Page 6 of 22 FirstFirst 12345678910111213141516 ... LastLast
Results 126 to 150 of 528
Thread: Just another boring LS swap into an E36 M3
  1. #126
    OKC,OK
    several
    Youve inspired me to go back and tweak some things. I broke a boss off on the T56 extension housing for the passenger side bolt (cracked all through, so now only held by 1 bolt), so now to redo the crossmember to accept a GM OEM style bushing.
    I appreciate your pics! Your progress is great!
    If you dont find the wire, I can pull my steering wheel an browse the e36 bible to see what it is.
    1998 M3 Sedan - LS3 M12T56 - A bad addiction.
  2. #127
    Sep 2015
    Stow, MA
    1997 328i
    Quote Originally Posted by OKsweetrides View Post
    Youve inspired me to go back and tweak some things. I broke a boss off on the T56 extension housing for the passenger side bolt (cracked all through, so now only held by 1 bolt), so now to redo the crossmember to accept a GM OEM style bushing. I appreciate your pics! Your progress is great!
    Thanks, some days I feel like I haven't accomplished anything on this, but it's good to hear that other people think I'm making progress. Going to keep pushing.
  3. #128
    Sep 2015
    Stow, MA
    1997 328i
    Passenger side header is in, ABS is pulled, and brackets are cut out so I can rework them into a new mount. The remaining pieces of bracket will be addressed once the motor comes back out.
    Ordered 25' of copper brake line, a bubble flaring tool, and a bunch of unions and other fittings to make this all happen. Does anyone have a suggestion for a heat shield/ sleeve to use to run the brake lines along the strut tower?
  4. #129
    Mar 2004
    USA
    96 328is 6.0L
    You should be fine without the shield. If you really want it, you could splice a small diameter fuel hose and put it over the lines.
  5. #130
    Sep 2015
    Stow, MA
    1997 328i
    That would be a huge help. The wheel is locked upside down and I'm not sure if the wires that are on that plug somehow play into it. Haven't seen them mentioned in other 3 spoke swaps.
    Quote Originally Posted by bimerok View Post
    Good to know, thanks.
  6. #131
    Sep 2015
    Stow, MA
    1997 328i
    Spent most of the afternoon helping out my buddy with his '49 F1, did start on extending the ABS harness, however. Made it long enough so I can run it through the fender.
    And the F1 with the M3 lurking in the back, he's dropping it on a Crown Vic front end and Lincoln Mark VIII rear so that it can lay frame.
  7. #132
    Mar 2004
    USA
    96 328is 6.0L
    I would advise to solder, don't use crimp connectors.
  8. #133
    Oct 2008
    Columbia, MD
    96 M3 TT LSx
    Looks like he is using Raychem/Duraseal splices, which are far better than solder for automotive applications when properly crimped.
    PS. Kind of upset there are no pics of that wood fired brick oven pizza
    96 M3 | Forged LSx | Twin S366 | Injector Dynamics | E85 | AEM Infinity
    90 Schwarz 325i
    IG : sdobart
  9. #134
    Sep 2015
    Stow, MA
    1997 328i
    Quote Originally Posted by sdobart View Post
    The za was delicious.
    Wired up a Sony head unit I had kicking around tonight, need an antenna cable still apparently. Helped my friend flush/bleed the brakes in his E46 M3 after.
  10. #135
    Sep 2015
    Stow, MA
    1997 328i
    ABS bracket is done minus paint and figuring out where I'm going to mount it. Dimple dies because racecar. Sloppy work because it's me.
  11. #136
    Sep 2015
    Stow, MA
    1997 328i
    Made a quick trip to the shop tonight.
    Passenger door panel in, speakers hooked up.
    Sony headunit installed, had to finish the harness, and add in the antenna wire, as well as pull the old bezel off of it from when it was in one of my 5.9 Grand Cherokee's.
    Water pump bolts were nasty, stuck those in the sand blaster to clean them up. Big difference.
    Water pump in and torqued. Need new bolts for the thermostat housing, so that's not installed yet.
    And my list of stuff left to buy. Long list, but it's everything I can think of that I'm missing at this point.
  12. #137
    Oct 2008
    Columbia, MD
    96 M3 TT LSx
    Just an FYI with those bolts. They're nickel coated so they don't rust. When you blast them or wire wheel them, that nickel coating is removed. Initially they look way better, but after a few months they end up rusting and turning completely orange. I just had to replace all mine hah - first hand experience doing the same thing.
    90 Schwarz 325i
    IG : sdobart
  13. #138
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    http://www.eastwood.com/ew-electropl...-tin-zinc.html
    yeah they will be pretty rusty soon, eastwood has a kit.
  14. #139
    Sep 2015
    Stow, MA
    1997 328i
    Good to know, figured it was better than putting them back as is.
    Quote Originally Posted by fallguy View Post
    More tools are always good.
  15. #140
    Sep 2015
    Stow, MA
    1997 328i
    Plug wires, remaining heater hose, belt and a used coil pack all ordered.
  16. #141
    Sep 2015
    Stow, MA
    1997 328i
    JTR diff flange purchased from another member on here.
  17. #142
    Sep 2015
    Stow, MA
    1997 328i
    Was out of town all week for work, finally got to spend some time at the shop today. Got the brake lines cut and the driver side header fitted. Crossmember is reinstalled, and the motor is sitting on its own weight.
    Not super happy with where the headers end up. The passenger side seems reasonable, but the driver's side dumps out basically right where the fuel filter/regulator normally is. Looks like I'd need to move the filter and move the line to the line outside of the rail, which presents an obvious safety issue. I'll grab some pictures and see if I can't figure out what NAHR did on their build.
  18. #143
    Sep 2015
    Stow, MA
    1997 328i
    Installed the missing coil pack and the thermostat/housing. Did some general clean up as well, under the car was a mess, as was the engine bay.
    Next issue as I mentioned is the headers. I'm really not fond of how the driver's side header fits. This is with everything bolted in, there's no weight on the jack in these pictures.
    Looking down the driver's side frame rail. Header points exactly where the regulator/filter needs to go.
    Passenger header, seems to be way more tucked up and placed with the outlet in a better spot.
  19. #144
    Apr 2015
    1995 e36 sedan
    I think I remember seeing people move the lines and regulator to the passenger side because of this.
    Sent from my LG-H901 using Tapatalk
    Ls2 e36 sedan
  20. #145
    Oct 2007
    sterling hts, michigan
    02 M3
    You shouldn't have to move the fuel filter/regulator. Mine is all in the OEM location. The headers I received from CX were actually too much into the interior of the car than exterior like yours, I'd ring them up and explain the extremely poor fitment.
  21. #146
    Apr 2015
    1995 e36 sedan
    He's running cxracing headers on new age hot rod mounts?
    Ls2 e36 sedan
  22. #147
    Sep 2015
    Stow, MA
    1997 328i
    They're New Age mounts and New Age headers.
  23. #148
    Sep 2015
    Stow, MA
    1997 328i
    Didn't make much progress today. Kind of at a standstill with some stuff until I decide what I'm going to do with headers/mounts. Ended up getting all the hoses I need for the heater valve relocate, but I'm going to delete the tray for the SAP, so I didn't mount the bracket I made yet. Not trying to get into deleting anything until I can pull the motor out again. Still haven't heard back from NAHR about the headers, probably will call them if I don't hear back tomorrow.
  24. #149
    Nov 2015
    Carlos MN
    99 E36
    Bummer to mod a purchase part but maybe an angle cut to the collector to point it away from the fuel filter?
    I've found all the work on hot rods only using a floor jacks and jack stands is really good for the shoulder muscles.
    My home built swap headers are not close to the stock fuel filter location.
  25. #150
    Sep 2015
    Stow, MA
    1997 328i
    Quote Originally Posted by 99E36LS1 View Post
    I'd cut it so that it worked, but I still have the issue of how low the header sits versus the passenger side, which I'm not pleased about either. That would add a lot more work.
    I feel you on working on my back- never had a lift in all of my years of working on cars/Jeeps.
  1. ANyone do a LS swap into an OBDII e36? EWS question
    By m3j0n in forum Engine Conversions
    Last Post: 09-24-2014, 08:04 PM
  2. M62 swap into an e36?
    By alpine318is in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 11-25-2009, 06:58 PM
  3. Let's say you're swapping an LS1 into an e36 M3......
    By giantrobot9000 in forum Engine Conversions
    Last Post: 04-21-2009, 09:38 PM
  4. M3 E46 Motor swap into an Euro M3 E36 EVO.
    By M3MotorsportITA in forum 1994 - 1999 Euro M3 (E36)
    Last Post: 11-06-2008, 02:30 PM
  5. 83 633csi drivetrain/motor swap into an E36
    By bilstein325i in forum 1991 - 1999 (E36)
    Last Post: 01-29-2007, 07:03 PM
