Page 13 of 22 FirstFirst ... 345678910111213141516171819202122 LastLast
Results 301 to 325 of 528
Thread: Just another boring LS swap into an E36 M3
  1. #301
    Sep 2015
    Stow, MA
    1997 328i
    Quote Originally Posted by doktor b View Post
    looks so good!
    Thanks man, fairly happy with how it turned out. I'll probably dimple die the flat pieces on the side to maximize racecar.
    Instergrams: @davemakepictar
  2. #302
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    Quote Originally Posted by squashman702 View Post
    oh you real fancy. i just have a step drill. no dimple dies over here.
    always trying to make it lighter and faster
    ^^former build: http://www.bimmerforums.com/forum/sh...-neglected-M3/
    current build: http://forums.pelicanparts.com/porsc...car-build.html
    instant grams: doktor_b
  3. #303
    Sep 2015
    Stow, MA
    1997 328i
    Yeah, they make the piece crazy rigid. My buddy bought a full set for his '49 Ford F1 build (he has the other half of the shop), so that has worked out well for me so far. I think I've used them more than he has.
    Here's his build for anyone interested:
    http://www.stanceworks.com/forums/sh...ad.php?t=93274
  4. #304
    Jul 2013
    FL Gulf Coast
    E36 - 1998 328iS - LS2
    Great, another project for me to read about that was done in an awesome shop, with lots of space and amazing tools by people who know what they hell they're doing :
    Tipsy
  5. #305
    Sep 2015
    Stow, MA
    1997 328i
    Quote Originally Posted by TipsyMcStagger View Post
    Tipsy
    Haha, I'll be the first to say that I am far from an expert in this stuff.
    Shop is smaller than it looks- we're working with about 900 square feet, and we like to leave the end with the door open so we can pull DD's in and out for more routine stuff. We were working out of a barn that was far from weather tight on my buddy's farm before, which was a decent space, but had about half of the square footage, no heat, and poor lighting, so this is a big change for us. The tool collections are about 10 years in the making; and we've kind of planned who buys what in terms of the bigger purchases. Stand up drill press is next, and I'd like a bender as well.
  6. #306
    Sep 2015
    Stow, MA
    1997 328i
    Nutsert plates are welded in. Multiple tacks instead of running a bead to keep the heat down.
    Radiator on the rubber hose mounts, radiator support mocked up.
    Power steering pressure line is in. Wrapped to protect it from rubbing on the alternator. Had to wait for a 45 degree fitting coming off the rack because I had my friend position the lower fitting clocked in the wrong direction. Whoops.
    Started to get the power steering cooler into position as well.
  7. #307
    Sep 2015
    Stow, MA
    1997 328i
    Finished up my power steering cooler lines. Added dimples to one of the vertical sides of the radiator support. My measuring skills bring the suck, hence the off centered holes.
    Ran out of time to do the other side tonight; this also stopped progress:
    That's one of the bottom plates for the press. Split in half (in quite the dramatic fashion) pressing the second dimple die in. It's a 20T Harbor Freight press that's a couple of years old. I got lucky I didn't get hit with anything, especially because I wasn't wearing safety glasses or any other PPE (I almost always do), and I'm lucky nothing hit my buddy Pat who I share the shop with, who was working about 15 feet away. Obviously a failure like this can't be predicted, so always be on your A game.
  8. #308
    Mar 2004
    USA
    96 328is 6.0L
    ... Obviously a failure like this can't be predicted, so always be on your A game.
    It can when you are using Harbor Freight stuff... The C-Clamp style bushing removal tool that they make also puts up quite an explosion show.
  9. #309
    Sep 2015
    Stow, MA
    1997 328i
    Quote Originally Posted by bimerok View Post
    Not the part of the press that I expected to fail, but yes, normally I don't have a ton of faith in their stuff.
  10. #310
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    we have the same HF 20T press and same junky plates in our shop at work. they've both worked flawlessly for over 8 years.
    i never invest tons of faith in HF anything. but sometimes they get it right.
    (we won't discuss my 10+ year old HF 1/2" impact that is still going strong and used nearly every day.)
  11. #311
    Sep 2015
    Stow, MA
    1997 328i
    Tonight, exciting things. Rear sway bar is in with new endlinks, hardware, and bushings. I consider this an accomplishment seeing as it hasn't had a rear sway installed since I've owned it.
    D/S front corner all reassembled.
    TRE's and ball joints tight, LCA tightened at the rear.
    Shifter cover and radiator support mostly painted.
    And my to-do list. Bad because it's long, good because this was literally everything that I can think of that I have left to do.
  12. #312
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    kicking ass and taking names!
    you're gonna be done way before me at this rate.
    (i went to PRI today instead of working on my car.)
  13. #313
    Sep 2015
    Stow, MA
    1997 328i
    Trying to make progress. The list is intimidating, but it feels good to cross stuff off.
    First project of the day: getting the trans tunnel cover done. Made a couple of stops on the way to the shop to try and find supplies. Ended up getting some weather stripping from Advance, a Mr. Gasket universal boot, and some leftover foam from mounting a truck cap. Also lined the bottom with some more reflective tape that I had.
    Installed in the car, seems to seal pretty decently. Used some self tappers on both ends.
    Front half of the console installed, gauge panel mocked up.
    Back half installed. Installed the glove box as well.
    Front clip most of the way back on. Radiator support isn't in yet, sprayed a couple more coats of paint on that today. I need another ZKW to match the junkyard driver's side light. Ordered some rubber isolators to make my top mounts and the euro radiator cover as well. Once those are in, I'll make the top mounts. Also ordered a replacement inner fender for the passenger side because mine was trashed.
    Found out I had a spare X20 plug, so I swapped everything over on the ABS wiring as well, so now it can actually connect.
  14. #314
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    how is that tunnel cover fixed to the tunnel? is it just sitting on top?
  15. #315
    Sep 2015
    Stow, MA
    1997 328i
    Self tappers at the front and the rear.
  16. #316
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    word.
    this is on my list for either tomorrow or this coming week one evening.
  17. #317
    Sep 2015
    Stow, MA
    1997 328i
    word.
    The weatherstripping seemed to work well, I ended up with a really sloppy cut because I was using shears instead of a power tool, didn't want to throw sparks everywhere inside after I installed the interior.
  18. #318
    Mar 2004
    USA
    96 328is 6.0L
    The only thing with these boots is that they are good for about year or one and a half years and then the rubber just disentegrates.
  19. #319
    Sep 2015
    Stow, MA
    1997 328i
    Good to know, I'll definitely keep an eye on it once the car is up and running.
  20. #320
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    Dave,
    it just occurred to me that the fuse blocks i bought for my harness aren't weather proof.
    are you mounting your PCM in the DME location and then putting the fuses/relays in sealed boxes on the battery tray? or are you putting everything inside something?
    i originally thought to put the PCM in the DME location, then just run the fuses/relays inside the car, but then i thought about how awful that would be to pull back out if i needed to pull the motor. (without just unplugging every single sensor)
  21. #321
    Sep 2015
    Stow, MA
    1997 328i
    Dave,
    Not sure yet. My fuel pump relay is trunk mounted. Getting into the wiring this week, so once I get a better idea of what needs to go where, I'll let you know.
  22. #322
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    awesome.
    thanks!
  23. #323
    Sep 2015
    Stow, MA
    1997 328i
    My buddy and I started on the harness today. So far, we purged a bunch of the junk. Wiring is not my forte, so I'm going to have a bunch of questions.
    It's a 1999 C5 harness from a T56 car, converting to truck MAF, and DBC, running a PCM I got out of a Silverado in the junkyard with the red/blue harness.
    Here's what we eliminated so far, let me know if you see issues.
    Blue connector:
    Pin 14: Throttle actuator control serial data
    Pin 15: Throttle actuator control serial data
    Pin 17: Transmission range signal B
    Pin 18: Transmission range signal C
    Pin 25: O2 sensor low bank 2 sensor 2
    Pin 28: O2 sensor low bank 1 sensor 2
    Pin 32: PRND A input signal
    Pin 33: TCC brake switch
    Pin 34: PRND P input signal
    Pin 38: Powertrain induced chassis pitch signal
    Pin 53: Transmission temp sensor ground
    Pin 62: Extended travel brake switch signal
    Pin 65: O2 signal high bank 2 sensor 2
    Pin 68: O2 signal high bank 1 sensor 2
    Pin 72: PRND B input signal
    Pin 79: 2nd and 3rd gear block out solenoid
    Red connector:
    Pin 2: TCC control solenoid
    Pin 4: AIR solenoid relay control
    Pin 6: Trans fluid pressure control solenoid low
    Pin 8: Trans fluid pressure control solenoid low
    Pin 9: Fuel pump relay control
    Pin 36: Air pump relay control
    Pin 42: TCC enable circuit
    Pin 44: Reverse inhibit solenoid control
    Pin 47: 1 to 4 upshift lamp
    Pin 48: Transmission shift solenoid A
    Pin 50: Vehicle speed output circuit
    Pin 51: Trans temp sensor signal
    Pin 54: Fuel level sensor signal
    Pin 62: PRND C input signal
    Pin 63: Transmission range signal A
    Pin 73: Fuel level sensor signal
    Need to do some research on the fan setup, my buddy is thinking it will be much simpler to run the fan off an external controller versus involving the PCM. Any downside to this?
    Also, I assume I want to keep the knock sensors?
  24. #324
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    looks good to me.
    absolutely keep the knock sensors.
    are you guys removing circuits from the harness like i've done so far?
    or are you completely undoing the whole harness from the red/blue and then re-routing/wrapping and re-pinning the red/blue?
  25. #325
    Sep 2015
    Stow, MA
    1997 328i
    looks good to me.
    I was 99% sure the knock sensors needed to stay.
    I stripped all the loom/tape/etc, zip tied at the junctions, and we are removing wires entirely from connectors at both ends.
  1. ANyone do a LS swap into an OBDII e36? EWS question
    By m3j0n in forum Engine Conversions
    Last Post: 09-24-2014, 08:04 PM
  2. M62 swap into an e36?
    By alpine318is in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 11-25-2009, 06:58 PM
  3. Let's say you're swapping an LS1 into an e36 M3......
    By giantrobot9000 in forum Engine Conversions
    Last Post: 04-21-2009, 09:38 PM
  4. M3 E46 Motor swap into an Euro M3 E36 EVO.
    By M3MotorsportITA in forum 1994 - 1999 Euro M3 (E36)
    Last Post: 11-06-2008, 02:30 PM
  5. 83 633csi drivetrain/motor swap into an E36
    By bilstein325i in forum 1991 - 1999 (E36)
    Last Post: 01-29-2007, 07:03 PM
