Results 1 to 25 of 29
Thread: E39 540i piston 7&8 crashed due to supercharger. Engine with no ecu tuning.
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Dear friends. My engine broken down due to I can not tune my ecu. Looks like there was poor fuel injection and temperature was increased above 1000 deg Celsius. Who can help me with this issue? This is my 3rd messeg. Kindly ask your support. I need someone who can help me with tune my ecu.
    Here it is.
    Feb 2016
    Michigan
    1999 540i S/C
    Aluminum melting point is 660 Deg. Celsius.
    Jun 2014
    Fresno, Ca
    2001 BMW 540I
    ^^^^ lol.
    2001 Topaz Blue 540I6 sport - aFe Intake - CDV Delete -
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    I laughed when I saw 1000...... .... .
    Warren, MI
    00 M5 / 99 540i
    What type of supercharger? Propane heat injector to obtain 1000°C?
    Look up Frank Smith / ttfs... Better yet
    http://www.tuningtechfs.com
    2000 Silverstone/Silverstone M5 1/34
    Dec 2014
    Cave Creek, Arizona
    2008 E90 335i
    Hypothetically he could have ambient temps in the cylinder that were above 1000ºc for a very short period of time. RIP engine tho.
    E90 335i
    On3 Performance top mount single turbo kit, Precision 6466 Turbo, ECS Tuning charge pipe, 7in FMIC, JB4 w/ MHD backend flash, Stage 3 fuel pump, Port injection, E85, some wheels that came w the car but are thick
    E39 540i (SOLD)
    6 spd swap, "Almost Nardo" Vinyl Wrap, JB Racing LTW flywheel, M5 clutch & control, BC
    Racing
    coilovers, cat back straight pipe, E60 SSK, ZHP shift knob, hard wired aux, Style 32 17", BFG G-force Sport Comp-2 tires, shadow-line trim, reenforced differential bushing, ATE Type 200, Hawk HP Plus pads, intake res delete, 10W40 M1, trans fill 50/50 Redline MT-90 & 75w90NS, solid shifter carrier bushing, pixel fix, red needles
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Where is Ashgabat?
    Feb 2016
    Michigan
    1999 540i S/C
    Turkmenistan or what use to be Russia
    West Plains, MO
    '97 540i Dinan, 98 740iL
    Why is that so hard to believe? If that's an exhaust temperature, 1000C is only 1832F... way too hot and will burn the exhaust valves, of course, but certainly possible.
    I've routinely seen 1600F without melting anything on my E23 745i turbo at 15 psi boost. But I didn't hold it there for long. (Also because there was no place to go that fast)...
    '98 740iL E38 201k, TCG at 190k, 5HP24 at 195k
    '97 540i/6 E39 Dinan blower & stage 1 suspension 114k
    '93 525i E34 "Golf Ball" (hail damaged) 334k
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    My EGT hits 1250 F or so. 12 psi boost with meth. If he severely leaned this engine out, the higher Temps are possible.
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Your suggestion?
    I need your suggestions. I have installed pulley 3.15 with 6pk 1468 belt.
    1. Who knows what is the boost I have?
    2. Now I am replacing my engine and going to decries my compression in engine. By defoult it is 10.5:1 I guess now decreasing to 9.5:1. Will that help me?
    3. Look at my pistons, looks like oil was not delivered sufficient or was too hot when it reach piston #7&8 and become evaporated. Should I install oil cooler and performance pump for oil?
    Thanks in advance.
    Jul 2013
    Ontario, Canada
    1998 528i; 2000 540i;
    There is a "Forced Induction" forum here. Also, there is a "tuning" forum. You might have better luck talking to those guys.
    gmak: The Good, the Bad, and the Ugly. A journey with my new-to-me 2000 540i
    "Working on a BMW E39 is the best way to run out of time."
    Mar 2012
    Lansdale, Pa
    Get an AFR and Boost gauge and get a proper tune. Without a proper tune your just going to keep ruining engines. Did you actually think you could run the SC without a proper tune? SMH.
    Dec 2014
    Cave Creek, Arizona
    2008 E90 335i
    Even a DIY driving around the block tune on pirated software is better than no tune.
    E90 335i
    E39 540i (SOLD)
    Racing
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    I cannot find any one who can tune my ecu. If you have some give me advise please.
    I tried to ess but they said that they working only with their costumers.
    Today my engine was repaired and decreased compression for 9.5:1. Hope it will help more.
    I am interecting on water methanol as well. Which one is best one?
    Which afr manifacture is best one. I have read about PLX 4gen. Your opinion?
    Sep 2015
    Mankato, MN
    1999 540i
    Quote Originally Posted by Clark49660 View Post
    Used to be part of the Soviet Union, you mean.
    Turkmenistan has always been Turkmenistan, and Russia has always been Russia. (Modern history, anyways).
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Quote Originally Posted by Mach540 View Post
    Turkmenistan ex USSR
    Warren, MI
    00 M5 / 99 540i
    Contact Frank Smith... I supplied a link above. He's the go to guy it seems lately, can help remote tune
    Feb 2016
    Michigan
    1999 540i S/C
    +1 That's what I ment
    Are you running the correct size injectors. You should be running about a 42lb injector, Or you risk predetonation and engine damage.
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Quote Originally Posted by philly98540 View Post
    I am thinking about AFR but how many should I install? 1 set on one site or 2 set on each site on exhaust headers?
    Feb 2014
    Seattle wa usa
    2003 546it m-sport
    DUDMD here on bimmerforums might be able to help also.
    Try fixing your supercharger problems before going meth and water injection.
    Or,
    Buy an M5 and stop dealing with stuff like this.
    Who told you that you could use a supercharger without a tune?! Slap that person, hard.
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Quote Originally Posted by Plattus1000 View Post
    Or,
    I have been just contacting with him, he said that he cannot help me with tuning of my ECU.
    Feb 2016
    Michigan
    1999 540i S/C
    What size injectors are you using.
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    450 CC, it came with kit itself.
    Also, as I mentioned above I decreased engine compression by putting additional seal between headers and engine block. Before it was 10.5:1 now it is 9.5:1. What do you think will that help me against detonation (force induction)?
    Jul 2012
    MA
    ///M5
    Nice troll.
    Current
    2005 E55 AMG
    1998 Silverado K1500
    1964 Impala
    ​1964 Chevelle 496ci
    Past
    2000 Avus M5
    1988 Suburban K1500
    1987 Suburban K2500
    2007 Suburban
    1999 K2500 Suburban
    2000 MGM
    1999 K2500 Suburban
    2001 Stratus 740i Msport
    1990 750iL
    1995 540i/6
    1996 MGM
  1. How to move seat with no power
    By ClarkWGriswold in forum 1988 - 1996 (E34)
    Last Post: 10-22-2021, 08:27 PM
  2. About to reinstall engine with new main seals
    By rvGraham in forum 1991 - 1999 (E36)
    Last Post: 12-30-2008, 11:25 PM
  3. Replies: 7
    Last Post: 11-27-2008, 07:08 PM
  4. E36 325 to 328 engine with turbo. Thoughts?
    By fixture in forum Forced Induction
    Last Post: 11-10-2008, 02:58 PM
