I'm trying to relocate the abs pump. It is going to be to close to the header on the driver side. Trying to find fitting sizes?
what did you end up doing I'm running into the exact same problem
Ended up leaving it in the same location for now, smashed the header in and wrapped. Moved the abs in some. I have about 1/4" of clearance.
Sent from my SM-G900T using Tapatalk
Is this an LS swap? If so, what headers did you go with?
