RM European Auto Parts
Results 1 to 9 of 9
Thread: Driver's Side Window Problem
    Aug 2015
    Stanford, CA
    1994 325i Convertible
    Hey, I have an e36 convertible where the driver's side window works intermittently. First off, yes, I have searched pretty extensively about this, but my problem seems different from other peoples'. For me, the window occasionally works just fine, but suddenly, it does a partial retract, like if it sensed that there was an obstruction. After that, the window doesn't respond to the switch for some arbitrary amount of time. This varies. I've had days where it starts working again within five minutes, and other times where it takes a few days. Also, it only ever stops working when it's going up. It never hangs while retracting, though once it freezes, it doesn't move either direction.
    I took off my door card to get a better view of the regulator. The slides all look good and greased, and since it moves occasionally, I know the electrical system is fine. I tested whether it was a problem with switch contacts by replacing the switch with the front passenger window switch, but it had the same issues, so the switch is fine.
    I suspect that there is a problem with the system that detects obstructions and stops the window from closing. When I press the switch, I briefly see voltage on the motor power leads, and I can hear (from the glovebox area) a relay closing, but almost immediately reopening. Unplugging the sensor wires seems to, occasionally, allow the window to move either up or down in very small steps, but it quickly freezes when I do that too.
    Does anyone have experience with the window obstruction sensor system, or are there other troubleshooting steps I can take?
    Feb 2016
    Murfreesboro,tn
    BMW Z3
    Quote Originally Posted by Silntknight View Post
    Hey, I have an e36 convertible where the driver's side window works intermittently. First off, yes, I have searched pretty extensively about this, but my problem seems different from other peoples'. For me, the window occasionally works just fine, but suddenly, it does a partial retract, like if it sensed that there was an obstruction. After that, the window doesn't respond to the switch for some arbitrary amount of time. This varies. I've had days where it starts working again within five minutes, and other times where it takes a few days. Also, it only ever stops working when it's going up. It never hangs while retracting, though once it freezes, it doesn't move either direction. I took off my door card to get a better view of the regulator. The slides all look good and greased, and since it moves occasionally, I know the electrical system is fine. I tested whether it was a problem with switch contacts by replacing the switch with the front passenger window switch, but it had the same issues, so the switch is fine. I suspect that there is a problem with the system that detects obstructions and stops the window from closing. When I press the switch, I briefly see voltage on the motor power leads, and I can hear (from the glovebox area) a relay closing, but almost immediately reopening. Unplugging the sensor wires seems to, occasionally, allow the window to move either up or down in very small steps, but it quickly freezes when I do that too. Does anyone have experience with the window obstruction sensor system, or are there other troubleshooting steps I can take? Thanks!
    I'm having the same problem. I'll be watching for an answer.
    Mar 2003
    St. Joseph, Mo.
    95 m3+, 03 ZHP, Mk4 Tdi
    Actually. Pretty common problem. Likely a problem with the door micro-switch.
    Aug 2015
    Stanford, CA
    Quote Originally Posted by shadowpuck View Post
    Can you elaborate? If I understand you correctly, the microswitch would signal whether the door is open or closed. Why would that interfere with the ability to raise and lower the window (since it should be able to do that in both cases), and why would it get stuck where it won't move for days? Also, if it's common, do you know if anyone has posted a solution? I haven't seen one yet...
    Any other diagnostic tips you can give me would be awesome too. I'm doubtful about finding a solution after not seeing one for so long, so I am going to be trying to solve it myself.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    I know that the E46 chassis has the General Module 5 (GM5) for windows, central locking, etc. I believe the E36 has the GM4 module. The GM5 module is full of relays that can act intermittently. I think I'd check that if all else fails.
    In the E46 there's a switch in each door lock actuator. A bad switch could impact (not 100% sure) window ops.
    Mar 2003
    St. Joseph, Mo.
    i may have also mis-read your original post - so apologies there.
    it sounds like you are describing the one-touch up operation. google/forum searches should produce numerous hits on how to troubleshoot and test this operation. have you tested for voltage at the switch while you were having the problem? i'm thinking things like weak relay, fuse, or even the motor itself - since you mentioned that when it fails you lose control for an arbitrary period of time.
    i have heard of micro-switches causing all sorts of weirdness, too.
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    The E36 window regulator is much more reliable than the lousy cable and plastic pulley arrangement of the E46....BUT, when it does fail, it's more of a problem to diagnose and replace.
    Your best first step will be to remove the door glass from the regulator. (It would be a good idea to pick up two of the white plastic window slides from your local dealership) Removing the glass will remove much of the strain from the motor and the regulator. If the problem goes away, replace the motor and regulator. If the problem continues, you have an electrical issue. If it's an electrical issue, first suspect will be the wiring in the door hinge are's rubber boot.
    Chris Powell
    BMWCCA 274412
    Aug 2015
    Stanford, CA
    Quote Originally Posted by MarcoZandrini View Post
    I'll look into this a bit more. The GM4 is certainly in the right place (behind the glove box), and perhaps the relay only works sometimes, which is causing the issue.
    I'm actually talking about any type of operation, one-touch up/down, or hold up/down. I've only tested voltages at the motor terminals. I unplugged the motor and tried operating the window. I would read around ±12V when it worked, depending on if I pressed up or down, and a brief spike before 0V when the window wasn't working. Basically, even with the motor itself disconnected, the system showed that it momentarily tried to send power (relay closing sound I heard) before cutting it (relay opening sound I heard).
    Quote Originally Posted by bmwdirtracer View Post
    I'll try that. I've already gotten the door card out (the PO secured it with a wood screw and a few of the bottom tabs...), so it's only a few more steps. I was first going to try removing the motor from the regulator assembly and testing if it spins freely when removed. I was having problems with my convertible top and I noticed a motor retention plate was bent, likely causing the problem, so I wouldn't be surprised if other motors were misaligned, causing increased loads. Hopefully this will tell me if it's mechanical or electrical!
    Aug 2015
    Colombia
    '93 E36 325i Coupe
    I know that this is an old thread, but did you manage to fix this? I think I might be having the same problem as you had.
  1. Driver's side window problem
    By mva in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 10-13-2013, 11:23 AM
  2. Driver's side window problem...
    By Gene V in forum Hawaii & Other Islands
    Last Post: 01-04-2011, 03:02 PM
  3. Power driver side window problem
    By scoot21 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-13-2004, 12:04 PM
  4. Driver side window problems
    By babarn in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 05-08-2004, 07:09 PM
  5. driver's side window problem
    By Blazin95Red325i in forum 1991 - 1999 (E36)
    Last Post: 06-30-2003, 12:14 PM
