no bends or prior repair / body filler).
Thanks!
I need (1) 18" CSL Replica Wheel PM me if you have!
Thinking of buying from BAV TOYS... Think again...
http://forums.bimmerforums.com/forum....php?t=1179527
See previous post. Car is gone so can't take specific requests.
Motor still for sale ?
― George Orwell
I need a black (cosmos) M3 rear tow hook cover. Please PM me if you have one.
Hi folks, for those NOT reading the posts, the whole car is gone... these are the parts that are left:
Items for sale:
Maintenance items :
Peake Research R5 / FCX-R2 Engine scan reset tool (1987-2000)+ manual. $100
Peake Research R5 / SRS Airbag scan reset tool (1994-2003) + manual. $100
Bentley Manual e36 BMW - $25
K&N 33-2990 drop-in filter for stock airbox - $25
Spare parts : (all parts new in packaging)
Engine
11-42-7-833-769 Mahle oil filter kit - $7
11-12-1-718-856 Valve Cover Stud - Cylinder Head to Valve Cover (7/6 X 29.5 mm) (QTY 4) - $5 ea or all for $10
Interior
64-11-9-069-895 Cabin air filter (QTY 2) Airmatic brand from PelicanParts - $10 ea
Exhaust
18-11-1-723-720 Gasket Ring - Catalytic Converter to Rear Muffler (48mm) BMW from PelicanParts - $5
18-11-1-719-446 Gasket Ring - Catalytic Converter to Rear Muffler (48 mm) BMW from PelicanParts - $5
11-72-1-437-202 Copper Collar Nut - Exhaust Manifold to Cylinder Head (7 mm) (QTY 9) - $1 ea or all for $5
Brakes
34-32-2-227-381 Front left or right brake hose OEM/ATE from PelicanParts - $10
34-32-1-159-524 Rear left or right inner brake hose (QTY 2) OEM/ATE from PelicanParts - $5 ea
34-35-1-181-342 Brake pad sensor rear right PEX brand from PelicanParts - $5
34-21-1-161-806 Brake disk set screw 8x14mm (QTY 2) OEM from PelicanParts - $1 ea
Suspension
31-35-2-227-203 Sway bar end link (QTY 2) Lemforder from Pelicanparts - $20 ea
33-41-1-133-785 Nut for Wheel Bearing/Axle (27 X 1.5 mm) (QTY 4) Febi Bilstein from Pelicanparts - $5 ea
07 11 9 934 755 Snap ring for wheel bearing (QTY 4) BMW brand - $4 ea
33 32 6 772 698 Eccentric Bolt for Rear Control Arm, 12 X 1.5 X 81mm BMW brand - $7
-- in conjunction with 33-32-6-760-668 Self-locking collar nut, for Eccentric Bolt in Rear Control Arm (12 x 1.5 - 10 mm) - $1 or free with above
-- in conjunction with 33-32-1-094-653 Eccentric Washer - Control Arm (12 mm) - $5 or free with above
33 17 1 134 872 Differential Mount for Differential Cover BMW brand - $15
33 32 6 770 824 Inner Bushing on Rear Lower Control Arm (QTY 2) Lemforder brand - $10 ea
33 21 7 840 673 Axle boot kit for inner CV joint (QTY 2) GKN Lobro - $15 ea
33 21 9 067 806 Axle Boot Kit for Rear Axle Outer C/V Joint (QTY 2) GKN Lobro - $10 ea
33 32 6 775 551 Ball Joint for Trailing Arm (Trailing Arm to Control Arm) (QTY 2) Lemforder - $10 ea
33 41 1 090 505 Wheel bearing (rear) FAG brand repacked with redline CV-2 grease - $45 ea
Unopened 14oz jar of redline CV-2 synthetic high-performance extreme pressure grease w/ red moly - $10 ea
OEM parts :
E36 M3 Coupe side mirrors (black) + new blue glass drivers side (no browning). Pass side has ~1mm browning on inside edge. $150
Non-sagging glove box (grey) - $45
18 button OBC with full display working - $45
sunglasses cubby with cigarette lighter - $5
Two heated seat switches - $5
ASC switch - $5
Euro Alarm LED - $5
Headlight switch - $5
63 31 8 350 554 Hood light - $5
Window switches - $5 ea
OEM upgrades :
Central lock switch with connector and wire leads - $5
Rear side reading lights with independent on/off switch (QTY 2) - $10 ea
61-35-8-369-474 Wi-WA II + SRA wiper module (allows continuously variable wiper interval setting) - $50
51-16-8-131-737 Euro e36 auto-dim rear view mirror + connector plug + trim piece - $75
e46 trunk 12V electrical socket - $5
67 11 8 361 363 Z3 trunk lid actuator for remote open - $50
740iL door warning lights + connectors and wire leads (QTY 2) - $5 ea
740iL motorized headrest kit (motor, cable, bracket, wiring, and switch for seat) : $25
Aftermarket upgrades :
1995 e36 M3 Dinan engine ECU chip - $100
Sunroof eclipse one-touch open/close controller (requires ‘96+ switch/motor) - $40
Black steel M3 license plate frame - $15
Audio:
JL Audio Slash 300/4 (v1) amp (nearly identical to v2) - $250
ADS 345CS two-way component speakers (5.25" mids, tweeters, crossovers) - $150
JL audio StealthBoxes with 8" woofers (needs re-foam edge of speaker cone, I may do this since I was already planning to this year) - $250
Pioneer Premier DEH-P8600MP Headunit w/ all LEDS converted to amber - $100
Pioneer CD-BTB200 - Bluetooth Wireless Adapter for headunit - $50
Pioneer GEX-P920XM - XM Digital Satellite Tuner with lifetime XM subscription - $75
Take all three (headunit, bluetooth and XM for $200)
Suspension
TC Kline True Match single adjustable coilover suspension with 500# front / rear springs and Buna rubber rear shock mounts. Installed spring of 2013, used about 13k miles - $1500
Vorschlag camber plates. Installed spring 2013 used about 13k miles- $350
Rallyroad Motorsport reproduction strut tower reinforcement bar. Installed fall 2013 - $350
AKG RFSP36 Front subframe motor mount reinforcement - $30
Rogue engineering rear shock mount bushing set for normal/street (set of 4) - $5
Rogue engineering e36/e46 rear trailing arm shims (only 2) - $20
Status of camber plates? I sent a PM.
Four Car Garage Motorsports #4
Sold camber plates. Rest of suspension still for sale.
Pm'd
― George Orwell
I have a '94 325i convertible that i need the zippered rear window for. Do you have that by chance? If not, can anyone recommend where i might find a reasonably price one? Thanks!
Sorry, I didn't have a convertible. Not much left aside from the coilover suspension, the maintenance items, the Peake tools, the Stealthboxes, and some electronics.
Pmd
Sent from my Nexus 6P using Tapatalk
Cool. Replied!
You have rear bumper molding?
Current cars:
87' Zinnorot 325is
91' Alpine white 318is
92' E30 Alpine white Mtechnic
97' E36 Alpine white M3/2/5
