Hello, I am trying to update my transmission software by WinKFP with V57 daten. When I select update ZUSB/ECU family, I do not know which is ECU is for transmission. Anybody can tell me? Thank you.
I check the INPA > Transmission, there are 3 options, the first is Gearbox, automatic GS19, 2nd: Sequential SSG, 3rd: DXC, VGSG. Which one should I selete? My car is 2006 BMW 325xi. I select GS19, it says version does not match.
My UIF is below, but I did not see any match on WinKFP2.jpg. I also have another question here. I saw some post said I should enter ZUSB first, but some post said just click update ZUSB, which is correct? I install the BMW tool 2.12 and set up the BMW coding Tool as the instruction. In there, I did select the SP daten. Should I set in WinKFP again or not? Should I use BMW coding tool to update the transmission or WinKFP? I am so confused now.
Before I saw your reply, I tried the GKE233, update in WinKFP. It showed ECU>ZBNr from UIF XXXXXX to 7572903. After update, there are Brake, ABS, 4X4 lights on. Then I saw your reply, I tried the GKE211, the same information, Brake, ABS, 4X4 lights on off, then light again. Drive the car outside for few minutes, the transmission jerk from 2nd to 1st gear still exists. So sad. And how do you know my transmission is GKE211? I go to the EC-APP>NFS>DATA>GKE211 I found A7564083, the next is 7564087, there is no 7564084
Your original ZUSB was 7564084. That is compatible with EGS P/N 7563275. If you search for 7563275 in the SP Daten E89\daten\gdaten\HWNR.DA2 file, you'll see that it's in ECU family GKE211:
You can display the part numbers of all installed modules (and lots of other useful information) with INPA...E90 -> Select E90 -> Functional Jobs -> <F2> Identification:Code:7563275,0000000,0000000,GKE211
Alpina B3 Flash/BMS OCC/ER CP/ETS 5/HKS BOV/M3 Control Arms
Thank you for your helpful reply. Does it matter I update the GKE 233 first then the GKE 211? The transmission jerk problem still exists after 10 minutes drive. At the very beginning, there is no jerk. Any solution? I saw someone update the VGSG to solve this problem. I am not sure it is correct or not.
No, what matters is the new ZB number. Read the UIF with INPA. What is the EGS ZB number?
You should also reset the GS19 adaptations and perform the drive cycle if you updated the EGS with WinKFP.
This ZF doc explains the drive cycle procedure:
http://www.natef.org/NATEF/media/NAT...sion-6-8HP.pdf
I'm not sure about the VGSG, you can calibrate it with INPA. Good luck.
The EGS ZB no. is 7564084.
The manual is very useful. The drive cycle seems complex.
I did not know, as you said, Your original ZUSB was 7564084. That is compatible with EGS P/N 7563275. If you search for 7563275 in the SP Daten E89\daten\gdaten\HWNR.DA2 file, you'll see that it's in ECU family GKE211:
So I flashed the GKE211 with WinKFP, and its version has been changed, but the problem still exists and cause the ABS, brake and 4X4 lights on now. I am not sure it is because the ZBno. 7564084 does not exists in the list or not. Should I add the ZB no. to the list?
I'm not sure what your trying to say... Error codes and lights after flashing is normal. Just clear the error codes, lock the doors, and let the car sleep for at least 5 minutes.
You have SP Daten 57.x, it will not have ZB number 7564084; that ZB is from an older SP Daten.
Sp Daten 57.x does include ZB 7572903.
Sorry for the confusion. I used INPA to clear all the errors, but the ABS,BRAKE, 4X4 lights still on. How to clear these codes?
And I also checked the Errors, I saw there are errors for EGS, DSC, VGSG. They are the only three ECU I updated in WinKFP. Does not the V57 fit the 2006 BMW 325XI?
I have driven over around 100 miles now in the past few days and the lights are still on. I have tried in INPA but did not work. Could you tell me how to the procedure? INPA>Transmission>... ? Or INPA> Engine>...? Thank you.
I thought that you just flashed the transmission, but I noticed in another thread on e90post where you stated that you flashed DSC and VGSG as well:
That's why the lights are still on. DSC and VGSG likely require calibration and/or coding.Originally Posted by yycyyc
If I were you, I would install ISTA/D (Rheingold) and let it walk you through whatever calibrations need to be performed.
Yes. I update the DSC and VGSG too.
I will try. Thank you.
why did you update all these modules in the first place? updates usually dont fix problems unless there was a specific TSB that called for such(in which case the TSB gives your the ZUSB to use).
Current:
- 09 335i MSport, FBO.
- 98 Euro M3, Estoril Blue
- 04 M3, Carbon Black, 6 Speed Coupe
- 06 M5, Black on Black, Full Leather.
- 73 3.0CS, Tagia Green, 5 speed M30b35 converted
Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i, 2001 M3, 2006 M5 6 speed
Update.
I downloaded the ISTA/D and ISTA/P (52GB). UpdateD all the modules. The ABS,BRAKE, 4X4 lights are all gone. All the modules are the latest. Everything works well. The transmission problem still exists, seems mine is not software problem. I do not updated them anymore.
hey,
my car is a e60 535D from 2009. my question is to find out correct ZB number. goal is to flash to the sport version. already coded to $2TB.
via Inpa find out, ZB Number
+G;1;469469;A;EGS_M57_487_ GKE 195 B30
7577144;7574064;7569980;0709410;WHNSL
7582468;7572988;7569980;0803400-0809410,0709500-0803550;WHNSL
7592136;7591972;7569980;0903410-1003450,0809500-1003501;WHNSL
GKE 195 B30 family
in the ATS file found out:
NX91;;2TB;7592134;SE
NX91;;205;7592136;SE
means for sport 2TB ZB numer 7592134 is it correct??
7592134 is in GKE 195 D30_2 family.
+G;1;349179;A;EGS_M57_470_ GKE 195 D30_2
7573362;7572472;7569980;0703450-0703460;WHNS
7567033;7564894;7564894;0703350-0709300;WNS
7571708;7569980;7569980;0703410-0703420;WNS
7582470;7572988;7569980;0803400-0809410,0709500-0803550;WHNSL
7576797;7575795;7569980;0703510-0703516;WHNSL
7575077;7572472;7569980;0703500;WHNSL
7578837;7575795;7569980;0703520-0703525;WHNSL
7591318;7588853;7569980;0809450;WHNSL
7579171;7573100;7569980;0709450-0803350;WHNSL
7577146;7574064;7569980;0709410;WHN
7592134;7591972;7569980;0903410-1003450,0809500-;WHNSL
am I wrong with my theory?
thanks
can someone explain what whsl, whn or wsn mean?
