Autogeek.net Car Care Products
** 10% off @ Autogeek.net - PinnacleWax.com & Wolfgangcarcare.com - Coupon Code = clubmember
Results 1 to 7 of 7
Thread: Engine Bay cleaning - 2007 335i e92 coupe
    Feb 2016
    New york
    2007 BMW 335i
    Exclamation Engine Bay cleaning - 2007 335i e92 coupe
    Hello Guys I want to clean my engine bay like this one in the picture, I just wanted to know what needs to be covered before washing the engine with water, or is there another alternative to water that will be just as effective. I have a BMW e92 coupe ; if you can circle the areas that need to be covered with a Plastic bag, aluminum foil or saran wrap. PLEASE let me know ASAP I just got the valve cover gasket changed and need the excess oil out of my engine as it is smoking. Thank you.
    Mar 2016
    Oz
    M3
    Some degreaser on the oil and careful low pressure water would work. Keep away from any electrical connectors etc.
    Feb 2010
    Rochester, Michigan
    E36 M3
    Nothing needs to be wrapped, covered, or protected above and beyond what is already in place from the factory. In some rare cases the electrical distribution box (aka fuse box) may have a warning sign to keep dry. GM does this on some vehicles. Other manufacturers just add the cost of a rubber seal to the fuse box top.
    Dec 2009
    MA
    e92
    The burning/white smoke will go away after a couple miles unless its still leaking.
    Jersey City, NJ
    2013 X5 35i M-Sport
    As long as you aren't completely flooding the compartment with water, you will be fine. You might hear some belt squealing when you first start the engine up but it will stop after a min or two.
    VRSF CP & DP | BMS Intake | MHD 2+ Tune | BavSound Stage 1 | 20% Tint
    Contact me for module coding/ECU resets
    Everett, WA, USA
    '01 740i, '93 300ZX TT
    You can use full strength simple green without damage to components, paint, etc. If you're dealng with small areas that are dirty, you can follow up by washing it down with a water spray bottle otherwise misting with a hose is just fine. WD-40 also works as a great cleaner, especially on engine parts. If you want a "showroom shine" on the engine (which personally I'm not a fan of) look into WATER based engine dressing since it will minimize on the stickiness and attract less dirt.
    Feb 2016
    New york
    2007 BMW 335i
    Thank you guys I will be cleaning with simple green tomorrow and misting water - fingers crossed!
  1. 2007 335i E92 Coupe, Low miles, California car
    By jeffb325 in forum 3 series & Z Series
    Last Post: 12-17-2015, 03:26 PM
  2. engine bay cleaning
    By will227457 in forum 1991 - 1999 (E36)
    Last Post: 10-08-2006, 02:56 PM
  3. engine bay cleaning
    By Dropped325i in forum 1983 - 1991 (E30)
    Last Post: 03-12-2006, 02:00 AM
  4. Engine Bay Cleaning?
    By 325rider in forum Car Detailing and Show & Shine Prep sponsored by Autogeek.net
    Last Post: 12-28-2005, 10:33 PM
  5. Engine Bay cleaning: The lazy way.
    By jsp98m3 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 09-02-2001, 03:35 AM
