Page 8 of 22 FirstFirst 123456789101112131415161718 ... LastLast
Results 176 to 200 of 528
Thread: Just another boring LS swap into an E36 M3
  1. #176
    Jul 2013
    FL Gulf Coast
    E36 - 1998 328iS - LS2
    Quote Originally Posted by squashman702 View Post
    You have the ramps to extend your garage, right? Can't say I'm jealous haha.
    Yep. Gotta make do with what I have. The trade-off is a canal and boat out back. But the next place won't be on the water and will be all about the garage. Eventually.
    Tipsy
  2. #177
    Sep 2015
    Stow, MA
    1997 328i
    Ran the last brake line I can with the motor still in place. I think I'm ready to pull it back out. Did anyone have to clearance their trans tunnel at all for the T56? I enlarged the shifter hole, but can't seem to find anywhere else that may be a clearance issue- is there something I'm missing? I still need to pull some of the heat blanket to be sure.
    Clearance from above:
  3. #178
    Sep 2015
    Stow, MA
    1997 328i
    Motor and T56 are back out. Didn't have to pull the ABS pump, which was nice. I think I had it all out in less than an hour working by myself. Plenty of space to run the heater lines, delete the SAP tray and other miscellaneous brackets, and bend and flare the final brake line to the passenger side front. Pulling the A/C lines as well for the time being.
  4. #179
    Sep 2015
    Stow, MA
    1997 328i
    Bent the last brake line to the passenger side front, then pulled everything but the front driver's side line out. Pulled the A/C lines as well, and started to remove the brackets for the cruise control, ASC, and ABS pump, as well as the washer fluid tank. Took a couple pictures, but this is the only one that came out decent. Found some rot under the cruise control mounts, so I cut out the areas and will have to weld in some patches.
  5. #180
    Sep 2015
    Stow, MA
    1997 328i
    Spent a good chunk of the day in the shop today. I don't like welding sheet metal.
    Got the contour pretty close to the lower patch. Messed around with some body hammers and a dolly we have at the shop.
    Tack tack, then get mad when it burned through. This was .025 wire, and the Miller 211 I have set to 1.5/35.
    Going to smear some bondo over this. I have no future as a body guy.
    Brackets shaved on the passenger side, luckily no extra work needed there.
    Remnants of the ABS pump brackets are gone. Traction control bracket gone. Whatever other bracket that was on the strut tower is gone too.
    Skip shift delete is free when you have a welder. Stole this from Tipsy's thread on here. Cut the solenoid in half, pulled out the guts, pulled the plunger forward and burned it home, then cut the extended part off the inside.
    Thinking I'll bolt the heater control valve here- any reason this can't be mounted upside down?
  6. #181
    Jul 2013
    FL Gulf Coast
    That Millermatic is autoset, no? I've been wanting to teach myself to weld for some time. I'd read that the autoset feature makes things a lot easier. But I've never laid a single bead of weld, so I have no basis for comparison.
    Nothing here is Stolen. It's all shared. I would never have attempted this swap pre-internet. The sharing of information is a game changer.
    Good question. I'm thinking about mounting the heater valve in the same location, though I hadn't considered mounting it upside down. Seems like a good place to keep it out of the way. But the engine will probably have to be pulled to access it in the future. Everything is a compromise.
    Got a better picture of the bracket that you fabbed?
    Tipsy
  7. #182
    OKC,OK
    several
    Mine is mounted on the top side of that battery/tray whatchamacallit. Just because of the electronics of it, and possible servicing requirements; I'd recommend mounting in an easier to access area. But it's nothing but actuator valves that open and close though.
    1998 M3 Sedan - LS3 M12T56 - A bad addiction.
  8. #183
    Sep 2015
    Stow, MA
    1997 328i
    Quote Originally Posted by TipsyMcStagger View Post
    Tipsy
    Autoset doesn't really do much beyond saving you from opening the door of the welder to figure out settings, from what I've done with it so far. Practice is far more important. I started on a Miller 135, which is a great machine for most automotive stuff, and can be had used for a few hundred bucks. Miller is releasing/has released a new line of machines that are lighter, which means that a lot of the older models like the 211 can probably be had cheaper. I went with the 211 because of the ability to plug in to 115/230v by switching plugs, plus you can hook up a spoolgun and weld aluminum. I give you props for jumping into this without a welder. It's been a lifesaver in a lot of situations for a variety of reasons, plus being able to stick together whatever I want is cool.
    You're right- I've figured way more of this swap out just by reading.
    I can grab some more pictures of the bracket I made on Tuesday.
    Quote Originally Posted by OKsweetrides View Post
    I made it and picked the location and instantly wanted to throw the motor back in to check clearances around it for the hoses, but I'm thinking I'll leave it where it is as long as I can get the plug to work where it's at. The one issue I can see is running the heater hoses down under the tray may not create ideal angles and placement.
  9. #184
    Sep 2015
    Stow, MA
    1997 328i
    Lokar throttle cable is in. Managed to lose one of the clips on the interior though, it went flying off when I was trying to install, so I'll need to replace that.
    Ground off the rest of the welds for the ABS pump bracket.
    Burned in the base for my new ABS bracket.
    Started on a throttle cable bracket.
  10. #185
    Apr 2015
    1995 e36 sedan
    Why not just use an oem one or an aftermarket one?
    Sent from my SM-N930T using Tapatalk
    Ls2 e36 sedan
  11. #186
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    Quote Originally Posted by Jaxchrisfla View Post
    assuming you mean the throttle bracket, i'm gonna bet it's for 3 reasons.
    1. DIY is always better than store bought for a build.
    2. he can.
    3. that damned Lokar bracket is ~$50 and doesn't come in black for a single. at least not that i found.
    always trying to make it lighter and faster
    ^^former build: http://www.bimmerforums.com/forum/sh...-neglected-M3/
    current build: http://forums.pelicanparts.com/porsc...car-build.html
    instant grams: doktor_b
  12. #187
    Sep 2015
    Stow, MA
    1997 328i
    Doktor B nailed it.
    Quote Originally Posted by doktor b View Post
    2. he can.
    I had the steel laying around, and the LS6 intake didn't come with a bracket. The bracket is stupid expensive for what it is, and I can use the $50 somewhere else, like on the stud conversion I bought at the BavAuto show on Sunday.
    I really do like fabbing stuff up, I'll take any excuse I can get to turn on the welder. Keep in mind that bracket is definitely not finished either.
  13. #188
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    i keep forgetting that i can actually build things like this from scratch. i have a welder (that i barely use), a square, and bench and angle grinders. don't really need anything else. just have to remember.
    kinda wishing i had the $50 from that bracket back lol.
  14. #189
    Sep 2015
    Stow, MA
    1997 328i
    Do it. More fab=more gooder.
  15. #190
    Sep 2015
    Stow, MA
    1997 328i
    Finished up the fab on the throttle cable bracket. Added some extra welds, but had some porosity in them due to not cleaning out my cutting oil fully. Should be mostly hidden by paint.
  16. #191
    Sep 2015
    Stow, MA
    1997 328i
    Motor went back in yesterday.
    Needed to check clearances for heater hoses and trans tunnel.
    Primed and undercoated the back side of the patch panels.
    Motor back out. This is time #2 in and out, my shop mate is convinced I'll have it out at least 5 times before the swap is done.
    Trans tunnel after hammer time.
  17. #192
    Oct 2008
    Columbia, MD
    96 M3 TT LSx
    You can mount the heater valve in any orientation. We mounted it facing upwards on my friends 2JZ swap, no issues.
    96 M3 | Forged LSx | Twin S366 | Injector Dynamics | E85 | AEM Infinity
    90 Schwarz 325i
    IG : sdobart
  18. #193
    Apr 2015
    1995 e36 sedan
    Most move the valve to the battery tray area for clearance purposes.
    Ls2 e36 sedan
  19. #194
    Sep 2015
    Stow, MA
    1997 328i
    Ended up moving the valve to the SAP tray, had to run it on top because I was worried about heater lines running too close to the passenger side header. Some pictures.
    This sort of shows the bracket I made for the valve.
    Harness extended, plug basically crumbled apart, so I'll need to get a new one.
  20. #195
    Sep 2015
    Stow, MA
    1997 328i
    Goofed off most of the day yesterday, and had to work today, so I didn't get much done. Did get the trans tunnel and gas tank covered with DEI stick on heat shield, however. Had some help from my girlfriend, it was nice to get her out into the shop and she actually enjoyed it.
    Looking up at the tunnel.
    Shiny AF.
    Slave/throwout bearing came in from Rockauto today. It's a Luk LSC265B, marked "AP" same as the OEM. It was $3x.xx, so that was a big savings over a Delco piece. Clutch line came in as well, and I should have the remaining fittings to adapt to the slave and to the BMW hard line in the next couple of days. Haven't really seen many people adapt a custom line, and it may be a fairly low cost option once it's all said and done.
  21. #196
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    that's a lot less than i paid for my TOB from Tick. and i felt like i got a solid deal. looks just the same...including the red rubber sock/boot/doohickey.
  22. #197
    Sep 2015
    Stow, MA
    1997 328i
    Autozone was supposedly selling the same thing, but I struck out when I went there. It wasn't marked "AP" and it cost somewhere close to $70 as well, so it got returned. Did some googling after that happened upon an LS1tech post that mentioned LUK was the same, so I gave it a shot.
  23. #198
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    we use tons of LUK clutches and clutch components at work. i wouldn't shy away from their products at all.
  24. #199
    Sep 2015
    Stow, MA
    1997 328i
    I've seen their stuff everywhere, not sure if it was a LUK or Sachs clutch I put in my old Grand Cherokee, but I know they're a trusted name. On a side note, I miss that Jeep. 250k plus on it when I got rid of it. Next to my buddy's 1994 factory 5 speed. 2 of 400 built for 1994; some of the more rare Mopars that few care about.
  25. #200
    Mar 2013
    Lloydminster, Canada
    1992 BMW 325i
    Is this where most power distribution blocks are mounted? Mine is in a slightly different spot, basically about an inch or two to the right of your heater valve position.
  1. ANyone do a LS swap into an OBDII e36? EWS question
    By m3j0n in forum Engine Conversions
    Last Post: 09-24-2014, 08:04 PM
  2. M62 swap into an e36?
    By alpine318is in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 11-25-2009, 06:58 PM
  3. Let's say you're swapping an LS1 into an e36 M3......
    By giantrobot9000 in forum Engine Conversions
    Last Post: 04-21-2009, 09:38 PM
  4. M3 E46 Motor swap into an Euro M3 E36 EVO.
    By M3MotorsportITA in forum 1994 - 1999 Euro M3 (E36)
    Last Post: 11-06-2008, 02:30 PM
  5. 83 633csi drivetrain/motor swap into an E36
    By bilstein325i in forum 1991 - 1999 (E36)
    Last Post: 01-29-2007, 07:03 PM
