Mods - when you moved this thread you appended "upstate NY" to the title. This car is NOT in upstate NY, it is in Long Island NY, AKA DOWNSTATE NY
Hello fellow Bimmerheads,
As some of you might remember, my beloved and trusty 1995 e36 M3 coupe suffered a ‘total loss’ accident after being ran off the highway by a road-raged senior-citizen SUV driver. :o(
This is my for-sale thread, and I will be updating it with parts and prices. Please come back and look as I add more parts. I will accept paypal friends-and-family or paypal + 3% to cover fees. You are free to come pick up parts in Long Island NY, otherwise shipping will be at cost via buyer’s requested service. Pictures available upon request.
Those of you that know me and saw my car know the pride I had in ownership of it, and it was a sad day when I realized that it was time for us to part ways before I was ready to let go. It was a truly reliable car, and a wonderful love affair, and part of me died the day it crumpled into the trees to save my life. I had gone to great lengths to take excellent care of my car, performing tasteful modifications for style and function, upgrading parts as they wore out, and diligently doing most of the maintenance myself. I have decided to move on from the e36, thus I no longer need any of my BMW parts or service items. I have had a few weeks to pick apart the car, while it sat in the back parking lot at work. But the big-high mucky muck has started to get agitated seeing a pile of car scrap in the corner and has told me to get it out. So next week it will be towed off (God willing).
Picking off parts I went after items that were after-market add ons, or OEM parts that would ship easily and fetch decent returns. I’m sorry that I may not be able to fill part requests for odd items, what is listed here is what is available.
Regarding the headlights: Sadly I saw that many mounting tabs were damaged on both headlights. I was quite proud of my excellent handiwork on the Bosch Euro headlights with FX-R bi-xenon retrofit. If any of you wish to make an offer on them let me know. They also include the headlight range motors but not the headlight range wiring.
Items for sale:
Maintenance items :
Peake Research R5 / FCX-R2 Engine scan reset tool (1987-2000)+ manual. $100
Peake Research R5 / SRS Airbag scan reset tool (1994-2003) + manual. $100
Bentley Manual e36 BMW - $25
K&N 33-2990 drop-in filter for stock airbox - $25
Spare parts : (all parts new in packaging)
Engine
11-42-7-833-769 Mahle oil filter kit - $7
11-12-1-718-856 Valve Cover Stud - Cylinder Head to Valve Cover (7/6 X 29.5 mm) (QTY 4) - $5 ea or all for $10
Interior
64-11-9-069-895 Cabin air filter (QTY 2) Airmatic brand from PelicanParts - $10 ea
Exhaust (see listing below for Stromung exhaust)
18-11-1-723-720 Gasket Ring - Catalytic Converter to Rear Muffler (48mm) BMW from PelicanParts - $5
18-11-1-719-446 Gasket Ring - Catalytic Converter to Rear Muffler (48 mm) BMW from PelicanParts - $5
11-72-1-437-202 Copper Collar Nut - Exhaust Manifold to Cylinder Head (7 mm) (QTY 9) - $1 ea or all for $5
Brakes
34-32-2-227-381 Front left or right brake hose OEM/ATE from PelicanParts - $10
34-32-1-159-524 Rear left or right inner brake hose (QTY 2) OEM/ATE from PelicanParts - $5 ea
34-35-1-181-342 Brake pad sensor rear right PEX brand from PelicanParts - $5
34-21-1-161-806 Brake disk set screw 8x14mm (QTY 2) OEM from PelicanParts - $1 ea
Suspension
31-35-2-227-203 Sway bar end link (QTY 2) Lemforder from Pelicanparts - $20 ea
33-41-1-133-785 Nut for Wheel Bearing/Axle (27 X 1.5 mm) (QTY 4) Febi Bilstein from Pelicanparts - $5 ea
07 11 9 934 755 Snap ring for wheel bearing (QTY 4) BMW brand - $4 ea
33 32 6 772 698 Eccentric Bolt for Rear Control Arm, 12 X 1.5 X 81mm BMW brand - $7
-- in conjunction with 33-32-6-760-668 Self-locking collar nut, for Eccentric Bolt in Rear Control Arm (12 x 1.5 - 10 mm) - $1 or free with above
-- in conjunction with 33-32-1-094-653 Eccentric Washer - Control Arm (12 mm) - $5 or free with above
33 17 1 134 872 Differential Mount for Differential Cover BMW brand - $15
33 32 6 770 824 Inner Bushing on Rear Lower Control Arm (QTY 2) Lemforder brand - $10 ea
33 21 7 840 673 Axle boot kit for inner CV joint (QTY 2) GKN Lobro - $15 ea
33 21 9 067 806 Axle Boot Kit for Rear Axle Outer C/V Joint (QTY 2) GKN Lobro - $10 ea
33 32 6 775 551 Ball Joint for Trailing Arm (Trailing Arm to Control Arm) (QTY 2) Lemforder - $10 ea
33 41 1 090 505 Wheel bearing (rear) FAG brand repacked with redline CV-2 grease - $45 ea
Unopened 14oz jar of redline CV-2 synthetic high-performance extreme pressure grease w/ red moly - $10 ea
OEM parts :
Original zippered folio with owners manual + extras - $5
E36 M3 Coupe side mirrors (black) + new blue glass drivers side (no browning). Pass side has ~1mm browning on inside edge. $150
Non-sagging glove box (grey) - $45
18 button OBC with full display working - $45
sunglasses cubby with cigarette lighter - $5
Two heated seat switches - $5
ASC switch - $5
Euro Alarm LED - $5
61 35 8 359 031 Wi-Wa Low II wiper module - $10
Headlight switch - $5
63 31 8 350 554 Hood light - $5
Window switches - $5 ea
All 5 LTW M-Spoke Forged wheels (7.5 x 17 front, 8.5 x 17 rear, 7.5 x 17 spare). - $650
OEM upgrades :
Central lock switch with connector and wire leads - $5
Rear side reading lights with independent on/off switch (QTY 2) - $10 ea
61-35-8-369-474 Wi-WA II + SRA wiper module (allows continuously variable wiper interval setting) - $50
51-16-8-131-737 Euro e36 auto-dim rear view mirror + connector plug + trim piece - $75
e46 trunk 12V electrical socket - $5
67 11 8 361 363 Z3 trunk lid actuator for remote open - $50
740iL door warning lights + connectors and wire leads (QTY 2) - $5 ea
740iL motorized headrest kit (motor, cable, bracket, wiring, and switch for seat) : $25
Aftermarket upgrades :
Sunroof eclipse one-touch open/close controller (requires ‘96+ switch/motor) - $40
Homemade adjustable clutch stop – similar to “UUC big boy” clutch stop - $5
Black steel M3 license plate frame - $15
1995 e36 M3 Dinan engine ECU chip - $100
AKG RFSP36 Front subframe motor mount reinforcement - $30
Rogue engineering rear shock mount bushing set for normal/street (set of 4) - $5
Rogue engineering e36/e46 rear trailing arm shims (only 2) - $20
JL Audio Slash 300/4 (v1) amp (nearly identical to v2) - $250
ADS 345CS two-way component speakers (5.25" mids, tweeters, crossovers) - $150
JL audio StealthBoxes with 8" woofers (needs re-foam edge of speaker cone, I may do this since I was already planning to this year) - $250
Pioneer Premier DEH-P8600MP Headunit w/ all LEDS converted to amber - $100
Pioneer CD-BTB200 - Bluetooth Wireless Adapter for headunit - $50
Pioneer GEX-P920XM - XM Digital Satellite Tuner with lifetime XM subscription - $75
Take all three (headunit, bluetooth and XM for $200)
Major upgrades
Stromung exhaust with staggered tips Installed fall 2013 (see above for exhaust gaskets), used about 10K miles - $500 Pictures to follow soon
TC Kline True Match single adjustable coilover suspension with 500# front / rear springs and Buna rubber rear shock mounts. Installed spring of 2013, used about 13k miles - $1500 Pictures to follow soon
Vorschlag camber plates. Installed spring 2013 used about 13k miles- $350 Pictures to follow soon
Rallyroad Motorsport reproduction strut tower reinforcement bar. Installed fall 2013 - $350 Pictures to follow soon
1995 OBD I Cosmos Black M3 - RIP: gone but not forgotten
how much for the stromung exhaust?
Pictures of the glovebox? Highly interested and PayPal ready.
ImageUploadedByTapatalk1458522125.192435.jpgImageUploadedByTapatalk1458522143.398992.jpg
I added two USB charge ports inside, if you connect them to power.
Please check PM
Full interior reupholstery - Will NOT break apart, sold as a lot because many pieces match other pieces. Pictures to follow soon with price
Custom fabric combination (e30 M-Technich II fabric w/ genuine Alcantara) by professional upholstery shop
- e36 Vader seats with 9002 Alcantara / M-Tech reproduction fabric / double red stitching
- Genuine BMW e92 Carbon fiber seat heaters for seat, back, side bolsters wired for e36 seat heater harness. Works better than stock; faster and hotter.
- Rear bench seat with 9002 Alcantara / M-Tech reproduction fabric / double red stitching
- Rear side bolsters with 9002 Alcantara / double red stitching (no rear headrests)
- Arm rest with 9002 Alcantara / double red stitching
- Shift gaiter with 9002 Alcantara / double red stitching
- E-brake boot with 9002 Alcantara / double red stitching
- Custom front door cards with re-moulded arm rest shape, padded arm rest, e39 lighted chrome door pull, 9002 Alcantara / M-Tech reproduction fabric / double red stitching, e38 door warning lights, e38 door puddle lights
- Rear side cards with padded arm rests, 9002 Alcantara / M-Tech reproduction fabric / double red stitching
OPTIONAL :
- ZHP weighted shift knob converted with OEM lighted shift knob insert
- Nearly new OEM black M3 Carpet mats
Cluster?
Eat, drink, and be merry - for tomorrow we drive.
door panel pics??? sound awesome.
Sorry for the accident
How much for the lighted zhp
Any pics of the head unit lit up? I'm interested in a few other parts either way.
@M3AMI
96 BG/Magma Lux
Mods. Lots of Mods.
Sent PM a few days ago about the shift knob and stealthboxes. Please lmk.
Stealth boxes and shift knob are available. Let me snap some photos later
Pm sent about some door and window seals.
Pm sent about interior
Interested in driver body/door seal and possible exhaust
Smith
interested in the gray glove box if it will fit a convertible.
Thanks everyone for interest. I'll be posting several pics later today of items.
Happy Easter!
I need the rear bumper diffuser, let me know via PM if that's available. Thank you.
instagram @andyitslit
Does the AC blow cold? I need all bolts, hoses, compressor, dryer, condenser. Everything from the firewall to the front of the car. Email me a price if it all works shipped to 60544. crcragg at gmail
Sent from my SM-T707V using Tapatalk
PM Sent
Hi, do you have the M3 cams? If yes, pls PM price. We can seal deal quickly as I need the cams soon. Thanks.
Is the front pass fender avail, condition and pricing. And are you anywhere near Utica? Thank you
Shift knob and sound system still available?
sent a pm on cat back and folio.
'But Dad.... it's PURPLE!'
